The MST40N05 uses advanced trench technology and design excellent RDS(ON) with low gate charge.
(40N05采用先进的沟槽技术和设计优良的RDS(ON)低压充电)
It can be used in a wide variety of applications.
它可以用于各种各样的应用)
特点:
BADS>=43V
High density cell for Ultra low on-resistance(高密度电池,超低导通电阻)
Rds(ON)<30mΩ @ VGS=10V
Rds(ON)<40mΩ @VGS=4.5V
Fully characterized avalanche voltage and current
Excellent package for good heat dissipation and tiny solution size (封装完美,散热性好,体积小)
175℃ operating temperature(175℃承受温度)
应用:
load switching
hard switched and high frequency circuits
DC-DC Convertor
Others
