电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » path-sum
path-sum
2018-01-23 12:19:33     打赏
Given a binary tree and a sum, determine if the tree has a root-to-leaf path such that adding up all the values along the path equals the given sum.
For example:
Given the below binary tree andsum = 22,
              5
            4   8
          11  13  4
        7    2      1
return true, as there exist a root-to-leaf path5->4->11->2which sum is 22.
[cpp] view plain copy
  1. class Solution {
  2. public:
  3.     bool hasPathSum(TreeNode* root, int sum)
  4.     {
  5.         if (root==NULL)
  6.         {
  7.             return false;
  8.         }
  9.
  10.         if (root->right==NULL && root->left==NULL && sum-root->val==0)
  11.         {
  12.             return true;
  13.         }
  14.
  15.         return hasPathSum(root->left, sum-root->val ) || hasPathSum(root->right, sum - root->val);
  16.     }
  17. };
For example:
              5
            4   8
          11  13  4
        7    2      1
