Given two words (start and end), and a dictionary, find the length of shortest transformation sequence from start to end, such that:
- Only one letter can be changed at a time
- Each intermediate word must exist in the dictionary
For example,
Given:
start ="hit"
end ="cog"
dict =["hot","dot","dog","lot","log"]
As one shortest transformation is"hit" -> "hot" -> "dot" -> "dog" -> "cog",
return its length5.
Note:
- Return 0 if there is no such transformation sequence.
- All words have the same length.
- All words contain only lowercase alphabetic characters.
题意:将单词一通过给定的词典中进行转换,返回转换次数最少,转换成end单词;
思路:使用广度优先遍历;1、将start放入队列q1,初始count=0;2、当q1非空,逐个遍历q1中的单词,count++;3、设q1中的单词为str, 寻找其临近单词s,如果s等于end返回count+1否则,将s放入队列q2中,4、将q1和 q2 交换,继续执行2
[cpp] view plain copy
- class Solution
- int ladderLength(string start, string end, unorder_set<string>& dict)
- queue<string> q1, q2, *p1, *p2;
- int count = 0;
- for (p1=&q1, p2=&q2, p1->push(start); p1->size(); swap(p1, p2))
- ++count;
- for (string str; p1->size(); p1->pop())
- str = p1->front();
- for (int i=0; i<str.length(); i++)
- string s = str;
- for (char ch = 'a'; ch <= 'z'; ++ch)
- if (ch==str[i])
- continue;
- s[i] = ch;
- if (s==end)
- return count + 1;
- if (dict.find(s)!=dict.end())
- p2->push(s);
- dict.erase(s);
- return 0;
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
