金属探测器? 大家估计会喜欢吧?!
如下是电路图和源码,大家可以按此制作DIY
BOM清单:
R1 = 330 Ω, resistor
R2 = 1 KΩ, resistor
C1 = 10nF, ceramic capacitor
D1 = 1N4148, diode
BUZ1 = Buzzer
LED1 = 5mm any color LED
Arduino UNO Board or equivalent
成品图:
#define vinPin A5
#define buz 9
#define pulsePin A4
#define led 10
long sumExpect=0; //running sum of 64 sums
long ignor=0; //number of ignored sums
long diff=0; //difference between sum and avgsum
long pTime=0;
long buzPeriod=0;
void setup()
Serial.begin(9600);
pinMode(pulsePin, OUTPUT);
digitalWrite(pulsePin, LOW);
pinMode(vinPin, INPUT);
pinMode(buz, OUTPUT);
digitalWrite(buz, LOW);
pinMode(led, OUTPUT);
void loop()
int minval=1023;
int maxval=0;
long unsigned int sum=0;
for (int i=0; i<256; i++)
//reset the capacitor
pinMode(vinPin,OUTPUT);
digitalWrite(vinPin,LOW);
delayMicroseconds(20);
pinMode(vinPin,INPUT);
applyPulses();
//read the charge of capacitor
int val = analogRead(vinPin); //takes 13x8=104 microseconds
minval = min(val,minval);
maxval = max(val,maxval);
sum+=val;
long unsigned int cTime=millis();
char buzState=0;
if (cTime<pTime+10)
if (diff>0)
buzState=1;
else if(diff<0)
buzState=2;
if (cTime>pTime+buzPeriod)
if (diff>0)
buzState=1;
else if (diff<0)
buzState=2;
pTime=cTime;
if (buzPeriod>300)
buzState=0;
if (buzState==0)
digitalWrite(led, LOW);
noTone(buz);
else if (buzState==1)
tone(buz,2000);
digitalWrite(led, HIGH);
else if (buzState==2)
tone(buz,500);
//subtract minimum and maximum value to remove spikes
sum-=minval;
sum-=maxval;
if (sumExpect==0)
sumExpect=sum<<6; //set sumExpect to expected value
long int avgsum=(sumExpect+32)>>6;
diff=sum-avgsum;
if (abs(diff)<avgsum>>10)
sumExpect=sumExpect+sum-avgsum;
ignor=0;
else
ignor++;
if (ignor>64)
sumExpect=sum<<6;
ignor=0;
if (diff==0)
buzPeriod=1000000;
else
buzPeriod=avgsum/(2*abs(diff));
void applyPulses()
for (int i=0;i<3;i++)
digitalWrite(pulsePin,HIGH); //take 3.5 uS
delayMicroseconds(3);
digitalWrite(pulsePin,LOW); //take 3.5 uS
