电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » linux看门狗使用方法
共5条 1/1 1 跳转至页
linux看门狗使用方法
2019-09-26 23:49:00     打赏
linux看门狗使用很简单,在应用层使用,只需要ioctl设置一下溢出时间,既可以使用看门狗,定时喂狗即可
前提是kernel支持看门狗
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
//watchdog
#define WATCHDOG_IOCTL_BASE     'W'
struct watchdog_info {
    unsigned int opTIons;          /* OpTIons the card/driver supports */
    unsigned int firmware_version; /* Firmware version of the card */
    char idenTIty[32];     /* IdenTIty of the board */
#define WDIOC_GETSUPPORT        _IOR(WATCHDOG_IOCTL_BASE, 0, struct watchdog_info)
#define WDIOC_GETSTATUS         _IOR(WATCHDOG_IOCTL_BASE, 1, int)
#define WDIOC_GETBOOTSTATUS     _IOR(WATCHDOG_IOCTL_BASE, 2, int)
#define WDIOC_GETTEMP           _IOR(WATCHDOG_IOCTL_BASE, 3, int)
#define WDIOC_SETOPTIONS        _IOR(WATCHDOG_IOCTL_BASE, 4, int)
#define WDIOC_KEEPALIVE         _IOR(WATCHDOG_IOCTL_BASE, 5, int)
#define WDIOC_SETTIMEOUT        _IOWR(WATCHDOG_IOCTL_BASE, 6, int)
#define WDIOC_GETTIMEOUT        _IOR(WATCHDOG_IOCTL_BASE, 7, int)
#define WDIOC_SETPRETIMEOUT     _IOWR(WATCHDOG_IOCTL_BASE, 8, int)
#define WDIOC_GETPRETIMEOUT     _IOR(WATCHDOG_IOCTL_BASE, 9, int)
#define WDIOC_GETTIMELEFT       _IOR(WATCHDOG_IOCTL_BASE, 10, int)
#define WDIOF_OVERHEAT          0x0001  /* Reset due to CPU overheat */
#define WDIOF_FANFAULT          0x0002  /* Fan failed */
#define WDIOF_EXTERN1           0x0004  /* External relay 1 */
#define WDIOF_EXTERN2           0x0008  /* External relay 2 */
#define WDIOF_POWERUNDER        0x0010  /* Power bad/power fault */
#define WDIOF_CARDRESET         0x0020  /* Card previously reset the CPU */
#define WDIOF_POWEROVER         0x0040  /* Power over voltage */
#define WDIOF_SETTIMEOUT        0x0080  /* Set timeout (in seconds) */
#define WDIOF_MAGICCLOSE        0x0100  /* Supports magic close char */
#define WDIOF_PRETIMEOUT        0x0200  /* Pretimeout (in seconds), get/set */
#define WDIOF_KEEPALIVEPING     0x8000  /* Keep alive ping reply */
#define WDIOS_DISABLECARD       0x0001  /* Turn off the watchdog timer */
#define WDIOS_ENABLECARD        0x0002  /* Turn on the watchdog timer */
#define WDIOS_TEMPPANIC         0x0004  /* Kernel panic on temperature trip */
int wdt_fd;
int time_out = 5;
void stop_signal()
    int i = 0 , ret = 0 ;
    i = WDIOS_DISABLECARD ;
    ioctl(wdt_fd, WDIOC_SETOPTIONS, &i) ;
    printf("===watchdow will be closed===\n") ;
    close(wdt_fd) ;
    exit(0) ;
int main(int argc, char *argv[])
    int new_time;
    int i;
    int ret, count = 10;
    struct watchdog_info wdt_info;
    signal(SIGINT, stop_signal) ;
    wdt_fd = open("/dev/watchdog", O_RDWR);
    if(wdt_fd == -1)
        perror("Open Watchdog ERROR!\n");
    //get watchdog infomation struct
    ioctl(wdt_fd, WDIOC_GETSUPPORT, &wdt_info);
    //printf("options=%d,id=%s\n", wdt_info.options, wdt_info.identity);
    ioctl(wdt_fd, WDIOC_SETTIMEOUT, &time_out);
    while(1)
        ioctl(wdt_fd,WDIOC_KEEPALIVE,NULL);
        sleep(atoi(argv[1]));
    close(wdt_fd);
    return 0;
2019-10-01 23:55:00     打赏
学习一下
2019-10-08 21:07:55     打赏
学到了
2019-10-10 21:45:30     打赏
2019-10-11 15:47:49     打赏
谢谢楼主分享
共5条 1/1 1 跳转至页
