电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » 开发STM32G0,用哪个版本的J-Link合适些?
共8条 1/1 1 跳转至页
2020-01-27 21:15:11     打赏
如题,f系列一直用jlink_ob,貌似无法用在G系列,如果用jlink,哪个版本好?V9?
关键词: STM32G0     J-Link     stm32
2020-01-27 21:31:38     打赏
我在用G0,手头直接Jlink V9可用,V8没试过。
2020-01-27 21:34:48     打赏
用标准的jlink,就是很大个头那个。
2020-01-28 20:43:18     打赏
路过,借题顺便问下大家:
我用cubemx生成嘀嗒时钟,定时器都跑不起来,是咋回事?
是还需要使能全局中断吗?
我的源码如下:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * <h2><center>&copy; Copyright (c) 2020 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_TIM3_Init(void);
static void MX_TIM16_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_SYSCFG);
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_PWR);
  /* System interrupt init*/
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
    NVIC_SetPriority(SysTick_IRQn, 2);
  NVIC_EnableIRQ(SysTick_IRQn);
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_TIM3_Init();
  MX_TIM16_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  /* HSE configuration and activation */
  LL_RCC_HSE_Enable();
  while(LL_RCC_HSE_IsReady() != 1)
  /* Main PLL configuration and activation */
  LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_HSE, LL_RCC_PLLM_DIV_2, 12, LL_RCC_PLLR_DIV_4);
  LL_RCC_PLL_Enable();
  LL_RCC_PLL_EnableDomain_SYS();
  while(LL_RCC_PLL_IsReady() != 1)
  /* Set AHB prescaler*/
  LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
  /* Sysclk activation on the main PLL */
  LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_PLL);
  while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_PLL)
  /* Set APB1 prescaler*/
  LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_1);
  LL_Init1msTick(24000000);
  LL_SYSTICK_SetClkSource(LL_SYSTICK_CLKSOURCE_HCLK);
  LL_SetSystemCoreClock(24000000);
  /* Update CMSIS variable (which can be updated also through SystemCoreClockUpdate function) */
  * @brief TIM3 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN TIM3_Init 0 */
  /* USER CODE END TIM3_Init 0 */
  LL_TIM_InitTypeDef TIM_InitStruct = {0};
  LL_TIM_OC_InitTypeDef TIM_OC_InitStruct = {0};
  LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* Peripheral clock enable */
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_TIM3);
  /* TIM3 interrupt Init */
  NVIC_SetPriority(TIM3_IRQn, 0);
  NVIC_EnableIRQ(TIM3_IRQn);
  /* USER CODE BEGIN TIM3_Init 1 */
  /* USER CODE END TIM3_Init 1 */
  TIM_InitStruct.Prescaler = 0;
  TIM_InitStruct.CounterMode = LL_TIM_COUNTERMODE_UP;
  TIM_InitStruct.Autoreload = 0;
  TIM_InitStruct.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
  LL_TIM_Init(TIM3, &TIM_InitStruct);
  LL_TIM_DisableARRPreload(TIM3);
  TIM_OC_InitStruct.OCMode = LL_TIM_OCMODE_FROZEN;
  TIM_OC_InitStruct.OCState = LL_TIM_OCSTATE_DISABLE;
  TIM_OC_InitStruct.OCNState = LL_TIM_OCSTATE_DISABLE;
  TIM_OC_InitStruct.CompareValue = 0;
  TIM_OC_InitStruct.OCPolarity = LL_TIM_OCPOLARITY_HIGH;
  LL_TIM_OC_Init(TIM3, LL_TIM_CHANNEL_CH3, &TIM_OC_InitStruct);
  LL_TIM_OC_DisableFast(TIM3, LL_TIM_CHANNEL_CH3);
  LL_TIM_SetTriggerOutput(TIM3, LL_TIM_TRGO_RESET);
  LL_TIM_DisableMasterSlaveMode(TIM3);
  /* USER CODE BEGIN TIM3_Init 2 */
  /* USER CODE END TIM3_Init 2 */
  LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOB);
  /**TIM3 GPIO Configuration
  PB0   ------> TIM3_CH3
  GPIO_InitStruct.Pin = LL_GPIO_PIN_0;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
  GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_LOW;
  GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
  GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
  GPIO_InitStruct.Alternate = LL_GPIO_AF_1;
  LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  * @brief TIM16 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN TIM16_Init 0 */
  /* USER CODE END TIM16_Init 0 */
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_TIM16);
  /* TIM16 interrupt Init */
  NVIC_SetPriority(TIM16_IRQn, 0);
  NVIC_EnableIRQ(TIM16_IRQn);
  /* USER CODE BEGIN TIM16_Init 1 */
  /* USER CODE END TIM16_Init 1 */
  TIM_InitStruct.Autoreload = 0xFFFF;
  TIM_InitStruct.RepetitionCounter = 0;
  LL_TIM_Init(TIM16, &TIM_InitStruct);
  LL_TIM_DisableARRPreload(TIM16);
  /* USER CODE BEGIN TIM16_Init 2 */
LL_TIM_EnableCounter(TIM16);
  /* USER CODE END TIM16_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  LL_EXTI_InitTypeDef EXTI_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOF);
  LL_EXTI_SetEXTISource(LL_EXTI_CONFIG_PORTB, LL_EXTI_CONFIG_LINE1);
  EXTI_InitStruct.Line_0_31 = LL_EXTI_LINE_1;
  EXTI_InitStruct.LineCommand = ENABLE;
  EXTI_InitStruct.Mode = LL_EXTI_MODE_IT;
  EXTI_InitStruct.Trigger = LL_EXTI_TRIGGER_RISING;
  LL_EXTI_Init(&EXTI_InitStruct);
  LL_GPIO_SetPinPull(GPIOB, LL_GPIO_PIN_1, LL_GPIO_PULL_NO);
  LL_GPIO_SetPinMode(GPIOB, LL_GPIO_PIN_1, LL_GPIO_MODE_INPUT);
  /* EXTI interrupt init*/
  NVIC_SetPriority(EXTI0_1_IRQn, 0);
  NVIC_EnableIRQ(EXTI0_1_IRQn);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
2020-01-30 14:01:22     打赏
V9很不错的
2020-01-31 19:47:26     打赏
用最新版本,不香吗?
2020-01-31 19:57:05     打赏
建议看官方的文档和意见呗! 我个人觉得V8或V8版本以上即可
2020-02-10 21:23:56     打赏
有问题就看官方 的文档 比较靠谱一点
共8条 1/1 1 跳转至页
