电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » STM32F0+SPI+0.96 OLED
共7条 1/1 1 跳转至页
2018-11-29 18:37:30     打赏
拿出板卡,一股正版的气息铺面而来...
创建库函数版工程模板
Stm32F0的标准库不好找,放个链接
https://www.st.com/content/st_com/zh/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32-standard-peripheral-libraries/stsw-stm32048.html#getsoftware-scroll
然后创建模板,日常操作,截几个关键的图吧
这是必须的一些文件,勿忘,还有
然后我考虑用cubemx试试,但是感觉不太好用,可能是因为注释太多了吧。。。
移植OLED驱动程序
效果如下
主程序如下
部分驱动程序如下
#include "oled.h"
#include "oledfont.h"
#include "stm32f0xx.h"
#include "delay.h"
void OLED_Configuration(void)
   GPIO_InitTypeDef GPIO_InitStructure;
	 RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB,ENABLE);
	 GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT;//ÍÆÍìÊä³ö
	 GPIO_InitStructure.GPIO_Pin=GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
	 GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
	 GPIO_Init(GPIOB,&GPIO_InitStructure);
	 GPIO_SetBits(GPIOB,GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15);
void OLED_Init(void)
   OLED_RST_Set();
	 delay_ms(100);
	 OLED_RST_Clr();
	 delay_ms(100);
	 OLED_RST_Set();
	 OLED_WR_Byte(0xAE,OLED_CMD);//Set display off
	 OLED_WR_Byte(0x00,OLED_CMD);//set low column address
	 OLED_WR_Byte(0x10,OLED_CMD);//set high column address
	 OLED_WR_Byte(0x40,OLED_CMD);//set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
	 OLED_WR_Byte(0x81,OLED_CMD);//Set contrast control
	 OLED_WR_Byte(0xCF,OLED_CMD);//Select1-256
	 OLED_WR_Byte(0xA4,OLED_CMD);//Disable entire display
	 OLED_WR_Byte(0xA6,OLED_CMD);//Set normal display
	 OLED_WR_Byte(0xAF,OLED_CMD);//Set display on
	 OLED_WR_Byte(0x20,OLED_CMD);//Set memory addressing mode
	 OLED_WR_Byte(0x02,OLED_CMD);//Set page addressing mode
	 OLED_WR_Byte(0xA1,OLED_CMD);//Disable segment re-map
	 OLED_WR_Byte(0xA8,OLED_CMD);//Set multiplex ratio
	 OLED_WR_Byte(0x3F,OLED_CMD);//1/64 duty
	 OLED_WR_Byte(0xC8,OLED_CMD);//Set normal mode scan
	 OLED_WR_Byte(0xD3,OLED_CMD);//Set display offset
	 OLED_WR_Byte(0x00,OLED_CMD);//No offset
	 OLED_WR_Byte(0xDA,OLED_CMD);//Set COM pins hardware configuration
	 OLED_WR_Byte(0x12,OLED_CMD);//Alternative COM pin configuration
	 OLED_WR_Byte(0xD5,OLED_CMD);//Set display clock clock divide
	 OLED_WR_Byte(0x80,OLED_CMD);//100 frames/s
	 OLED_WR_Byte(0xD9,OLED_CMD);//Set pre-charge period
	 OLED_WR_Byte(0xF1,OLED_CMD);//Set pre-charge as 15 clocks,discharge as 1 clock
	 OLED_WR_Byte(0xDB,OLED_CMD);//Set Vcomh deselect level
	 OLED_WR_Byte(0x40,OLED_CMD);//~0.77xVcc
	 OLED_WR_Byte(0x8D,OLED_CMD);//Set DCDC
	 OLED_WR_Byte(0x14,OLED_CMD);//Enable DCDC (0x10 disable)
	 OLED_Clear(0);
	 OLED_Set_Address(0,0);
/................中间省略................./
void OLED_WR_Byte(uint8_t DATA,uint8_t CMD)
   uint8_t i;
	 OLED_CS_Clr();
	 if(CMD)
	   {OLED_DC_Set();}
	 else
		  OLED_DC_Clr();
	 for(i=0;i<8;i++)
	    OLED_SCLK_Clr();
		  if(DATA&0x80)
			  {OLED_SDIN_Set();}
      else
         OLED_SDIN_Clr();
			OLED_SCLK_Set();
			DATA<<=1;
	 OLED_CS_Set();
   OLED_DC_Set();
void OLED_Set_Address(uint8_t column,uint8_t page)
   OLED_WR_Byte(OLED_PAGE_Address+page,OLED_CMD);
   OLED_WR_Byte(OLED_LINE_Address_L+column%16,OLED_CMD);
   OLED_WR_Byte(OLED_LINE_Address_H+column/16,OLED_CMD);
void OLED_ShowString(u8 x,u8 y,u8 *chr)
	unsigned char j=0;
	while (chr[j]!='\0')
	{		OLED_ShowChar(x,y,chr[j]);
			x+=8;
		if(x>120){x=0;y+=2;}
			j++;
驱动代码网盘链接
https://pan.baidu.com/s/1adV97nYilo4b7PikCFnqBA
现在就做了这么多,因为F0的板子大家很少用,程序都得从F1的移植,所以有点麻烦
先就这么多吧,告辞
关键词: STM32F0     OLED
管理员
2018-11-30 14:55:14     打赏
楼主棒棒哒
2018-12-01 08:37:49     打赏
加油加油
2018-12-06 14:34:09     打赏
很棒~期待楼主的新帖~
2018-12-15 21:19:07     打赏
显示的效果挺不错的,点赞。
2022-01-21 10:47:21     打赏
2022-01-21 10:50:58     打赏
感谢分享,学习学习
共7条 1/1 1 跳转至页
