在推荐的店铺,杂七乱八的这个电买了100多块钱的东西,led最简单,让他亮起来再说。
这三个最靠边,方便链接,都是C,就他们三个了,
初始化引脚
/*Configure GPIO pins : Din_Pin cs_Pin clk_Pin */
GPIO_InitStruct.Pin = Din_Pin|cs_Pin|clk_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
编写对8279写的函数
void Write_Max7219_byte(uchar DATA)
uchar i;
//Max7219_pinCS=0;
HAL_GPIO_WritePin(GPIOC, cs_Pin, GPIO_PIN_RESET);
for(i=8;i>=1;i--)
HAL_GPIO_WritePin(GPIOC,clk_Pin, GPIO_PIN_RESET);
if(DATA&0x80)
HAL_GPIO_WritePin(GPIOC, Din_Pin, GPIO_PIN_SET);
else
HAL_GPIO_WritePin(GPIOC, Din_Pin, GPIO_PIN_RESET);
DATA=DATA<<1;
HAL_GPIO_WritePin(GPIOC, clk_Pin, GPIO_PIN_SET);
针对地址写函数
void Write_Max7219(uchar address,uchar dat)
HAL_GPIO_WritePin(GPIOC, cs_Pin,GPIO_PIN_RESET);
Write_Max7219_byte(address);
Write_Max7219_byte(dat);
HAL_GPIO_WritePin(GPIOC, cs_Pin, GPIO_PIN_SET);
然后初始化8279
void Init_MAX7219(void)
Write_Max7219(0x09, 0x00); //????:BCD?
Write_Max7219(0x0a, 0x03); //??
Write_Max7219(0x0b, 0x07); //????;8??????
Write_Max7219(0x0c, 0x01); //????:0,????:1
Write_Max7219(0x0f, 0x00); //????:1;????,????:0
取字模
uchar const disp1[38][8]={
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
{0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1
{0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
{0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
{0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4
{0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5
{0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6
{0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7
{0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
{0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9
{0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A
{0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0},//B
{0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0},//C
{0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0},//D
{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x7C},//E
{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x40},//F
{0x3C,0x40,0x40,0x40,0x40,0x44,0x44,0x3C},//G
{0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x44},//H
{0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x7C},//I
{0x3C,0x8,0x8,0x8,0x8,0x8,0x48,0x30},//J
{0x0,0x24,0x28,0x30,0x20,0x30,0x28,0x24},//K
{0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7C},//L
{0x81,0xC3,0xA5,0x99,0x81,0x81,0x81,0x81},//M
{0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0},//N
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//O
{0x3C,0x22,0x22,0x22,0x3C,0x20,0x20,0x20},//P
{0x1C,0x22,0x22,0x22,0x22,0x26,0x22,0x1D},//Q
{0x3C,0x22,0x22,0x22,0x3C,0x24,0x22,0x21},//R
{0x0,0x1E,0x20,0x20,0x3E,0x2,0x2,0x3C},//S
{0x0,0x3E,0x8,0x8,0x8,0x8,0x8,0x8},//T
{0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C},//U
{0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18},//V
{0x0,0x49,0x49,0x49,0x49,0x2A,0x1C,0x0},//W
{0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41},//X
{0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8},//Y
{0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F},//Z
{0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},//ÖÐ
{0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//¹ú
开始测试吧
void max8279test(void)
uchar i,j;
HAL_Delay(50);
Init_MAX7219();
for(j=0;j<38;j++)
for(i=1;i<9;i++)
Write_Max7219(i,disp1[j][i-1]);
HAL_Delay(1000);
然后就亮起来了。
视频不会上传,估计得传到其他网站,然后贴链接吧,太麻烦了,算了吧
