电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » STM32驱动铂电阻温度检测器MAX31865的读写程序
共10条 1/1 1 跳转至页
2021-01-05 20:30:24     打赏
MAX31865是一款RTD铂电阻至数字转换器,支持100Ω至1kΩ (0°C时)铂电阻RTD (PT100至PT1000)。
STM32读写MAX31865的源码程序如下,希望对大家有帮助!
#define IO_GLOBAL
#include "io.h"
#include "main.h"
* @brief        MAX31865芯片所用单片机引脚的初始化
* @param
* @param
* @retval
static void MAX31865_Port_Init(void)
    GPIO_InitTypeDef GPIO_InitStruct;
  /*##-1- Enable peripherals and GPIO Cloc #########################*/
  /* Enable GPIO TX/RX clock */
    __HAL_RCC_GPIOF_CLK_ENABLE();
  /* SPI SCK GPIO pin configuration********  PG1  */
  GPIO_InitStruct.Pin       = GPIO_PIN_8;      //哪个引脚
  GPIO_InitStruct.Mode      = GPIO_MODE_OUTPUT_PP;  //输出
  GPIO_InitStruct.Speed     = GPIO_SPEED_FREQ_HIGH; //速度选最快的
  HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  /* SPI MISO GPIO pin configuration****** PF15 */
  GPIO_InitStruct.Pin = GPIO_PIN_6;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  /* SPI MOSI GPIO pin configuration**** PF13  */
  GPIO_InitStruct.Pin = GPIO_PIN_4;
  /* SPI cs GPIO pin configuration**** PF11  */
  GPIO_InitStruct.Pin = GPIO_PIN_2;
    /*  re GPIO pin configuration****** PB1 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
   NCS_H;
   SCLK_H;
* @brief        IO资源引脚的初始化
* @param
* @param
* @retval
void ConfigurePortPins(void)
    MAX31865_Port_Init();
#define  DT_NUM    0x30  //延时时间
* @brief        简单粗暴的延时函数
* @param
* @param
* @retval
void Delay(u32 nCount)
  for(; nCount != 0; nCount--);
* @brief        读max31865的寄存器
* @param        地址
* @param
* @retval
u8 MAX31865_SB_Read(u8 addr)//SPI Single-Byte Read
  u8 i=0;
  u8 read = 0;
  NCS_L;
  Delay(DT_NUM);
  for(i = 0; i < 8; i++)
    SCLK_L;
    if (addr & 0x80)
        {SDI_H;}
    else
        {SDI_L;}
    Delay(DT_NUM);
    SCLK_H;
    addr <<= 1;
    Delay(DT_NUM);
  Delay(DT_NUM);
  for (i = 0; i < 8; i++)
    SCLK_L;
    read = read<<1;
    Delay(DT_NUM);
    if(SDO)
      read++;
    SCLK_H;
    Delay(DT_NUM);
  NCS_H;
  return read;
* @brief        写max31865的寄存器
* @param        地址
* @param        数据
* @retval
void MAX31865_SB_Write(u8 addr,u8 wdata)//SPI Single-Byte Write
  u8 i = 0;
  NCS_L;                          //拉低片选信号
  Delay(DT_NUM);          //粗暴延时
  //写地址
  for(i = 0; i < 8; i++)  //0-7
    SCLK_L;                                  //时钟线拉高
    if (addr & 0x80)      // xxxx xxxx  & 1000 0000   addr最高位是否为1简单判断
        {SDI_H;}                  // 为1 发送高电平
    else
        {SDI_L;}                          //为0 发送低电平
    SCLK_H;               //时钟线拉低
    addr <<= 1;           //数据左移 判断次高位
  //写数据
    SCLK_L;
    if (wdata & 0x80)
        {SDI_H;}
    else {SDI_L;}
    Delay(DT_NUM);
    SCLK_H;
    wdata <<= 1;
    Delay(DT_NUM);
  //操作完成拉高片选
  NCS_H;
* @brief        简单滤波计算温度值
* @param
* @param
* @retval   扩大100倍的温度
u8 temp1;
u8 temp2;
float Get_tempture(void)//PT100
  float temps;
  u16 dtemp[2];
  u16 data_temp;
  u8 i;
  static u8 cnt_num =0;
  static u16 temp1_num[8];
  static u32 temp1_sum;
  static u16 temp1_min =0;
  static u16 temp1_max =0;
  dtemp[0]=MAX31865_SB_Read(0x01);//读RTD_MSB
  dtemp[1]=MAX31865_SB_Read(0x02);//读RTD_LSB
  data_temp=(dtemp[0]<<7)+(dtemp[1]>>1);//Get 15Bit DATA;
  temp1=dtemp[0];
  temp2=dtemp[1];
  temp1_ad = data_temp;
    if(cnt_num<8)cnt_num++;
    else cnt_num=0;
    temp1_num[cnt_num] = data_temp;
        temp1_min = temp1_num[cnt_num];
          temp1_max = temp1_num[cnt_num];
          if(power_time < 10) return 0;
          for (i=0,temp1_sum=0; i<8; i++)
                 temp1_sum += temp1_num[i];
                 if (temp1_num[i]<=temp1_min) temp1_min = temp1_num[i];
                 if (temp1_num[i]>=temp1_max) temp1_max = temp1_num[i];
          temp1_sum -= temp1_min;
          temp1_sum -= temp1_max;
    temps = temp1_sum/6;
    temps=(temps*402)/32768;//Here is the rtd R value;
    temps=(temps-100)*100/0.385055;//A gruad 本身值经扩大100倍单位为1摄氏度
    return temps;
* @brief        得到PT100温度值
* @param
* @param
* @retval
void  GetPT100_Temp(void)
        u8 i;
        static float temp1_num[64];
        static float temp1_sum;
        static float temp1_min =0;
        static float temp1_max =0;
    if(cnt_num<64)cnt_num++;
    else cnt_num=0;
    temp1_num[cnt_num] = Get_tempture();
          if(power_time < 10) return;
          for (i=0,temp1_sum=0; i<64; i++)
    tempture = temp1_sum/62;
    Fault_Status=MAX31865_SB_Read(0x07);//Get Fault_Status
* @brief        读取IO资源
* @param
* @param
* @retval
关键词: MAX31865     铂电阻
2021-01-05 20:45:30     打赏
模拟的SPI接口时序,为何不用硬件SPI来读写呢?
2021-01-05 20:49:56     打赏
不错!正好需要
2021-01-05 20:54:31     打赏
maxim 出品的IC确实很棒! 用这个做接口方便铂电阻温度探测线性化多了!
2021-01-05 21:29:14     打赏
程序写的蛮好的
2021-01-05 22:59:40     打赏
挺不错的机器
2021-01-12 23:45:21     打赏
2021-05-20 08:50:56     打赏
我发现这代码跟我在阿莫电子论坛上分享的一样
2021-05-20 08:57:20     打赏
学习
2021-05-20 08:58:01     打赏
收藏一下
共10条 1/1 1 跳转至页
