电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » Tensorflow中的tf.train.batch函数的使用
共4条 1/1 1 跳转至页
2021-01-06 18:24:14     打赏
tensorflow中的读取数据的队列,不论是对正喜欢Python开发的人来说,还是对已经走入工作中的Python开发工程师来说都是比较难懂的。原因可能之大家对这方面的经验不足吧。下面扣丁学堂Python培训小编就和大家分享一下关于Tensorflow中的tf.train.batch函数的使用。
扣丁学堂Python培训告诉你关于Tensorflow中的tf.train.batch函数的使用
tensorflow中的读取数据的队列,简单的说,就是计算图是从一个管道中读取数据的,录入管道是用的现成的方法,读取也是。为了保证多线程的时候从一个管道读取数据不会乱吧,所以这种时候读取的时候需要线程管理的相关操作。今天给大家分享一个简单的操作,就是给一个有序的数据,看看读出来是不是有序的,结果发现是有序的,所以直接给代码:
import tensorflow as tf
import numpy as np
def generate_data():
  num = 25
  label = np.asarray(range(0, num))
  images = np.random.random([num, 5, 5, 3])
  print('label size :{}, image size {}'.format(label.shape, images.shape))
  return label, images
def get_batch_data():
  label, images = generate_data()
  images = tf.cast(images, tf.float32)
  label = tf.cast(label, tf.int32)
  input_queue = tf.train.slice_input_producer([images, label], shuffle=False)
  image_batch, label_batch = tf.train.batch(input_queue, batch_size=10, num_threads=1, capacity=64)
  return image_batch, label_batch
image_batch, label_batch = get_batch_data()
with tf.Session() as sess:
  coord = tf.train.Coordinator()
  threads = tf.train.start_queue_runners(sess, coord)
  i = 0
  try:
    while not coord.should_stop():
      image_batch_v, label_batch_v = sess.run([image_batch, label_batch])
      i += 1
      for j in range(10):
        print(image_batch_v.shape, label_batch_v[j])
  except tf.errors.OutOfRangeError:
    print("done")
  finally:
    coord.request_stop()
  coord.join(threads)
记得那个slice_input_producer方法,默认是要shuffle的哈。
Besides, I would like to comment this code.
1: there is a parameter ‘num_epochs' in slice_input_producer, which controls how many epochs the slice_input_producer method would work. when this method runs the specified epochs, it would report the OutOfRangeRrror. I think it would be useful for our control the training epochs.
2: the output of this method is one single image, we could operate this single image with tensorflow API, such as normalization, crops, and so on, then this single image is feed to batch method, a batch of images for training or testing wouldbe received.
tf.train.batch和tf.train.shuffle_batch的区别用法
tf.train.batch([example, label], batch_size=batch_size, capacity=capacity):[example, label]表示样本和样本标签,这个可以是一个样本和一个样本标签,batch_size是返回的一个batch样本集的样本个数。capacity是队列中的容量。这主要是按顺序组合成一个batch
tf.train.shuffle_batch([example, label], batch_size=batch_size, capacity=capacity, min_after_dequeue)。这里面的参数和上面的一样的意思。不一样的是这个参数min_after_dequeue,一定要保证这参数小于capacity参数的值,否则会出错。这个代表队列中的元素大于它的时候就输出乱的顺序的batch。也就是说这个函数的输出结果是一个乱序的样本排列的batch,不是按照顺序排列的。
上面的函数返回值都是一个batch的样本和样本标签,只是一个是按照顺序,另外一个是随机的。
2021-01-06 22:43:00     打赏
使用起来还不错的
2021-01-06 23:27:04     打赏
使用起来还是非常不错的
2021-01-10 21:00:52     打赏
学到了
共4条 1/1 1 跳转至页
