电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【第二天】Linux-4.1.15 测试体验
共13条 1/2 1 2 › 跳转至页
2019-09-07 18:40:17     打赏
既然是评测,就实际开始用吧,适逢周末,点亮板子,
板子带四个LED灯,其中除角落的D1外,另外三个以某种规律在闪动,也不知道是哪个进程控制的,
关于板卡的重起和关机似乎有了问题,
首先测试的是reboot,结果没能重起卡住了
2019-09-07 18:53:22     打赏
可以通过板卡上的reset键重启板卡,不过系统是起来了,网卡还在睡觉,打着双闪,要彻底断电冷启才能恢复
另外一个命令就是shutdown关闭,似乎也不能达到预期
不知道为什么,几次测试下来,彻底断电网卡也不灵了,先去吃饭,回来再看
2019-09-07 19:26:53     打赏
 网卡死活起不来,可能是反复重起,固件坏了吧,尝试重新烧录
[FAILED] Failed to start Raise network interfaces.
See 'systemctl status networking.service' for details.
2019-09-07 20:06:15     打赏
又搞不定网卡了,先进行其它测试吧,板卡直连电脑可以协商到10M网络,
设置电脑ip为192.168.18.18
设置板卡ip为192.168.18.100
ifconfig eth0 192.168.18.100
ping 192.168.18.18 -c 4
PING 192.168.18.18 (192.168.18.18) 56(84) bytes of data.
64 bytes from 192.168.18.18: icmp_seq=1 ttl=64 time=0.840 ms
64 bytes from 192.168.18.18: icmp_seq=2 ttl=64 time=0.894 ms
64 bytes from 192.168.18.18: icmp_seq=3 ttl=64 time=0.853 ms
64 bytes from 192.168.18.18: icmp_seq=4 ttl=64 time=0.861 ms
--- 192.168.18.18 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 0.840/0.862/0.894/0.019 ms
2019-09-07 20:16:16     打赏
USB测试用的USB读卡器,应该识别成U盘吧,不太如意,稍后再研究吧,可以了
root@myimx6ek140:~# usb 1-1: new high-speed USB device number 2 using ci_hdrc
usb-storage 1-1:1.0: USB Mass Storage device detected
scsi host0: usb-storage 1-1:1.0
scsi 0:0:0:0: Direct-Access     Mass     Storage Device   1.00 PQ: 0 ANSI: 0 CCS
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 15597568 512-byte logical blocks: (7.98 GB/7.43 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
 sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
EXT4-fs (sda1): recovery complete
EXT4-fs (sda1): mounted filesystem with writeback data mode. Opts: (null)
root@myimx6ek140:~# mount /dev/sda1 /mnt
root@myimx6ek140:~# ls /mnt
bin   dev  home  lost+found  mnt  proc  run   selinux  sys  usr
boot  etc  lib   media       opt  root  sbin  srv      tmp  var
root@myimx6ek140:~#
换上TF卡,不是自弹插槽,第一次用
root@myimx6ek140:~# dmesg | grep mmc0
[    1.772471] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[    1.876110] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.899113] mmc0: new high speed SDHC card at address 0001
[    1.913972] mmcblk0: mmc0:0001 SD 29.5 GiB
然后可以挂载
mount /dev/mmcblk0p1 /mnt
2019-09-07 20:20:17     打赏
好啦《MY-IMX6-EK140_Linux-4.1.15_测试手册》的内容基本过完,继续磕网卡吧
http://wiki.myzr.com.cn/index.php?title=MY-IMX6-EK140_Linux-4.1.15_%E6%B5%8B%E8%AF%95%E6%89%8B%E5%86%8C
2019-09-07 22:27:10     打赏
谢谢分享经验
2019-09-08 09:15:20     打赏
今天我也准备跑一遍这个测试手册
2021-04-11 10:22:54     打赏
试一试
2021-04-11 10:30:30     打赏
谢谢分享经验
共13条 1/2 1 2 › 跳转至页
