ccppc -c -g -mcpu=405 -mstrict-align -ansi -fno-builtin -P -xassembler-with-cpp -I.. -IC:\ Tornado2.2\target\config\ML300seg -IC:\Tornado2.2\target\h -IC:\Tornado2.2\target\config\c omps\src -IC:\Tornado2.2\target\src\drv -DCPU=PPC405 -DTOOL_FAMILY=gnu -DTOOL=gnu -DPRJ_BU ILD -IC:\Tornado2.2\target\config\ML300seg\ip_csp\xsrc -DXENV_VXWORKS -g -Wall -O2 -fvolat ile -DROM_COMPRESS -DRAM_DATA_ADRS=0x00C00000 -DRAM_DST_ADRS=0x00010000 C:\Tornado2.2\ta rget\config\ML300seg\romInit.s -o romInit.o \cygdrive\c\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccMEPKWh.s: Assembler messages: \cygdrive\c\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccMEPKWh.s:1876: Error: alignment padding (11 bytes) not a multiple of 4 \cygdrive\c\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccMEPKWh.s:1876: Error: ignoring least signifi cant bits in branch offset \cygdrive\c\DOCUME~1\ADMINI~1\LOCALS~1\Temp\ccMEPKWh.s:1876: Error: ignoring least signifi cant bits in branch offset make: *** [romInit.o] Error 0x1
各位大侠帮我看看是什么问题哦
