Given a binary tree and a sum, determine if the tree has a root-to-leaf path such that adding up all the values along the path equals the given sum.
For example:
Given the below binary tree andsum = 22,
5 / \ 4 8 / / \ 11 13 4 / \ \ 7 2 1
return true, as there exist a root-to-leaf path5->4->11->2which sum is 22.
class Solution {
public:
bool hasPathSum(TreeNode* root, int sum)
if (root==NULL)
return false;
if (root->right==NULL && root->left==NULL && sum-root->val==0)
return true;
return hasPathSum(root->left, sum-root->val ) || hasPathSum(root->right, sum - root->val);
For example:Given the below binary tree andsum = 22,
