电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » Python 移植教程
共5条 1/1 1 跳转至页
Python 移植教程
2019-11-02 14:13:48     打赏
Python 移植教程
  我们经常会遇到需要Python 移植的情况,但是还是有很多人对此不是十分清楚,那么就可以看看接下来的教程。
使用的源文件需要自行从网上下载。
准备文件:
Python-2.7.13.tgz
sqlite-autoconf-3200100.tar.gz
Python-2.7.13-xcompile.patch.tar.gz
步骤1、准备环境
tar xvf Python-2.7.13.tgz
tar xvf sqlite-autoconf-3200100.tar.gz
mkdir python2_7_13_for_x86_32
mkdir python2_7_13_for_arm
mkdir INSTALL
mkdir sqlite3
步骤2、安装sqlite
cd sqlite-autoconf-3200100
./configure --host=arm-arago-linux-gnueabi \
    --prefix=$PWD/../sqlite3
make
make install
步骤3、安装python2_7_13_for_x86_32
cd ../python2_7_13_for_x86_32/
sed -i 's/self.extensions.remove(ext)/print(ext.name)/g' ../Python-2.7.13/setup.py
../Python-2.7.13/configure --prefix=`pwd`
make
make install
步骤4、打补丁
cd ..
tar xvf Python-2.7.13-xcompile.patch.tar.gz -C Python-2.7.13
cd Python-2.7.13/
patch -p1 < Python-2.7.13-xcompile.patch
步骤5、配置python2_7_13_for_arm
cd ../python2_7_13_for_arm/
../Python-2.7.13/configure --prefix=`pwd` \
    --build=i686-linux-gnu \
    --enable-ipv6 \
    --enable-static \
    ac_cv_file__dev_ptmx="yes" \
    ac_cv_file__dev_ptc="no" \
    LDFLAGS="-L$PWD/../sqlite3/lib" \
    CPPFLAGS="-I$PWD/../sqlite3/include"
步骤6、编译python2_7_13_for_arm
make HOSTPYTHON=../python2_7_13_for_x86_64/python \
    HOSTPGEN=../python2_7_13_for_x86_64/Parser/pgen \
    BLDSHARED="arm-arago-linux-gnueabi-gcc -shared" \
    CROSS_COMPILE=arm-arago-linux-gnueabi- \
    CROSS_COMPILE_TARGET=yes \
    HOSTARCH=arm-arago-linux-gnueabi \
    BUILDARCH=i686-linux-gnu
步骤7、安装python2_7_13_for_arm
make install HOSTPYTHON=../python2_7_13_for_x86_64/python \
    prefix=$PWD/../INSTALL
步骤8、移植到开发板之后的配置
export PATH=/INSTALL/bin:$PATH
python python2.7-config --prefix /INSTALL
python python2.7-config --includes /INSTALL/include/
python python2.7-config --libs /INSTALL/lib/
为Python安装easy_install工具
步骤1、下载setuptools-0.6c11-py2.7.egg
wget https://pypi.python.org/packages/25/5d/cc55d39ac39383dd6e04ae80501b9af3cc455be64740ad68a4e12ec81b00/setuptools-0.6c11-py2.7.egg#md5=fe1f997bc722265116870bc7919059ea
步骤2、安装easy_install
/bin/sh setuptools-0.6c11-py2.7.egg
修改openssl.so库的版本
步骤1、下载openssl-OpenSSL_1_0_1b.zip,并解压缩
tar xvf openssl-OpenSSL_1_0_1b.zip
步骤2、
mkdir arm_install
CC=arm-arago-linux-gnueabi-gcc
./Configure linux-elf no-asm --prefix=$PWD/arm_install --openssldir=$PWD --cross-compile-prefix=arm-arago-linux-gnueabi- shared
make
make install
tar cvf arm_install.tar arm_install/
mv arm_install.tar /media/BOOT/
步骤3、在开发板上进行操作
mv /media/mmcblk1p1/arm_install.tar /
tar xvf arm_install.tar
cp -r /arm_install/lib/* /usr/lib
cp /arm_install/bin/* /usr/bin/
步骤4、取消SSL全局验证并验证easy_install
vi /INSTALL/bin/easy_install
增加
import ssl
ssl._create_default_https_context = ssl._create_unverified_context
easy_install web.py
步骤5、安装pip工具
easy_install pip
//此时使用pip工具会报SSL 认证错误,需要安装ntp网络对时
移植ntp网络对时 (335x已有不用移植)
wget http://www.eecis.udel.edu/~ntp/ntp_spool/ntp4/ntp-4.2/ntp-4.2.8p10.tar.gz
tar xvf ntp-4.2.8p10.tar.gz
cd ntp-4.2.8p10/
mkdir arm_install
./configure --prefix=$PWD/arm_install --host=arm-arago-linux-gnueabi --enable-static --with-yielding-select=yes
make
make install
./ntpdate time.buptnet.edu.cn
以上就是Python 移植到arm的教程了,希望对大家与所帮助,欢迎回帖和提问!
关键词: Python     移植
2019-11-02 15:26:05     打赏
谢谢楼主分享
2019-11-02 15:47:14     打赏
学习了
2019-11-02 16:00:45     打赏
很不错的学习资料
2019-11-02 16:18:17     打赏
收藏了  以后慢慢学习
共5条 1/1 1 跳转至页
