电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » 扣丁学堂Java培训之LeetCode--PathSumIII分析及实现方法
共3条 1/1 1 跳转至页
2021-01-07 15:20:27     打赏
废话不多说了,下面和大家分享一下扣丁学堂Java在线学习课程:LeetCode -- Path Sum III分析及实现方法,希望可以帮到对Java开发感兴趣的小伙伴们。
题目描述:
You are given a binary tree in which each node contains an integer value.
Find the number of paths that sum to a given value.
The path does not need to start or end at the root or a leaf, but it must go downwards (traveling only from parent nodes to child nodes).
The tree has no more than 1,000 nodes and the values are in the range -1,000,000 to 1,000,000.
给定一个二叉树,遍历过程中收集所有可能路径的和,找出和等于X的路径树。
思路:
设当前节点为root,分别收集左右节点路径和的集合,merge到当前集合中;
将当前节点添加到数组中,构成新的可能路径。
实现代码:
 * Definition for a binary tree node.
 * public class TreeNode {
 * public int val;
 * public TreeNode left;
 * public TreeNode right;
 * public TreeNode(int x) { val = x; }
public class Solution {
 private int _sum;
 private int _count;
 public int PathSum(TreeNode root, int sum)
 _count = 0;
 _sum = sum;
 Travel(root, new List<int>());
 return _count;
 private void Travel(TreeNode current, List<int> ret){
 if(current == null){
  return ;
 if(current.val == _sum){
  _count ++;
 var left = new List<int>();
 Travel(current.left, left);
 var right = new List<int>();
 Travel(current.right, right);
 ret.AddRange(left);
 ret.AddRange(right);
 for(var i = 0;i < ret.Count; i++){
  ret[i] += current.val;
  if(ret[i] == _sum){
  _count ++;
 ret.Add(current.val);
 //Console.WriteLine(ret);
好了,以上就是小编给大家分享的Java在线学习课程:LeetCode -- Path Sum III分析及实现方法,想要学好Java开发的小伙伴一定要选择专业的Java培训机构,小编给大家推荐专业的Java培训机构扣丁学堂,扣丁学堂不仅有专业的老师和与时俱进的课程体系还有大量的Java在线教程供学员观看学习,心动的小伙伴快快行动吧。扣丁学堂java技术交流群:487098661。微信号:codingbb
2021-01-07 18:25:19     打赏
方法还是蛮多的
2021-01-10 17:21:33     打赏
实现方法还是挺难的
共3条 1/1 1 跳转至页
