电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 郁闷啊!protues中AT89C52无法点亮LCD1602
共6条 1/1 1 跳转至页
2020-08-30 11:26:36     打赏
郁闷啊!protues中AT89C52无法点亮LCD1602,以下分别是我的电路图和源码,大家有空帮我看看,谢谢咯!
#include<reg51.h>
#define uint signed int
#define uchar signed char
 uchar aa[]={"current voiltage :"};
 sbit lcden = P3^4;
 sbit lcdrs = P3^5;
 sbit START = P2^0;
 sbit CLK = P2^1;
 sbit EOC = P2^2;
 sbit OE = P2^3;
 sbit AA = P2^4;
 sbit BB = P2^5;
 sbit CC = P2^6;
 float v;
 void delay(uint ms)   //延时函数
  uchar i;
  while(ms--);
   for(i<0;i<120;i++);
 void write_com(uchar com)    //写命令函数
  lcdrs=0;
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
 void write_data(uchar date)   //写数据函数
  lcdrs=1;
  P0=date;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
 void LCD1602_init()   //1602初始化函数
  lcden=0;
  write_com(0x38);
  write_com(0x0C);
  write_com(0x01);
 void display (int v)
  int shu,i;
  write_com(0x80);
  for(i=0;i<16;i++)
    write_data(aa[i]);
  write_com(0x80+0x46);
   shu=v/100;
   write_data(shu+'0');
   delay(5);
   write_data('.');
   delay(5);
    shu=v%100/10;
    delay(5);
    delay(5);
     shu=v%10;
     delay(5);
     write_data('V');
 void main()
  LCD1602_init();
  TMOD=0x02;
  TH0=0x14;
  TL0=0X14;
  IE=0X82;
  TR0=1;
  P2=0x0f;  //选用通道0,CLK=1,START=1,EOC=1,OE=1.
  while(1)
   START=0;
   START=1;
   START=0;
   while(EOC=0);
   OE=1;
   v=P1*1.0/255*500;
   display(v);
   OE=0;
 void Timer0() interrupt 1
  CLK=!CLK;
关键词: LCD1602     AT89C52     protues
2020-08-30 11:36:22     打赏
显示函数没的问题 就是“v=P1*1.0/255*500”;如果把P1改成255 就可以正确显示5.00V
2020-08-30 11:40:43     打赏
 主函数中 WHILE(EOC==0)这里少打个=
2020-08-30 11:45:13     打赏
建议 LCD接口的RW 用单片机的IO来控制,而不是一直接低电平
2020-08-30 14:58:18     打赏
多检查检查
2020-09-02 22:03:13     打赏
共6条 1/1 1 跳转至页
