波特率74880
ets Jan 8 2013,rst cause:2, boot mode:(1,6) ets Jan 8 2013,rst cause:2, boot mode:(3,6) load 0x40100000, len 1396, room 16 tail 4 chksum 0x89 load 0x3ffe8000, len 776, room 4 tail 4 chksum 0xe8 load 0x3ffe8308, len 540, room 4 tail 8 chksum 0xc0 csum 0xc0 2nd boot version : 1.4(b1) SPI Speed : 40MHz SPI Mode : QIO SPI Flash Size & Map: 16Mbit(512KB+512KB) jump to run user1 @ 1000 R )D蠦芇P尃C ?阷p_task_hdl : 3ffef6f8, prio:13, stack:512 pm_task_hdl : 3ffeffd8, prio:1, stack:176 ApiMsgMutex created tcpip_task_hdl : 3fff03f0, prio:10,stack:512 wdt_task : 3fff0cb0, prio:14, stack:176 idle_task_hdl : 3fff1820 tim_task_hdl : 3fff1c18 xPortStartScheduler frc2_timer_task_hdl:3fff2528, prio:12, stack:512 OS SDK ver: 1.2.0(b900bd2) compiled @ Aug 28 2015 17:18:41 phy ver: 356, pp ver: 9.0 SDK version:1.2.0(b900bd2) mode : softAP(5e:cf:7f:81:c8:72) dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1) add if1 bcn 100 hello world,I am MikuQ.com hello world,I am MikuQ.com
serialPort1.BaudRate = 74880;
serialPort1.PortName = "COM51";
serialPort1.Open();
private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
byte[] buf=new byte[1024];
if (e.EventType == SerialData.Chars)
int r=serialPort1.Read(buf, 0, 1024);
output(Encoding.Default.GetString(buf, 0, r));
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
