电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 跳动的心之三——另辟蹊径出心跳
共4条 1/1 1 跳转至页
跳动的心之三——另辟蹊径出心跳
2019-01-01 21:51:28     打赏
用STM32CubeMX和keil5组合,编出来的程序无论怎么查都找不出问题,头疼啊
没办法,找过一些程序作参考,但小白终究是小白,还是调不出来,正当我要放弃的时候,突然想起在查找板子相关资料的时候发现这个板子是可以支持mebd项目中的在线开发环境的,我要是从那个方向下手,换个程序编会不会成功呢,与其纠缠在原来的程序中,倒不如尝试一下新的编程方式。
说干就干。首先,点开mbed在线调试。
第一次使用需要注册,注册完直接登录,创建工程。可以直接导入创建例程工程。随便选择一个,点击“OK”创建工程,直接打开main.c文件。
可以看到直接就有例程了,咱们的项目用不到,直接全选删除即可。
界面比较简洁,一看就懂。
加入程序。
#include "mbed.h"
#define false 0
#define true 1
Ticker tick;
DigitalOut leds(D12);
DigitalOut led1(LED1);
AnalogIn pulsepin(A0);//analog input pin
Serial pc(SERIAL_TX, SERIAL_RX);//USB TO SERIAL
// these variables are volatile because they are used during the shorterrupt service routine!
volatile short BPM;                   // used to hold the pulse rate
volatile short Signal;                // holds the incoming raw data
volatile short IBI = 600;             // holds the time between beats, must be seeded!
volatile char Pulse = false;     // true when pulse wave is high, false when it's low
volatile char QS = false;        // becomes true when Arduoino finds a beat.
volatile short rate[10];                    // array to hold last ten IBI values
volatile unsigned long sampleCounter = 0;          // used to determine pulse timing
volatile unsigned long lastBeatTime = 0;           // used to find IBI
volatile short P =512;                      // used to find peak in pulse wave, seeded
volatile short T = 512;                     // used to find trough in pulse wave, seeded
volatile short thresh = 512;                // used to find instant moment of heart beat, seeded
volatile short amp = 100;                   // used to hold amplitude of pulse waveform, seeded
volatile char firstBeat = true;        // used to seed rate array so we startup with reasonable BPM
volatile char secondBeat = false;      // used to seed rate array so we startup with reasonable BPM
//void ledFadeToBeat()
//    fadeRate -= 15;                         //  set LED fade value
//    fadeRate = constrain(fadeRate,0,255);   //  keep LED fade value from going shorto negative numbers!
//    analogWrite(fadePin,fadeRate);          //  fade LED
void timer_isr(void)
    //cli();                                      // disable shorterrupts while we do this
    Signal = pulsepin.read_u16()>>6;              // read the Pulse Sensor
    sampleCounter += 2;                         // keep track of the time in mS with this variable
    short N = sampleCounter - lastBeatTime;       // monitor the time since the last beat to avoid noise
    //  find the peak and trough of the pulse wave
    if(Signal < thresh && N > (IBI/5)*3) {      // avoid dichrotic noise by waiting 3/5 of last IBI
        if (Signal < T) {                       // T is the trough
            T = Signal;                         // keep track of lowest poshort in pulse wave
    if(Signal > thresh && Signal > P) {         // thresh condition helps avoid noise
        P = Signal;                             // P is the peak
    }                                        // keep track of highest poshort in pulse wave
    //  NOW IT'S TIME TO LOOK FOR THE HEART BEAT
    // signal surges up in value every time there is a pulse
    if (N > 250) {                                  // avoid high frequency noise
        if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) ) {
            Pulse = true;                               // set the Pulse flag when we think there is a pulse
            leds=1;                // turn on pin 13 LED
            IBI = sampleCounter - lastBeatTime;         // measure time between beats in mS
            lastBeatTime = sampleCounter;               // keep track of time for next pulse
            if(secondBeat) {                       // if this is the second beat, if secondBeat == TRUE
                secondBeat = false;                  // clear secondBeat flag
                for(short i=0; i<=9; i++) {            // seed the running total to get a realisitic BPM at startup
                    rate[i] = IBI;
            if(firstBeat) {                        // if it's the first time we found a beat, if firstBeat == TRUE
                firstBeat = false;                   // clear firstBeat flag
                secondBeat = true;                   // set the second beat flag
                //sei();                               // enable shorterrupts again
                return;                              // IBI value is unreliable so discard it
            // keep a running total of the last 10 IBI values
            unsigned short runningTotal = 0;                  // clear the runningTotal variable
            for(short i=0; i<=8; i++) {               // shift data in the rate array
                rate[i] = rate[i+1];                  // and drop the oldest IBI value
                runningTotal += rate[i];              // add up the 9 oldest IBI values
            rate[9] = IBI;                          // add the latest IBI to the rate array
            runningTotal += rate[9];                // add the latest IBI to runningTotal
            runningTotal /= 10;                     // average the last 10 IBI values
            BPM = 60000/runningTotal;               // how many beats can fit shorto a minute? that's BPM!
            QS = true;                              // set Quantified Self flag
            // QS FLAG IS NOT CLEARED INSIDE THIS ISR
    if (Signal < thresh && Pulse == true) {  // when the values are going down, the beat is over
        leds=0;            // turn off pin 13 LED
        Pulse = false;                         // reset the Pulse flag so we can do it again
        amp = P - T;                           // get amplitude of the pulse wave
        thresh = amp/2 + T;                    // set thresh at 50% of the amplitude
        P = thresh;                            // reset these for next time
        T = thresh;
    if (N > 2500) {                          // if 2.5 seconds go by without a beat
        thresh = 512;                          // set thresh default
        P = 512;                               // set P default
        T = 512;                               // set T default
        lastBeatTime = sampleCounter;          // bring the lastBeatTime up to date
        firstBeat = true;                      // set these to avoid noise
        secondBeat = false;                    // when we get the heartbeat back
    //sei();                                   // enable shorterrupts when youre done!
void sendDataToProcessing(char symbol, short data )
    pc.putc(symbol);                // symbol prefix tells Processing what type of data is coming
    pc.printf("%d\r\n", data);                // the data to send culminating in a carriage return
int main()
    pc.baud(115200);             // we agree to talk fast!
    tick.attach_us(&timer_isr,2000);                 // sets up to read Pulse Sensor signal every 2mS
    while(1) {
        led1 =1;
        sendDataToProcessing('S', Signal);     // send Processing the raw Pulse Sensor data
        if (QS == true) {                      // Quantified Self flag is true when arduino finds a heartbeat
            //fadeRate = 255;                  // Set 'fadeRate' Variable to 255 to fade LED with pulse
            sendDataToProcessing('B',BPM);   // send heart rate with a 'B' prefix
            sendDataToProcessing('Q',IBI);   // send time between beats with a 'Q' prefix
            QS = false;                      // reset the Quantified Self flag for next time
        //ledFadeToBeat();
        wait(0.02);                             //  take a break
点击编译,会弹出窗口,等编译完,会提示下载,直接选择板子内存,下载进去就行。
下栽进去后板子上的程序就会自动运行了。
对了,引脚接法是
pulse sensor:
VOUT       ->       PA0
VCC         <-      3.3V
GND        <-      GND
LED小灯:
VOUT       ->       PA5
VCC         <-      5V
GND        <-      GND
运行效果如下图,我的心在那跳动
我用找到的心率传感器上位机显示程序processing显示如下图。
换了一种方法,果然成功了。LED小灯闪烁频率和我的心跳一样,“跳动的心”终于跳动起来了,实现了功能。不容易啊,以前玩c51系列的,初碰stm32,还是挺有难度的,我发现,实际上,论坛上的资源还是挺多的,只是有些程序比较难读,不同型号的板子之间的联系和代码替换相关的帖子也比较少,在查找上还不是那么方便。至此,我的“跳动的心”就告一段落了,真心感谢论坛给我这次机会,也感谢在我遇到困难时对我给予帮助的小伙伴们!
PS:如果有哪位大神知道我用keil5编写的程序问题在哪,或者有对我的程序有兴趣的小伙伴,欢迎指教哦
我把PulseSensor的相关资料和显示程序链接附上,需要的自取吧。
链接:https://pan.baidu.com/s/1G-tCvMk8MdAT8EDx_KjUCQ
提取码:gngs
关键词: 跳动的心     pulse sensor     mbed
管理员
2019-01-02 10:39:41     打赏
谢谢楼主分享
2019-01-02 11:46:19     打赏
谢谢楼主分享
2019-01-03 10:12:07     打赏
不错哦,上位机软件很可爱
共4条 1/1 1 跳转至页
