各位好,本人用的迅为i.MX6Q 开发板在ubuntu下的wifi 无法使用,于是参照了帖子:http://bbs.topeetboard.com/forum.php?mod=viewthread&tid=4165迅为4412全能版V_4.0 ubuntu 在Android4.4.4的内核下移植wifi[/url] 进行了移植, 但是无法成功启动wifi。
首先我重新编译了需要的内核模块驱动,并将模块放置在了 /lib/modules下
除去模块加载的启动脚本如下:
1. chmod 0777 /dev/stpwmt
2. #chmod 0666 /dev/stpgps
3. #chmod 0666 /dev/fm
4. chmod 0777 /dev/wmtWifi
5. chmod 0660 /dev/ttySAC0
6. #chmod 0666 /dev/gps
7.
8. /system/bin/6620_launcher -m 1 -b 115200 -n /system/etc/firmware/mt6620_patch_hdr.bin -d /dev/ttySAC0 &
9.
10. sleep 5
11.
12. echo 1 > /dev/wmtWifi
13.
14. wpa_supplicant -d -Dwext -iwlan0 -c /etc/wpa_supplicant.conf &
15. sleep 3
16. dhclient wlan0 &
17.
复制代码
加载模块信息如下:
root@iMX6-ubuntu-desktop:~# lsmod
Module Size Used by
wlan_mt6620 660442 0
mtk_wmt_wifi 5536 1 wlan_mt6620
mtk_stp_uart 22272 0
mtk_stp_wmt 395990 4 wlan_mt6620,mtk_wmt_wifi,mtk_stp_uart
mtk_hif_sdio 41707 2 wlan_mt6620,mtk_stp_wmt
1. 但是wifi 启动失败,内核日志如下:
2. [MTK-WIFI] WIFI_open: WIFI_open: major 194 minor 0 (pid 1642)
3. [MTK-WIFI] WIFI_write: WIFI_write 1
4.
5. [HIF-SDIO][I]mtk_wcn_wmt_func_ctrl:OPID(3) type(3) start
6. [STP] mtk_wcn_stp_psm_disable:[W] STP Not Ready, Dont do Sleep/Wakeup
7. [WMT-DFT][I]mtk_wcn_cmb_hw_pwr_on:CMB-HW, hw_pwr_on start
8. [WMT-DFT][I]wmt_plat_pmu_ctrl:WMT-PLAT:PMU init (out 0)
9. [WMT-DFT][I]wmt_plat_rst_ctrl:WMT-PLAT:RST init (out 0)
10. [WMT-DFT][I]wmt_plat_bgf_eint_ctrl:BGF_EINT gpio request fail, ret = -16
11. dbus[1737]: [system] Activating service name='org.freedesktop.PolicyKit1' (using servicehelper)
12. dbus[1737]: [system] Activated service 'org.freedesktop.PolicyKit1' failed: Failed to execute program /usr/lib/dbus-1.0/dbus-daemon-launch-helper: Success
13. [WMT-DFT][I]mtk_wcn_cmb_hw_pwr_on:CMB-HW, rtc clock exported
14. [WMT-DFT][I]wmt_plat_uart_ctrl:WMT-PLAT:UART init (mode_01, uart)
15. [WMT-DFT][I]wmt_plat_pmu_ctrl:WMT-PLAT:PMU (out_h 0)
16. [WMT-DFT][I]wmt_plat_rst_ctrl:WMT-PLAT:RST (out_h 0)
17. [WMT-DFT][I]wmt_plat_pmu_ctrl:WMT-PLAT:PMU (out_h 1)
18. dbus[1737]: [system] Activating service name='org.freedesktop.UDisks' (using servicehelper)
19. [WMT-DFT][I]wmt_plat_rst_ctrl:WMT-PLAT:RST (out_h 1)
20. dbus[1737]: [system] Activated service 'org.freedesktop.UDisks' failed: Failed to execute program /usr/lib/dbus-1.0/dbus-daemon-launch-helper: Success
21. [WMT-DFT][I]wmt_plat_audio_ctrl:PCM/I2S pin seperate
22. [WMT-DFT][I]wmt_plat_audio_ctrl:skip chip aif setting
23. [WMT-DFT][I]wmt_plat_bgf_eint_ctrl:WMT-PLAT: bgf irq num is: 351
24. [WMT-DFT][I]wmt_plat_eirq_ctrl:WMT-PLAT: request IRQ fail for BGF IRQ : 351
25. [WMT-DFT][I]wmt_plat_eirq_ctrl:WMT-PLAT:BGF Int requested...fail, iRet=-16
26. [WMT-DFT][I]mtk_wcn_cmb_hw_pwr_on:CMB-HW, BGF_EINT IRQ registered and disabled
27. [HIF-SDIO][E]wmt_core_ctrl(466):WMT-CORE: wmt_core_ctrl failed: id(1), type(0), value(0) iRet:(-32)
28. drivers/misc/mediatek/combo_mt66xx/wmt/core/wmt_core.c, 467, (0)
29. [HIF-SDIO][E]opfunc_pwr_on(936):WMT-CORE: WMT_CTRL_HW_PWR_ON fail iRet(-32)
30. [HIF-SDIO][E]opfunc_func_on(1096):func(3) pwr_on fail(-1)
31. drivers/misc/mediatek/combo_mt66xx/wmt/core/wmt_core.c, 1097, (0)
32. [HIF-SDIO][W]wmtd_thread:opid (0x3) failed, iRet(-3)
33. [HIF-SDIO][W]wmt_lib_put_act_op:opId(3) result:-3
34. [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
35. [HIF-SDIO][W]mtk_wcn_wmt_func_ctrl:OPID(3) type(3) fail
36. [MTK-WIFI] WIFI_write: WMT turn on WIFI fail!
复制代码
