总是编译不过,找了半天文章好象说是宏定义做立即数有问题?请哪位大虾点解一下!!!
make[3]: Leaving directory `/usr/src/uClinux-dist/lib/libc/termios'
make[3]: Entering directory `/usr/src/uClinux-dist/lib/libc/sysdeps'
arm-elf-gcc -O2 -g -fomit-frame-pointer -fno-builtin
-DEMBED -I/usr/src/uClinux-dist/lib/libc/include
-I/usr/src/uClinux-dist -Dlinux -D__linux__ -D__uClinux__ -Dunix
-I/usr/src/uClinux-dist/linux-2.4.x/include -I. -Iarm -c -o
arm/clone.o arm/clone.S
arm/clone.S: Assembler messages:
arm/clone.S:34: Error: internal relocation (type 232) not fixed up (IMMEDIATE)
make[3]: *** [arm/clone.o] Error 1
make[3]: Leaving directory `/usr/src/uClinux-dist/lib/libc/sysdeps'
make[2]: *** [subdirs] Error 1
make[2]: Leaving directory `/usr/src/uClinux-dist/lib/libc'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/src/uClinux-dist/lib'
make: *** [lib_only] Error 2
[root@localhost uClinux-dist]#
共1条
请教make lib_only出错Error: internal relocation (type 232) not fixed up (IMMEDIATE)
共1条
