如图,在测试ds18b20时 ,温度跳到25.0以后自动变成00.4,然后01.4,02.4,03.4
代码如下
#include<reg52.h>
#include<intrins.h>
typedef unsigned char u8;
typedef unsigned int u16;
sbit ds=P2^2;
sbit ser=P2^7;
sbit srclk=P2^6;
sbit rclk=P2^5;
bit flag;
unsigned char code smgduan[]={0x3f,
0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,
0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code smgwei[]={0xfe,
0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
void delayms(u16 n);
void TempDelay(u16 us);
void send_595(u8 dat);
void ds_reset()
ds=1;
_nop_();
ds=0;
TempDelay(80);//520us
ds=1;
TempDelay(5);
if(ds==0)
flag=1;
else
flag=0;
TempDelay(20);
ds=1;
bit ds_read_bit()
bit dat;
ds=0;
_nop_();
_nop_();
ds=1;
_nop_();
dat=ds;
TempDelay(12);
return dat;
u8 ds_read_byte()
u8 i,j,value;
for(i=0;i<8;i++)
j=ds_read_bit();
value=(j<<7)|(value>>1);
return value;
void ds_write_byte(u8 dat)
u8 i,onebit;
for(i=0;i<8;i++)
onebit=dat&0x01;
if(onebit) //?1
ds=0;
TempDelay(1);
ds=1;
_nop_();
else //?0
ds=0;
TempDelay(11);
ds=1;
_nop_();
dat>>=1;
u8 get_temperature()
u16 temp,temp1;
u8 a,b;
ds_reset();
ds_write_byte(0xcc);
ds_write_byte(0x44);
ds_reset();
ds_write_byte(0xbe);
a=ds_read_byte();
b=ds_read_byte();
temp=b;
temp<<=8;
temp|=a;
temp1 = temp*0.0625;
temp=temp1*10+0.5;
return temp ;
void main()
{ u16 j;
while(1){
j=get_temperature();
send_595(smgwei[0]);
send_595(smgduan[j/1000]);
rclk=0;
rclk=1;
delayms(1);
send_595(smgwei[1]);
send_595(smgduan[j%1000/100]);
rclk=0;
rclk=1;
delayms(1);
send_595(smgwei[2]);
send_595(smgduan[j%100/10]);
rclk=0;
rclk=1;
delayms(1);
send_595(smgwei[3]);
send_595(0X80);
rclk=0;
rclk=1;
delayms(1);
send_595(smgwei[4]);
send_595(smgduan[j%10]);
rclk=0;
rclk=1;
delayms(1);
send_595(smgwei[5]);
send_595(smgduan[12]);
rclk=0;
rclk=1;
delayms(1);
void delayms(u16 n)
u8 i;
while(n--)
for(i=0;i<113;i++);
void TempDelay(u8 us)
while(us--);
u8 i;
for(i=0;i<8;i++)
if(dat&0x80)
ser=1;
else
ser=0;
srclk=0;
srclk=1;
dat=dat<<1;
