LCB3399Pro基于瑞芯微RK3399Pro芯片平台精心设计的一款全功能核心模块,尺寸仅有75mm*55mm。核心模块与底板的连接采用两颗tyco/AMP的0.8mm pitch双排140Pin板对板连接器,并通过4颗M3的螺丝固定,稳定可靠、易于安装和维护。
Function | Description |
CPU | RK3399Pro, Big.Little architecture: Dual Cortex-A72 + Quad Cortex-A53, 64-bit CPU,Frequency is up to 1.8GHz |
GPU | Mali-T860MP4 GPU, OpenGL ES1.1/2.0/3.0/3.1, OpenVG1.1, OpenCL, DX11 |
NPU | NPU up to 3.0TOPS,Support 8-bit/16-bit Inference,Support TensorFlow/Caffe Model |
DDR | LPDDR3, 3GB/6GB (Optional) |
eMMC | eMMC 5.1, 8GB/16GB/32GB/64GB/128GB(Optional) |
PMU | RK809,Support a variety of power supply |
Camera Interface | Two ISP built-in Dual MIPI-CSI 4 Lane of 1.5 Gbps/Lane ITU-R BT 601/656 compliant Maximum input resolution of one ISP is 14M pixels |
Display Interface | Two VOP embedded Dual MIPI-DSI 4 Lane of 1.5 Gbps/Lane up to 2560x1600@60fps eDP1.3 4 Lane of 2.7/1.62 Gbps/lane DP1.2 4 Lane with HDCP2.2 up to 4kx2k at 60Hz resolution HDMI2.0 3 Lane with HDCP2.2 |
USB Interface | OTG*1,HOST*2,TYPE-C*2 |
TYPE-C Interface | Dual Type-C PHY with Type-C V1.1 and USB PD2.0 Attach/detach detection and signaling as DFP, UFP and DRP Support USB3.0 Type-C and DisplayPort 1.2 Alt Mode Up to 5Gbps data rate for USB3.0 Up to 5.4Gbps (HBR2) data rate for DP1.2 |
Audio Interface | Three I2S/PCM built-in SPDIF supported Audio resolution from 16bits to 32bits Sample rate up to 192KHz Provides master and slave work mode, software configurable Support 3 I2S formats (normal, left-justified, right-justified) Support 4 PCM formats (early, late1, late2, late3) Support two 16-bit audio data store together in one 32-bit wide location Support 16, 20, 24 bits audio data transfer in linear PCM mode |
Connectivity | Compatible with SDIO 3.0 protocol GMAC 10/100/1000M Ethernet Controller Six on-chip SPI controllers Five on-chip UART controllers inside Nine on-chip I2C controllers Five groups of GPIO (GPIO0~GPIO4), totally have 122 GPIOs One PCIe port compatible with PCI Express V2.1 and dual operation mode (RC and EP) Six-channel single-ended 10-bit SAR-ADC up to 1MS/s sampling rate |
OS | Android / ubuntu / Buildroot |
PCB interface | B2B,280 Pin |
PCB size | L* W* H(mm) : 75 * 55 *7.8(PCB 1.2mm) |
