不明原因,不过考虑做一个脚本来监控,大概步骤是这样的,
1、每隔一段时间访问一下mikuq.com
2、如果不正常则重起nginx
3、记录日志
听起来应该不太难,计划用python来写,测试代码
#!/usr/bin/env python
import httplib
import sys
import os
def reboot_nginx():
os.system('nginx -s reload')
def check_webserver(address, port, resource):
try:
conn = httplib.HTTPConnection(address, port)
print 'HTTP connection created successfully'
req = conn.request('GET', resource)
print 'request for %s successful' % resource
response = conn.getresponse()
print 'response status: %s' % response.status
except httplib.error, e:
print "HTTP connection failed: %s" % e
return False
finally:
conn.close()
print 'HTTP connection closed successfully'
if response.status in [200, 301]:
return True
else:
return False
check=check_webserver('mikuq.com', 80, '/')
print 'check_webserver returned %s' % check
