电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » 【炫Q-IOT】学用小e开发快(一)-课后实习
共23条 2/3 ‹ 1 2 3 › 跳转至页
2016-03-31 19:52:44     打赏
11楼
波特率74880
2016-03-31 20:30:08     打赏
12楼
渣么好的帖子一定要插楼
2016-03-31 20:30:54     打赏
13楼
昨天听课不认真
一点不如炫球收获多
看来以后多关注炫球大神的帖子就可以啦
2016-03-31 20:31:01     打赏
14楼
2016-03-31 20:31:49     打赏
15楼
炫球不错,学以致用
象炫球同志学习
2016-03-31 21:38:39     打赏
16楼
听上去真棒啊
2016-04-01 09:22:26     打赏
17楼
好好学习,天天向上
2016-04-01 09:50:35     打赏
18楼
74880为啥是这么个波特率呢,谁给解释一下?
2016-04-01 15:12:49     打赏
19楼
 ets Jan  8 2013,rst cause:2, boot mode:(1,6)
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size & Map: 16Mbit(512KB+512KB)
jump to run user1 @ 1000
R	)D蠦芇P尃C
?阷p_task_hdl : 3ffef6f8, prio:13, stack:512
pm_task_hdl : 3ffeffd8, prio:1, stack:176
ApiMsgMutex created
tcpip_task_hdl : 3fff03f0, prio:10,stack:512
wdt_task : 3fff0cb0, prio:14, stack:176
idle_task_hdl : 3fff1820
tim_task_hdl : 3fff1c18
xPortStartScheduler
frc2_timer_task_hdl:3fff2528, prio:12, stack:512
OS SDK ver: 1.2.0(b900bd2) compiled @ Aug 28 2015 17:18:41
phy ver: 356, pp ver: 9.0
SDK version:1.2.0(b900bd2)
mode : softAP(5e:cf:7f:81:c8:72)
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
add if1
bcn 100
hello world,I am MikuQ.com
2016-04-01 15:17:20     打赏
20楼
            serialPort1.BaudRate = 74880;
            serialPort1.PortName = "COM51";
            serialPort1.Open();
        private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
            byte[] buf=new byte[1024];
            if (e.EventType == SerialData.Chars)
                int r=serialPort1.Read(buf, 0, 1024);
                output(Encoding.Default.GetString(buf, 0, r));
