电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » PHP开发中使用smtp类轻松的发送电子邮件(源码)
2020-11-04 10:34:44     打赏
  在现如今,作为PHP网站开发程序员需要接触到各种程序接口,比如网站修改密码使用smtp类轻松的发送电子邮件,首先smtp类发送邮件的方法其实很简单,也很稳定,类是别人已经写好的了,你只需要调用就行了。几行简单的配置就能发邮件,下面我们一起来看一下吧。
  email.class.php文件
  classsmtp
  /*PublicVariables*/
  var$smtp_port;
  var$time_out;
  var$host_name;
  var$log_file;
  var$relay_host;
  var$debug;
  var$auth;
  var$user;
  var$pass;
  /*PrivateVariables*/
  var$sock;
  /*Constractor*/
  functionsmtp($relay_host="",$smtp_port=25,$auth=false,$user,$pass)
  $this->debug=FALSE;
  $this->smtp_port=$smtp_port;
  $this->relay_host=$relay_host;
  $this->time_out=30;//isusedinfsockopen()
  $this->auth=$auth;//auth
  $this->user=$user;
  $this->pass=$pass;
  $this->host_name="localhost";//isusedinHELOcommand
  $this->log_file="";
  $this->sock=FALSE;
  /*MainFunction*/
  functionsendmail($to,$from,$subject="",$body="",$mailtype,$cc="",$bcc="",$additional_headers="")
  $mail_from=$this->get_address($this->strip_comment($from));
  $body=ereg_replace("(^|(rn))(.)","1.3",$body);
  $header="MIME-Version:1.0rn";
  if($mailtype=="HTML"){
  $header.="Content-Type:text/htmlrn";
  $header.="To:".$to."rn";
  if($cc!=""){
  $header.="Cc:".$cc."rn";
  $header.="From:$from<".$from.">rn";
  $header.="Subject:".$subject."rn";
  $header.=$additional_headers;
  $header.="Date:".date("r")."rn";
  $header.="X-Mailer:ByRedhat(PHP/".phpversion().")rn";
  list($msec,$sec)=explode("",microtime());
  $header.="Message-ID:<".date("YmdHis",$sec).".".($msec*1000000).".".$mail_from.">rn";
  $TO=explode(",",$this->strip_comment($to));
  if($cc!=""){
  $TO=array_merge($TO,explode(",",$this->strip_comment($cc)));
  if($bcc!=""){
  $TO=array_merge($TO,explode(",",$this->strip_comment($bcc)));
  $sent=TRUE;
  foreach($TOas$rcpt_to){
  $rcpt_to=$this->get_address($rcpt_to);
  if(!$this->smtp_sockopen($rcpt_to)){
  $this->log_write("Error:Cannotsendemailto".$rcpt_to."n");
  $sent=FALSE;
  continue;
  if($this->smtp_send($this->host_name,$mail_from,$rcpt_to,$header,$body)){
  $this->log_write("E-mailhasbeensentto<".$rcpt_to.">n");
  }else{
  $this->log_write("Error:Cannotsendemailto<".$rcpt_to.">n");
  $sent=FALSE;
  fclose($this->sock);
  $this->log_write("Disconnectedfromremotehostn");
  return$sent;
  /*PrivateFunctions*/
  functionsmtp_send($helo,$from,$to,$header,$body="")
  if(!$this->smtp_putcmd("HELO",$helo)){
  return$this->smtp_error("sendingHELOcommand");
  #auth
  if($this->auth){
  if(!$this->smtp_putcmd("AUTHLOGIN",base64_encode($this->user))){
  if(!$this->smtp_putcmd("",base64_encode($this->pass))){
  if(!$this->smtp_putcmd("MAIL","FROM:<".$from.">")){
  return$this->smtp_error("sendingMAILFROMcommand");
  if(!$this->smtp_putcmd("RCPT","TO:<".$to.">")){
  return$this->smtp_error("sendingRCPTTOcommand");
  if(!$this->smtp_putcmd("DATA")){
  return$this->smtp_error("sendingDATAcommand");
  if(!$this->smtp_message($header,$body)){
  return$this->smtp_error("sendingmessage");
  if(!$this->smtp_eom()){
  return$this->smtp_error("sending.[EOM]");
  if(!$this->smtp_putcmd("QUIT")){
  return$this->smtp_error("sendingQUITcommand");
  returnTRUE;
  functionsmtp_sockopen($address)
  if($this->relay_host==""){
  return$this->smtp_sockopen_mx($address);
  }else{
  return$this->smtp_sockopen_relay();
  functionsmtp_sockopen_relay()
  $this->log_write("Tryingto".$this->relay_host.":".$this->smtp_port."n");
  $this->sock=@fsockopen($this->relay_host,$this->smtp_port,$errno,$errstr,$this->time_out);
  if(!($this->sock&&$this->smtp_ok())){
  $this->log_write("Error:Cannotconnencttorelayhost".$this->relay_host."n");
  $this->log_write("Error:".$errstr."(".$errno.")n");
  returnFALSE;
  $this->log_write("Connectedtorelayhost".$this->relay_host."n");
  returnTRUE;;
  functionsmtp_sockopen_mx($address)
  $domain=ereg_replace("^.+@([^@]+)$","1",$address);
  if(!@getmxrr($domain,$MXHOSTS)){
  $this->log_write("Error:CannotresolveMX"".$domain.""n");
  returnFALSE;
  foreach($MXHOSTSas$host){
  $this->log_write("Tryingto".$host.":".$this->smtp_port."n");
  $this->sock=@fsockopen($host,$this->smtp_port,$errno,$errstr,$this->time_out);
  $this->log_write("Warning:Cannotconnecttomxhost".$host."n");
  continue;
  $this->log_write("Connectedtomxhost".$host."n");
  returnTRUE;
  $this->log_write("Error:Cannotconnecttoanymxhosts(".implode(",",$MXHOSTS).")n");
  returnFALSE;
  functionsmtp_message($header,$body)
  fputs($this->sock,$header."rn".$body);
  $this->smtp_debug(">".str_replace("rn","n".">",$header."n>".$body."n>"));
  returnTRUE;
  functionsmtp_eom()
  fputs($this->sock,"rn.rn");
  $this->smtp_debug(".[EOM]n");
  return$this->smtp_ok();
  functionsmtp_ok()
  $response=str_replace("rn","",fgets($this->sock,512));
  $this->smtp_debug($response."n");
  if(!ereg("^[23]",$response)){
  fputs($this->sock,"QUITrn");
  fgets($this->sock,512);
  $this->log_write("Error:Remotehostreturned"".$response.""n");
  returnFALSE;
  returnTRUE;
  functionsmtp_putcmd($cmd,$arg="")
  if($arg!=""){
  if($cmd=="")$cmd=$arg;
  else$cmd=$cmd."".$arg;
  fputs($this->sock,$cmd."rn");
  $this->smtp_debug(">".$cmd."n");
  functionsmtp_error($string)
  $this->log_write("Error:Erroroccurredwhile".$string.".n");
  returnFALSE;
  functionlog_write($message)
  $this->smtp_debug($message);
  if($this->log_file==""){
  returnTRUE;
  $message=date("MdH:i:s").get_current_user()."[".getmypid()."]:".$message;
  if(!@file_exists($this->log_file)||!($fp=@fopen($this->log_file,"a"))){
  $this->smtp_debug("Warning:Cannotopenlogfile"".$this->log_file.""n");
  returnFALSE;;
  flock($fp,LOCK_EX);
  fputs($fp,$message);
  fclose($fp);
  returnTRUE;
  functionstrip_comment($address)
  $comment="([^()]*)";
  while(ereg($comment,$address)){
  $address=ereg_replace($comment,"",$address);
  return$address;
  functionget_address($address)
  $address=ereg_replace("([trn])+","",$address);
  $address=ereg_replace("^.*<(.+)>.*$","1",$address);
  return$address;
  functionsmtp_debug($message)
  if($this->debug){
  echo$message;
  发送邮箱的php文件
  require_once"email.class.php";
  //********************配置信息********************************
  $smtpserver="smtp.XX.com";//SMTP服务器
  $smtpserverport=25;//SMTP服务器端口
  $smtpusermail="new2018oh@XX.com";//SMTP服务器的用户邮箱
  $smtpemailto=$_POST['toemail'];//发送给谁
  $smtpuser="new2018oh";//SMTP服务器的用户帐号
  $smtppass="您的邮箱密码";//SMTP服务器的用户密码
  $mailtitle=$_POST['title'];//邮件主题
  $mailcontent="
  ".$_POST['content']."
  ";//邮件内容
  $mailtype="HTML";//邮件格式(HTML/TXT),TXT为文本邮件
  //************************配置信息****************************
  $smtp=newsmtp($smtpserver,$smtpserverport,true,$smtpuser,$smtppass);//这里面的一个true是表示使用身份验证,否则不使用身份验证.
  $smtp->debug=false;//是否显示发送的调试信息
  $state=$smtp->sendmail($smtpemailto,$smtpusermail,$mailtitle,$mailcontent,$mailtype);
  echo"
  if($state==""){
  echo"对不起,邮件发送失败!请检查邮箱填写是否有误。";
  echo"点此返回";
  exit();
  echo"恭喜!邮件发送成功!!";
  echo"点此返回";
  echo"";
  最后还有smtp类无法发送邮件解决方法:
  偶然发现网站后台自动发送邮件功能不能用了,报这个错误:
  Tryingtosmtp.XX.com:25Error:Cannotconnencttorelayhostsmtp.XX.comError:()Error:Cannotsendemailtoweb@daixiaorui.comstate
  大概意思是:无法connenct中继主机smtp.XX.com错误:()错误:无法发送电子邮件
  找了很多资料后终于找到了解决方案,不是smtp类的问题,而就是linux配置的问题。原来是服务器的php.ini禁用了fsockopen函数。
  打开空间下的php.ini文件,linux空间一般都可以自定义php.ini,所以根目录下面一般会有这个文件。
  有两个地方可能禁用此函数:
  1.allow_url_fopen=On查看等于后面是否为ON,如果为OFF时函数将被禁用
  2.disable_functions=fsockopenpfsockopen(我的就是这样)这里应该去掉前面的“fsockopen”。使之变成:disable_functions=pfsockopen
  以上就是关于扣丁学堂php利用smtp类轻松的发送电子邮件的详细介绍最后想要了解更多关于PHP开发发展前景趋势,请关注扣丁学堂官网、微信等平台,扣丁学堂PHP培训IT职业在线学习教育平台为您提供权威的PHP视频教程系统,通过千锋扣丁学堂金牌讲师在线录制的一套PHP视频教程课程,让你快速掌握PHP从入门到精通开发实战技能。扣丁学堂PHP技术交流群:374332265。
