电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » QBD1044 datasheet 国产TJA1044 VP230 SN65HV
QBD1044 datasheet 国产TJA1044 VP230 SN65HVD230 CAN收发器芯片手册
2019-11-08 12:26:48     打赏
QBD1044(CAN2.0B CANFD)
3.3V & 5V  High-speed CAN transceiver with Standby mode
Rev. 5 — 24 August 2019 Product data sheet
1       General description
The QBD1044 is high-speed CAN transceivers It provides an interface between a Controller Area Network (CAN) protocol controller and the physical two-wire CAN bus. The transceiver is designed for high-speed CAN applications in the automotive industry, providing the differential transmit and receive capability to (a microcontroller with) a CAN protocol controller.
The QBD1044 offers a feature set optimized for 12V and 24V automotive applications, with significant improvements over Chipsmi's  first- and second-generation CAN transceivers, suchas the QBD1040, and excellent ElectroMagnetic Compatibility (EMC) performance. Additionally, the QBD1044 features:
• Ideal passive behavior to the CAN bus when the supply voltage is off
• A very low-current Standby mode with bus wake-up capability
• Excellent EMC performance at speeds up to 5Mbps even without a common mode choke
• QBD1044 can be interfaced directly to MCU with supply voltages from 3V to 5 V
• QBD1044 Can work with Power supply from 3V to 5 V
These features make the QBD1044 an excellent choice for all types of HS-CAN networks, in nodes that require a low-power mode with wake-up capability via the CAN bus.
The QBD1044 implements the CAN physical layer as defined in ISO 11898-2:2016 and SAE J2284-1 to SAE J2284-5. The QBD1044 is specified for data rates up to 5 Mbit/s. Additional timing parameters defining loop delay symmetry are specified for the other variants. This implementation enables reliable communication in the CAN FD fast phase at data rates up to 5 Mbit/s.
2      Features and benefits
2.3 General
• Fully functional compatible with the TJA1044 device and TI SN65HVD230.
• Vdd power supply compatible with 3.3 V and 5 V devices.
• Input levels compatible with 3.3 V and 5 V devices.
• Fully ISO 11898-2:2016 and SAE J2284-1 to SAE J2284-5 compliant
• Very low-current Standby mode with host and bus wake-up capability
• Optimized for use in 12 V and 24V automotive systems
• Dark green product (halogen free and Restriction of Hazardous Substances (RoHS) compliant)
• Differential receiver with wide common-mode range for high ElectroMagnetic Immunity (EMI).
• An unpowered node does not disturb the bus lines.
• Transmit Data (TXD) dominant time-out function.
• Silent mode in which the transmitter is disabled.
• Bus pins protected against transients in an automotive environment.
2.4 Predictable and fail-safe behavior
• Functional behavior predictable under all supply conditions
• Transceiver disengages from bus when not powered (zero load)
• Transmit Data (TXD) and bus dominant time-out functions
• Internal biasing of TXD and STB input pins
2.5 Protection
• High ESD handling capability on the bus pins (8 kV IEC and HBM)
• Bus pins protected against transients in automotive environments
• Thermally protected
2.6 QBD1044 CAN FD (applicable to all product variants)
• Timing guaranteed for CAN FD data rates up to 5 Mbit/s
• Improved TXD to RXD propagation delay of 210 ns
3   Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC
supply voltage
3.0
5.5
V
ICC
supply current
Standby mode; variants without a VIO pin
10
15
mA
Standby mode; variants with a VIO pin
5
mA
Normal mode; bus recessive
4
10
mA
Normal mode; bus dominant
63
80
mA
VESD
electrostatic discharge voltage
IEC 61000-4-2 at pins CANH and CANL
--8
+8
kV
TOP
Operation temperature
--40
+125
°C
4   Block diagram
5    Pinning information
 Pinning (SOP8 & DFN3X3)
Fig 2. Pin configuration diagrams
Pin description
Table 3. Pin description
Symbol
Pin
Description
TXD
1
transmit data input
GND
2
ground supply
VCC
3
supply voltage
RXD
4
receive data output; reads out data from the bus lines
n.c.
5
reserved
CANL
6
LOW-level CAN bus line
CANH
7
HIGH-level CAN bus line
SEL
8
Standby mode control input Selection
6    Functional description
– Operating modes
The QBD1044 supports two operating modes, Normal and Standby. The operating mode is selected via pin STB. See Ta ble 4 for a description of the operating modes under normal supply conditions.
Table 4. Operating modes
Mode
Inputs
Outputs
Pin STB
Pin TXD
CAN driver
Pin RXD
Normal
LOW
LOW
dominant
LOW
HIGH
recessive
LOW when bus dominant
HIGH when bus recessive
Standby
HIGH
x[1]
biased to ground
follows BUS when wake-up detected
HIGH when no wake-up detected
[1]   ‘x’ = don’t care.
• Normal mode
A LOW level on pin STB selects Normal mode. In this mode, the transceiver can transmit and receive data via the bus lines CANH and CANL (see Figure 1 for the block diagram). The differential receiver converts the analog data on the bus lines into digital data which is output on pin RXD. The slopes of the output signals on the bus lines are controlled internally and are optimized in a way that guarantees the lowest possible EME.
• Standby mode
A HIGH level on pin STB selects Standby mode. In Standby mode, the transceiver is not able to transmit or correctly receive data via the bus lines. The transmitter and
Normal-mode receiver blocks are switched off to reduce supply current, and only a low-power differential receiver monitors the bus lines for activity.
In Standby mode, the bus lines are biased to ground to minimize system supply current. The low-power receiver is supplied from VIO (VCC in non-VIO variants) and can detect CAN bus activity even if VIO is the only available supply voltage. Pin RXD follows the bus after a wake-up request has been detected. A transition to Normal mode is triggered when STB is forced LOW.
– Remote wake-up (via the CAN bus)
The QBD1044 wakes up from Standby mode when a dedicated wake-up pattern (specified in ISO 11898-2:2016) is detected on the bus. This filtering helps avoid spurious wake-up events. A spurious wake-up sequence could be triggered by, for example, a dominant clamped bus or by dominant phases due to noise or spikes on the bus.
The wake-up pattern consists of:
– a dominant phase of at least twake(busdom) followed by
– a recessive phase of at least twake(busrec) followed by
Dominant or recessive bits between the above mentioned phases that are shorter than twake(busdom) and twake(busrec) respectively are ignored.
The complete dominant-recessive-dominant pattern must be received within tto(wake)bus to be recognized as a valid wake-up pattern (see Figure 3). Otherwise, the internal wake-up logic is reset. The complete wake-up pattern will then need to be retransmitted to trigger a wake-up event. Pin RXD remains HIGH until the wake-up event has been triggered.
After a wake-up sequence has been detected, the QBD1044 will remain in Standby mode with the bus signals reflected on RXD. Note that dominant or recessive phases lasting less than tfltr(wake)bus will not be detected by the low-power differential receiver and will not be reflected on RXD in Standby mode.
A wake-up event is not flagged on RXD if any of the following events occurs while a valid wake-up pattern is being received:
– The QBD1044 switches to Normal mode
– The complete wake-up pattern was not received within tto(wake)bus
– A VCC or VIO undervoltage is detected (VCC < Vuvd(swoff)(VCC) or VIO < Vuvd(swoff)(VIO); see Section 7.3)
– Fail-safe features
• TXD dominant time-out function
A 'TXD dominant time-out' timer is started when pin TXD is set LOW. If the LOW state on this pin persists for longer than tto(dom)TXD, the transmitter is disabled, releasing the bus lines to recessive state. This function prevents a hardware and/or software application failure from driving the bus lines to a permanent dominant state (blocking all network
communications). The TXD dominant time-out timer is reset when pin TXD is set HIGH. The TXD dominant time-out time also defines the minimum possible bit rate of approximately 25 kbit/s.
Pins TXD and STB have internal pull-ups to VCC (VIO for variants with a VIO pin) to ensure a safe, defined state in case one or both of these pins are left floating. Pull-up currents flow in these pins in all states; both pins should be held HIGH in Standby mode to minimize supply current.
• Overtemperature protection
The output drivers are protected against overtemperature conditions. If the virtual junction temperature exceeds the shutdown junction temperature, Tj(sd), both output drivers are disabled. When the virtual junction temperature drops below Tj(sd) again, the output drivers recover once TXD has been reset to HIGH. Including the TXD condition prevents output driver oscillation due to small variations in temperature.
7   Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). All voltages are referenced to GND.
Symbol
Parameter
Conditions
Min
Max
Unit
V(CANH-CANL)
voltage between pin CANH and pin CANL
-27
+27
V
VESD
IEC 61000-4-2 (150 pF, 330 W) [5]
on pins CANH and CANL
-8
+8
kV
Human Body Model (HBM); 100 pF, 1.5 kW [6]
-8
+8
kV
on any other pin
-4
+4
kV
on any other pin
-500
+500
V
Tvj
-40
+150
°C
Tstg
storage temperature
-55
+150
°C
8     Static characteristics
Table 7. Static characteristics
Tvj = -40 °C to +150 °C; VCC = 3.0V to 5.5 V; RL = 60 W; CL = 100 pF unless specified otherwise; All voltages are defined with respect to ground. Positive currents flow into the IC.[2]
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Supply; pin VCC
VCC
supply voltage
3.0
5.5
V
Table 7. Static characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Standby mode control input; pin STB
VIH
HIGH-level input voltage
0.7VIO
VIO+ 0.3
V
2
VCC+ 0.3
V
VIL
LOW-level input voltage
-0.3VIO
+0.3VIO
V
-0.3
+0.8
V
IIH
HIGH-level input current
VSTB = V  [3]
IO
-1
+1
mA
IIL
LOW-level input current
VSTB = 0 V
-15
-1
mA
CAN transmit data input; pin TXD
VIH
0.7VIO
VIO+ 0.3
V
2
VCC+ 0.3
V
VIL
-0.3VIO
+0.3VIO
V
-0.3
+0.8
V
IIH
VTXD = VIO[3]
-5
+5
mA
IIL
VTXD =0 V; variants with a VIO pin
-260
-150
-60
mA
VTXD =0 V;
-260
-150
-70
mA
Ci
input capacitance
13
pF
CAN receive data output; pin RXD
IOH
HIGH-level output current
VRXD = VIO[3] - 0.4 V
-8
-3
-1
mA
IOL
LOW-level output current
VRXD = 0.4 V; bus dominant
1
12
mA
Bus lines; pins CANH and CANL
VO(dom)
dominant output voltage
VTXD =0 V; t < tto(dom)TXD
pin CANH; RL = 50 W to 65 W
2.75
3.5
4.5
V
pin CANL; RL = 50 W to 65 W
0.5
1.5
2.25
V
Vdom(TX)sym
transmitter dominant voltage symmetry
Vdom(TX)sym = VCC - VCANH - VCANL
-400
+400
mV
VTXsym
transmitter voltage symmetry
VTXsym = VCANH + VCANL; [4]
fTXD = 250 kHz, 1 MHz and 2.5 MHz;   [5]
CSPLIT = 4.7 nF
0.9VCC
1.1VCC
V
VO(dif)
differential output voltage
dominant; Normal mode; VTXD =0 V; t < tto(dom)TXD;
RL = 50 W to 65 W
1.5
3.2
4
V
RL = 45 W to 70 W
1.4
3.3
V
RL = 2240 W
1.5
5
V
recessive
Normal mode: VTXD = V  [3];
IO
no load
-50
+50
mV
Standby mode; no load
-0.2
+0.2
V
VO(rec)
recessive output voltage
Normal mode; VTXD = V ]; no load
2
2.4
3
V
-0.1
+0.1
V
9   Dynamic characteristics
Table 8. Dynamic characteristics
Tvj = -40 °C to +150 °C; VCC = 3.0V to 5.5 V;; RL = 60 W; CL = 100 pF unless specified otherwise. All voltages are defined with respect to ground.[2]
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Transceiver timing; pins CANH, CANL, TXD and RXD; see Figure 8 and Figure 4
td(TXD-busdom)
delay time from TXD to bus dominant
Normal mode
65
ns
td(TXD-busrec)
delay time from TXD to bus recessive
Normal mode
90
ns
td(busdom-RXD)
delay time from bus dominant to RXD
Normal mode
60
ns
td(busrec-RXD)
delay time from bus recessive to RXD
Normal mode
65
ns
td(TXDL-RXDL)
delay time from TXD LOW to RXD LOW
QBD1044; Normal mode
50
230
ns
all other variants; Normal mode
50
210
ns
td(TXDH-RXDH)
delay time from TXD HIGH to RXD HIGH
50
230
ns
50
210
ns
tbit(bus)
transmitted recessive bit width
QBD1044
tbit(TXD) = 500 ns [3]
435
530
ns
tbit(TXD) = 200 ns [3]
155
210
ns
tbit(RXD)
bit time on pin RXD
QBD1044
400
550
ns
120
220
ns
Dtrec
receiver timing symmetry
QBD1044
tbit(TXD) = 500 ns
-65
+40
ns
tbit(TXD) = 200 ns
-45
+15
ns
tto(dom)TXD
VTXD = 0 V; Normal mode
0.8
3
6.5
ms
td(stb-norm)
standby to normal mode delay time
1.2
5
ms
10  Application information
• Application diagram
• Application hints
Further information on the application of the QBD1044 can be found in Chipsmi application hints AH1308 Application Hints - Standalone high-speed CAN transceivers Mantis QBD1044.
11    Test information
13.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q100 Rev-G - Failure mechanism based stress test qualification for integrated circuits, and is suitable for use in automotive applications.
12    Package outline
Fig 10.  Package outline SOP (SO8)
Fig 11.  Package outline DFN3*3 package.
 13    Contact information
For more information, please email: rd1@Chipsmi.com
For sales office addresses, please send an email to: sales@Chipsmi.com
Cellphone:   86+17704036784   Mr Li    86+17704032412 Mr Tong
关键词: TJA1044     VP230     SN65HVD230
