电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 爱普生晶振最新现货库存表
共6条 1/1 1 跳转至页
爱普生晶振最新现货库存表
2021-01-13 16:59:50     打赏
EPSON爱普生晶振公司是全球知名的最大晶体,32.768K晶振,时钟模块,且是全球最大的晶振率覆盖范围生厂商,实现从KHz至MHz全覆盖,全球共有11家工厂,晶体和IC都能自主研发生产,可以保证供货安全性,供货稳定,一致性好,性能更稳定,5年以上都不会产生频偏,停振等,EPSON无源晶振,封装全,频率覆盖广,性能稳定,独有的QMEMS工艺保证了产品的高品质和高性价比,加科电子作为专业进口晶振现货分销商,可供应EPSON旗下无源晶振,有源晶振,26MHz温补晶振,今天加科电子整理一份爱普生晶振全系列现货型号表格,方便用户查询获取。
型号料号频率(HZ)频差(PPM)尺寸(MM)
TSX-3225X1E00002105270024MHZ±10PPM3.20×2.50mm
TSX-3225X1E00002106960016.000000MHZ±10PPM3.20×2.50mm
TG-5006CJX1G00413100370019.2MHZ±2PPM2.00×1.60mm
TG-5006CJX1G00413100420032MHZ±2PPM2.00×1.60mm
TG-5006CJX1G00413100110038.4MHZ±2PPM2.00×1.60mm
TG-5006CJX1G00413100100026MHZ±2PPM2.00×1.60mm
TG-5006CJX1G00413100090019.2MHz±2PPM2.00×1.60mm
TG-5006CGX1G00421100040016.368MHZ±2PPM2.50×2.00mm
TG-5006CEX1G00420100170026MHZ±2PPM3.20×2.50mm
TG-5006CEX1G00420100100026MHZ±2PPM3.20×2.50mm
SG7050VANX1G004281002400200MHZ±30PPM7.00×5.00mm
SG7050VANX1G004281003300156.25MHZ±30PPM7.00×5.00mm
SG7050VANX1G004281002300100MHZ±30PPM7.00×5.00mm
SG5032CCNX1G0044710029004.915200MHZ±50PPM5.00×3.20mm
SG-310SEFQ33310FE002610050MHZ±50PPM3.20×2.50mm
SG-310SCNQ33310N7000680050MHZ±25PPM3.20×2.50mm
SG-310SCNQ33310N7001650024MHZ±25PPM3.20×2.50mm
SG-3030LCQ3102LC0200050032.768KHZ+5PPM~±23PPM3.60×2.80mm
SG-3030JFQ3102JF0200010032.768KHZ+5PPM~±23PPM7.00×5.00mm
RX-8025NBQ4180259100010032.768KHZ±10PPM6.00×4.80mm
MC-146Q13MC146100170032.768KHZ±10PPM7.00×1.50mm
FC-135Q13FC135000060032.768KHZ±10PPM3.20×1.50mm
FC-135Q13FC135000010032.768KHZ±10PPM3.20×1.50mm
FC-135Q13FC135000240032.768KHZ±5PPM3.20×1.50mm
FC-135Q13FC135000050032.768KHZ±10PPM3.20×1.50mm
FC-12MX1A00006100210032.768KHZ±20PPM2.00×1.20mm
FC-12MX1A00006100140032.768KHZ±10PPM2.00×1.20mm
FA-238Q22FA238011010027MHz±30PPM3.20×2.50mm
FA-238Q22FA238008440025MHz±15PPM3.20×2.50mm
FA-238Q22FA238018120025MHz±30PPM3.20×2.50mm
FA-238Q22FA238016990025MHz±20PPM3.20×2.50mm
FA-238Q22FA238003380024MHz±15PPM3.20×2.50mm
FA-238Q22FA238016970024MHz±20PPM3.20×2.50mm
FA-238Q22FA238012010024MHz±20PPM3.20×2.50mm
FA-238Q22FA238000350020MHZ±30PPM3.20×2.50mm
FA-238Q22FA238002630016MHz±15PPM3.20×2.50mm
FA-238Q22FA238019110016MHz±50PPM3.20×2.50mm
FA-20HQ24FA20H001960032MHZ±10PPM2.50×2.00mm
FA-20HQ24FA20H000590016MHZ±10PPM2.50×2.00mm
FA-128Q22FA128000130024MHZ±30PPM2.00×1.60mm
FA-118TX1E00025100650032MHZ±10PPM1.60×1.20mm
FA-118TX1E00025100460024MHZ±10PPM1.60×1.20mm
RX-8025TX1B00028100050032.768KHZ±5PPM10.1×7.40mm
SG-210STFX1G00417100490054MHZ±50PPM2.50×2.00mm
FA-118TX1E00025100640026MHZ±10PPM1.60×1.20mm
FA-118TX1E00025100140026MHZ±10PPM1.60×1.20mm
FA-118TX1E00025100590032MHZ±10PPM1.60×1.20mm
FA-20HQ24FA20H003840030MHZ±10PPM2.50×2.00mm
FA-20HQ24FA20H001470027MHZ±10PPM2.50×2.00mm
MC-146Q13MC146200040032.768KHZ±20PPM7.00×1.50mm
SG7050CCNX1G0045010020116MHZ±50PPM7.0X5.0mm
SG7050CCNX1G0045010015118MHZ±50PPM7.0X5.0mm
SG7050CCNX1G0045010040117.3728MHZ±50PPM7.0X5.0mm
RX-8025TX1B00028100040032.768KHZ±5PPM6.3X4.8mm
SG-210STFX1G00417100190012.288MHZ±50PPM2.5X2.0mm
SG-8018CASG-8018CA 27MHZ TJHPA27MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 18.432MHZ TJHPA18.432MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 14.318MHZ TJHPA14.318MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 2.457MHZ TJHPA2.457MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 20MHZ TJHPA20MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 100MHZ TJHPA100MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 66.666MHZ TJHPA66.666MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 40MHZ TJHPA40MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 16MHZ TJHPA16MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 32MHZ TJHPA32MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 8MHZ TJHPA8MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 25MHZ TJHPA25MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 24MHZ TJHPA24MHZ±50PPM7.0X5.0mm
SG-8018CASG-8018CA 12MHZ TJHPA12MHZ±50PPM7.0X5.0mm
SG-8018CESG-8018CE 16.625MHZ TJHPA16.625MHZ±50PPM3.2x2.5mm
SG-8018CESG-8018CE 35MHZ TJHPA35MHZ±50PPM3.2x2.5mm
SG-8018CESG-8018CE 64MHZ TJHPA64MHZ±50PPM3.2x2.5mm
SG-8018CESG-8018CE 25MHZ TJHPA25MHZ±50PPM3.2x2.5mm
SG-8018CESG-8018CE 19.922944MHZ TJHPA19.922944MHZ±50PPM3.2x2.5mm
RX8130CEX1B00031100010032.768KHZ+5PPM~±23PPM3.2x2.5mm
RX8900CEX1B00030100020032.768KHZ±5PPM3.2x2.5mm
RX-8025SAQ4180255100020032.768KHZ±5PPM10.1x7.4mm
FA-238VQ22FA23V002850012MHZ±10PPM3.2X2.5mm
FA-238VQ22FA23V005010012MHZ±15PPM3.2X2.5mm
RX-8035LCX1B00018200031232.768KHZ±5PPM3.6x2.8mm
RX-8035SAX1B00017200031232.768KHZ±5PPM10.1x7.4mm
RX8900CEX1B00030100021232.768KHZ±5PPM3.2x2.5mm
SG-210STFX1G0041710015008MHZ±50PPM2.5X2.0mm
SG-210STFX1G0041710009004MHZ±50PPM2.5X2.0mm
TG-5006CJX1G00413100111238.4MHZ±2PPM2.0X1.6mm
TG-5006CJX1G00413100371219.2MHz±2PPM2.0X1.6mm
FC-135RX1A00014100060032.768KHZ±20PPM3.2X1.5mm
SG-210STFX1G0041710052128.192MHZ±50PPM2.5X2.0mm
SG5032CANX1G0044510063007.3728MHZ±20PPM5.0x3.2mm
FA-238AX1E00034103931124MHZ±15PPM3.2X2.5mm
SG5032EANX1G004271002411200MHZ±30PPM5.0X3.2mm
SG5032CANX1G00445100121240MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100131210MHZ±50PPM5.0X3.2mm
SG5032CANX1G0044510065128.192MHZ±50PPM5.0X3.2mm
TG-5006CGX1G00421100230019.2MHz±2PPM2.5X2.0mm
TG-5006CGX1G00421100009950MHZ±2PPM2.5X2.0mm
TG-5006CGX1G00421100111238.4MHZ±2PPM2.5X2.0mm
TG-5006CGX1G00421100081216.369MHZ±2PPM2.5X2.0mm
FA-20HQ24FA20H006301213.56MHZ±20PPM2.5X2.0mm
SG5032CCNX1G00447100040020MHZ±50PPM5.0X3.2mm
SG3225VANX1G00424100791150MHZ±50PPM3.2X2.5mm
SG3225VANX1G004241001011148.5MHZ±50PPM3.2X2.5mm
SG3225VANX1G004241000111125MHZ±50PPM3.2X2.5mm
SG3225VANX1G004241001411156.25MHZ±50PPM3.2X2.5mm
SG3225VANX1G004241000411100MHZ±50PPM3.2X2.5mm
SG3225VANX1G004241000511200MHZ±50PPM3.2X2.5mm
MC-306Q13MC306200030032.768KHZ±20PPM8.0X3.8mm
FC-12MX1A00006100020032.768KHZ±20PPM2.0X1.2mm
SG7050VANX1G004281003312156.25MHZ±30PPM7.0x5.0mm
SG7050VANX1G00428100281274.25MHZ±30PPM7.0x5.0mm
SG7050VANX1G004281002012125MHZ±30PPM7.0x5.0mm
SG7050VANX1G004281001011148.5MHZ±50PPM7.0x5.0mm
SG7050VANX1G004281000411100MHZ±50PPM7.0x5.0mm
SG7050VANX1G004281000511200MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100060020MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100091233MHZ±50PPM7.0x5.0mm
SG7050CCNX1G0045010015128MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100081225MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100041248MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100061220MHZ±50PPM7.0X5.0mm
SG7050CCNX1G00450100101240MHZ±50PPM7.0X5.0mm
SG7050CCNX1G00450100051211.0592MHZ±50PPM7.0X5.0mm
SG7050CCNX1G00450100321212.288MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100521222.1184MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100491216.384MHZ±50PPM7.0X5.0mm
SG7050CCNX1G0045010018123.579545MHZ±50PPM7.0x5.0mm
SG7050CCNX1G0045010039124.096MHZ±50PPM7.0X5.0mm
SG7050CCNX1G00450100351224.576MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100211212MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100361227MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100171224MHZ±50PPM7.0X5.0mm
SG7050CCNX1G00450100261214.7456MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100241232MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100251230MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100311210MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100331218.432MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100031216MHZ±50PPM7.0x5.0mm
SG7050CCNX1G00450100030016MHZ±50PPM7.0x5.0mm
SG7050EANX1G004291003312156.25MHZ±30PPM7.0x5.0mm
SG7050EANX1G004291003112150MHZ±30PPM7.0x5.0mm
SG7050EANX1G004291002912148.5MHZ±30PPM7.0x5.0mm
SG7050EANX1G00429100281274.25MHZ±30PPM7.0x5.0mm
SG7050EANX1G004291003212155.52MHZ±30PPM7.0x5.0mm
SG7050EANX1G004291002412200MHZ±30PPM7.0x5.0mm
SG7050EANX1G004291002312100MHZ±30PPM7.0x5.0mm
SG7050EANX1G004291002112125.00625MHZ±30PPM7.0x5.0mm
FC1610ANX1A00012100050032.768KHZ±20PPM1.6X1.0mm
FC-135RX1A00014100020032.768KHZ±20PPM3.2x1.5mm
FC-135Q13FC135000490032.768kHz±20PPM3.2x1.5mm
FA-128Q22FA128002271237.4MHZ±10PPM2.0X1.6mm
FA-128Q22FA128000641237.4MHZ±10PPM2.0X1.6mm
FA-128Q22FA128005061238.4MHZ±10PPM2.0X1.6mm
FA-128Q22FA128001001238.4MHZ±10PPM2.0X1.6mm
FA-128Q22FA128000071238.4MHZ±15PPM2.0X1.6mm
SG-310SCFQ33310F700548127.3728MHZ±25PPM3.2X2.5mm
SG-310SCNQ33310N7000241150MHZ±100PPM3.2X2.5mm
SG-310SCNQ33310N7000411148MHZ±25PPM3.2X2.5mm
SG-310SCNQ33310N7000271125MHZ±25PPM3.2X2.5mm
SG-310SEFQ33310FE002581127MHZ±50PPM3.2X2.5mm
SG-310SEFQ33310FE002561137.125MHZ±50PPM3.2X2.5mm
SG-310SEFQ33310FE002521124MHZ±50PPM3.2X2.5mm
SG-310SEFQ33310FE002441125MHZ±50PPM3.2X2.5mm
SG7050CANX1G0044810081126MHZ±50PPM7.0x5.0mm
SG7050CANX1G0044810074124.096MHZ±50PPM7.0x5.0mm
FA-20HQ24FA20H002321216MHZ±10PPM2.5X2.0mm
FA-128Q22FA128002340016MHZ±10PPM2.0X1.6mm
TSX-3225X1E00002105020027.12MHZ±10PPM3.2X2.5mm
FA-238AX1E00034103150012MHZ±30PPM3.2X2.5mm
FA-238VQ22FA23V004180012MHZ±20PPM3.2X2.5mm
SG7050VANX1G004281002112125.00625MHZ±50PPM7.0x5.0mm
SG7050VANX1G004281003212155.52MHZ±30PPM7.0x5.0mm
SG-310SEFQ33310FE001660012MHZ±20PPM3.2X2.5mm
SG-310SCNQ33310N7003240054MHZ±50PPM3.2X2.5mm
SG7050EANX1G004291002000125MHZ±30PPM7.0x5.0mm
SG5032VANX1G004261000600156.25MHZ±50PPM5.0x3.2mm
SG5032CBNX1G004461000700156.25MHZ±50PPM5.0x3.2mm
SG5032CANX1G0044510033006MHZ±50PPM5.0x3.2mm
SG7050CBNX1G00449100160096MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100450065.536MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100170033MHZ±50PPM7.0x5.0mm
SG-210STFX1G00417100460048MHZ±50PPM2.5X2.0mm
SG-210STFX1G0041710085001.5MHZ±50PPM2.5X2.0mm
SG-210STFX1G00417100320024.576MHZ±50PPM2.5X2.0mm
SG-210STFX1G00417100270016MHZ±50PPM2.5X2.0mm
SG-210STFX1G00417100470050MHZ±50PPM2.5X2.0mm
SG-310SCFQ33310F7006220050MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7006200012.288MHZ±50PPM3.2X2.5mm
FA-20HQ24FA20H003380030MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H001140025MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H002170032MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H001220016MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H000970040MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H002090040MHZ±10PPM2.5X2.0mm
FA-128Q22FA128005070016MHZ±10PPM2.0X1.6mm
TSX-3225X1E00002101330025MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002100190016MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002106480025MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002108190026MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002101390025MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002100650019.2MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002105960030MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002101190016MHZ±10PPM3.2X2.5mm
MC-306Q13MC306100040032.768KHZ±20PPM8.0X3.8mm
MC-306Q13MC306100030032.768KHZ±20PPM8.0X3.8mm
SG-8002DCSG-8002DC1MHz~125MHz±50ppm,±100ppm13.7X6.6
SG-8002JASG-8002JA1MHz~125MHz±50ppm,±100ppm14.0X9.8
SG-8002CASG-8002CA1MHz~125MHz±50ppm,±100ppm7.5X5.0
SG-8101CBSG-8101CB0.67MHz~170MHz±25ppm, ±50ppm,±100ppm5.0X3.2
EG-2102CBEG-2102CB100MHz~700MHz±50ppm, ±100ppm5.0X3.2
EG-2121CBEG-2121CB100MHz~700MHz±50ppm, ±100ppm5.0X3.2
EG-2103CBEG-2103CB100MHz~700MHz±100ppm5.0X3.2
EG-2123CBEG-2123CB100MHz~700MHz±100ppm5.0X3.2
SG-770SG-77050MHz~230MHz±50ppm7.5X5.0
SG3225EENSG3225EEN25MHz~200MHz±25ppm3.2X2.5
XG-2102CAXG-2102CA100MHz~700MHz±50ppm, ±100ppm7.5X5.0
XG-2121CAXG-2121CA100MHz~700MHz±50ppm, ±100ppm7.5X5.0
XG-2103CAXG-2103CA100MHz~700MHz±50ppm, ±100ppm7.5X5.0
XG-2123CAXG-2123CA100MHz~700MHz±50ppm, ±100ppm7.5X5.0
SG-310SG-3102MHz~80MHz±50ppm, ±100ppm3.2X2.5
SG-550SG-5502MHz~48MHz±50ppm, ±100ppm5.0X3.2
SG-645SG-6452.21675MHz~135MHz±100ppm7.1X5.1
SG-636SG-6362.21675MHz~135MHz±100ppm10.5X5.8
TCO-708xTCO-708x1.5MHz~160MHz±25ppm, ±50ppm,±100ppm7.5X5.0
TCO-710xTCO-710x1.5MHz~75MHz±50ppm,±100ppm5.0X3.2
SG-8002CESG-8002CE1MHz~125MHz±50ppm,±100ppm3.2X2.5
SG-8002JCSG-8002JC1MHz~125MHz±50ppm,±100ppm10.5X5.8
SG-8002LBSG-8002LB1MHz~125MHz±50ppm,±100ppm5.0X3.2
SG-8003CASG-8003CA1MHz~166MHz±50ppm,±100ppm7.5X5.0
SG-8003CESG-8003CE1MHz~166MHz±50ppm,±100ppm3.2X2.5
SG-8101CASG-8101CA0.67MHz~170MHz±25ppm, ±50ppm,±100ppm7.5X5.0
SG-8101CESG-8101CE0.67MHz~170MHz±25ppm, ±50ppm,±100ppm3.2X2.5
EG-2001CAEG-2001CA62.5MHz~250MHz±50ppm,±100ppm7.5X5.0
EG-2021CAEG-2021CA62.5MHz~250MHz±50ppm,±100ppm7.5X5.0
EG-2102CAEG-2102CA53.125MHz~700MHz±50ppm,±100ppm7.5X5.0
EG-2121CAEG-2121CA53.125MHz~700MHz±50ppm,±100ppm7.5X5.0
EG-2102CBEG-2102CB100MHz~700MHz±50ppm,±100ppm5.0X3.2
EG-2103CBEG-2103CB100MHz~700MHz±50ppm,±100ppm5.0X3.2
EG-4101CAEG-4101CA100MHz~700MHz±50ppm,±100ppm5.0X3.2
EV1409SANEV1409SAN1000MHz~3000MHz±50ppm14.0X9.0
EV1409EANEV1409EAN1000MHz~3000MHz±50ppm14.0X9.0
SG-771SG-77180MHz~175MHz±50ppm7.0X5.0
SG-8003CGSG-8003CG1MHz~166MHz±50ppm2.5X2.0
SG-8003LBSG-8003LB1MHz~166MHz±50ppm5.0X3.2
21022102CA100MHz ~700MHz±50ppm,±100ppm7.0X5.0
XG-2121XG-2121100MHz ~700MHz±50ppm,±100ppm7.0X5.0
2103CA2103CA100MHz ~700MHz±50ppm,±100ppm7.0X5.0
XG-2123XG-2123100MHz ~700MHz±50ppm,±100ppm7.0X5.0
FA-128Q22FA128000180032MHZ±10PPM2.0x1.6mm
SG5032VANX1G004261003112150MHZ±50PPM5.0x3.2mm
SG5032VANX1G004261002912148.5MHZ±50PPM5.0x3.2mm
SG5032VANX1G00426100281274.25MHZ±50PPM5.0X3.2mm
SG5032VANX1G004261002412200MHZ±30PPM5.0X3.2mm
SG5032VANX1G004261002312100MHZ±50PPM5.0X3.2mm
SG5032VANX1G004261002012125MHZ±30PPM5.0X3.2mm
FA-118TX1E00025100801232MHZ±10PPM1.6x1.2mm
FA-118TX1E00025100771225MHZ±10PPM1.6x1.2mm
FA-118TX1E00025100691224MHZ±30PPM1.6x1.2mm
FA-118TX1E00025100681224MHZ±30PPM1.6x1.2mm
FA-118TX1E00025100651232MHZ±10PPM1.6x1.2mm
FA-118TX1E00025100641226MHZ±10PPM1.6x1.2mm
FA-118TX1E00025100601248MHZ±30PPM1.6x1.2mm
FA-118TX1E00025100591232MHZ±10PPM1.6x1.2mm
FA-118TX1E00025100571225MHZ±30PPM1.6x1.2mm
FA-118TX1E00025100501232MHZ±10PPM1.6x1.2mm
FA-118TX1E00025100331225MHZ±30PPM1.6x1.2mm
FA-118TX1E00025100321240MHZ±10PPM1.6x1.2mm
FA-118TX1E00025100141226MHZ±10PPM1.6x1.2mm
FA-118TX1E00025100111226MHZ±10PPM1.6x1.2mm
FA-118TX1E00025100091227.12MHZ±30PPM1.6x1.2mm
TSX-3225X1E00002108081240MHZ±15PPM3.2x2.5mm
TSX-3225X1E00002107941222.5792MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002107921233.333MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002107711216.384MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002107621248MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002107461224.576MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002107141222.1184MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002106961216MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002106601238.4MHZ±20PPM3.2x2.5mm
TSX-3225X1E00002106241220MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002106221228.6363MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002106211225MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002105811220MHZ±15PPM3.2x2.5mm
TSX-3225X1E00002104811230MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002104691218.432MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002104371218.432MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002104271224.576MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002104261227MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002104251232MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002103941237.8MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002103031228.6363MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002101791240MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002101771240MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002101461226MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002101401225MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002101331225MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002101301224MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002101281224MHZ±10PPM3.2x2.5mm
TSX-3225X1E00002101261224MHZ±10PPM3.2x2.5mm
SG-3030CMX1B00021100011232.768KHZ+5PPM~±23PPM3.2x1.5mm
SG-3030LCQ3102LC0200051232.768KHZ+5PPM~±23PPM3.6X2.8mm
SG-3030LCQ3102JC0100011232.768KHZ+5PPM~±23PPM10.5X5.0mm
FA-20HQ24FA20H007481227.12MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H007321224MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H007291232MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H005301216MHZ±50PPM2.5x2.0mm
FA-20HQ24FA20H005121216MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H004311227.12MHZ±20PPM2.5X2.0mm
FA-20HQ24FA20H004281227.12MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H003941224MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H003901225MHZ±20PPM2.5X2.0mm
FA-20HQ24FA20H003841230MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H003801232MHZ±10PPM2.5x2.0mm
FA-20HQ24FA20H003581220MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H003571224MHZ±30PPM2.5X2.0mm
FA-20HQ24FA20H003451227MHZ±10PPM2.5x2.0mm
FA-20HQ24FA20H003391224MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H003381230MHZ±10PPM2.5x2.0mm
FA-20HQ24FA20H002891226MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H002471216MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H002381227MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H001721225MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H001391230MHZ±30PPM2.5x2.0mm
FA-20HQ24FA20H001281220MHZ±10PPM2.5x2.0mm
FA-20HQ24FA20H001151225MHZ±30PPM2.5X2.0mm
FA-20HQ24FA20H001141225MHZ±10PPM2.5x2.0mm
FA-20HQ24FA20H000921224MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H000291240MHZ±10PPM2.5X2.0mm
FA-128Q22FA128004001216MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003931232MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003881225MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003871224MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003691230MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003571224.576MHZ±50PPM2.0x1.6mm
FA-128Q22FA128003521226MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003451250MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003351220MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003321240MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003151227.12MHZ±10PPM2.0x1.6mm
FA-128Q22FA128002441224MHZ±15PPM2.0x1.6mm
FA-128Q22FA128002301226MHZ±10PPM2.0x1.6mm
FA-128Q22FA128002261226MHZ±10PPM2.0x1.6mm
FA-128Q22FA128001831225MHZ±10PPM2.0x1.6mm
FA-128Q22FA128001501248MHZ±10PPM2.0x1.6mm
FA-128Q22FA128001491227MHZ±10PPM2.0x1.6mm
FA-128Q22FA128001351227MHZ±10PPM2.0x1.6mm
FA-128Q22FA128001211227MHZ±10PPM2.0x1.6mm
FA-128Q22FA128001011240MHZ±10PPM2.0x1.6mm
FA-128Q22FA128000901225MHZ±10PPM2.0x1.6mm
SG5032VANX1G004261003312156.25MHZ±50PPM5.0X3.2mm
RX6110SABRX6110SAB32.768kHz±5ppm10.1X7.4
RX6110SAARX6110SAA32.768kHz±5ppm10.1X7.4
RX-4803SARX-4803SA32.768kHz±5ppm10.1X7.4
RX-4803LCRX-4803LC32.768kHz±5ppm10.1X7.4
RX-4581NBRX-4581NB32.768kHz5±23ppm6.3X5.0
RX-4571LCRX-4571LC32.768kHz±5ppm3.6X2.8
RX-4045SARX-4045SA32.768kHz±5ppm10.1X7.4
RX-4045NBRX-4045NB32.768kHz±5ppm6.3X5.0
RX-4035SARX-4035SA32.768kHz5±23ppm10.1X7.4
RX-4035LCRX-4035LC32.768kHz5±23ppm3.6X2.8
RTC-72423RTC-7242332.768kHz±20ppm ±50ppm16.3X12.2
RTC-72421RTC-7242132.768kHz±10ppm ±50ppm23.1X7.62
RTC-7301SFRTC-7301SF32.768kHz5±23ppm10.2X7.8
RTC-7301DGRTC-7301DG32.768kHz5±23ppm23.1X7.62
RTC-4574SARTC-4574SA32.768kHz5±23ppm10.1X7.4
RTC-4574JERTC-4574JE32.768kHz5±23ppm10.1X7.4
RTC-4543SARTC-4543SA32.768kHz5±23ppm10.1X7.4
RA4803SARA4803SA32.768kHz5±23ppm10.1X7.4
RA-4574SARA-4574SA32.768kHz5±23ppm10.1X7.4
RA-4565SARA-4565SA32.768kHz5±23ppm5.0X3.2
SG-210STFX1G00417100350027MHZ±50PPM2.5X2.0mm
SG-210STFX1G00417100330025MHZ±50PPM2.5X2.0mm
SG-210STFX1G00417100310024MHZ±50PPM2.5X2.0mm
SG-210STFX1G00417100290020MHZ±50PPM2.5X2.0mm
SG-210STFX1G00417100280019.2MHZ±50PPM2.5X2.0mm
SG-210STFX1G00417100180012MHZ±50PPM2.5X2.0mm
SG-310SCFQ33310F70050300 48M±50PPM3.2X2.5mm
SG-310SCFQ33310F7005810040MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F700551008MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7006110037.125MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7006000027MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7006280026MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7003210025MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7002290024.576MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7004900024MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7005150020MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7002410016MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7004540011.2896MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F7006070012MHZ±50PPM3.2X2.5mm
SG-310SCFQ33310F700386004MHZ±50PPM3.2X2.5mm
SG5032CANX1G00445100080050MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100070048MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100060033MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100140032MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100300028.6363MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100050027MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100040025MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100290024.576MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100030024MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100110020MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100020016MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100010012.288MHZ±50PPM5.0X3.2mm
SG5032CANX1G00445100280012MHZ±50PPM5.0X3.2mm
SG5032CANX1G0044510021008MHZ±50PPM5.0X3.2mm
SG7050CBNX1G004491000200125MHZ±50PPM7.0X5.0mm
SG7050CBNX1G004491000100100MHZ±50PPM7.0X5.0mm
SG7050CBNX1G00449100230080MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100470074.250MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100200066MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100340060MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100130054MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100120050MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100110048MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100150040MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100270033.333MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100410032.768MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100090032MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100310030MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100430028.6363MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100040027MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100030025MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100160024.576MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100020024MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448101520022.1184MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100080020MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100480018.432MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100230016.384MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100070016MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100250014.7456MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100280014.31818MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100950013MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100010012.288MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100060012MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100440011.0592MHZ±50PPM7.0X5.0mm
SG7050CANX1G00448100050010MHZ±50PPM7.0X5.0mm
SG7050CANX1G0044810014008MHZ±50PPM7.0X5.0mm
SG7050CANX1G0044810040007.3728MHZ±50PPM7.0X5.0mm
SG7050CANX1G0044810051004MHZ±50PPM7.0X5.0mm
SG7050CANX1G0044810039003.6864MHZ±50PPM7.0X5.0mm
RX8010SJX1B00024200010032.768KHZ+5PPM~±23PPM7.0*6.0*2.65
SG-3030CMX1B00021100010032.768KHZ+5PPM~±23PPM3.2X1.5mm
SG7050VANX1G004281002000125MHZ±30PPM7.0X5.0mm
TG-5006CGX1G00421100030026MHZ±2PPM2.5X2.0mm
TG-5006CGX1G00421100010026MHZ±2PPM2.5X2.0mm
FA-20HQ24FA20H001060032MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H007270032MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H002230030MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H003150026MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H001930026MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H001660025MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H003940024MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H000440016MHZ±10PPM2.5X2.0mm
FA-20HQ24FA20H006870012MHZ±10PPM2.5X2.0mm
TSX-3225X1E00002101690032MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002101630032MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002102950030MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002104810030MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002101580027MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002101440026MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002101470026MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002103520025MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002102640024MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002101290024MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002101270024MHZ±10PPM3.2X2.5mm
TSX-3225X1E00002103750016MHZ±10PPM3.2X2.5mm
FA-128Q22FA128001400026MHZ±10PPM2.0x1.6mm
FA-128Q22FA128004700026MHZ±10PPM2.0x1.6mm
FA-128Q22FA128003040024MHZ±10PPM2.0x1.6mm
FA-128Q22FA128000220024MHZ±10PPM2.0x1.6mm
FA-128Q22FA128000920032MHZ±10PPM2.0x1.6mm
FA-128Q22FA128000250032MHZ±10PPM2.0x1.6mm
MC-306Q13MC306200060032.768KHZ±20PPM8.0x3.8mm
FC-135RX1A00014100010032.768KHZ±20PPM3.2x1.5mm
FC-135RX1A00014100050032.768KHZ±10PPM3.2x1.5mm
FC-12MX1A00006100060032.768KHZ±20PPM2.0x1.2mm
FC-12MX1A00006100050032.768KHZ±20PPM2.0x1.2mm
MC-146Q13MC146200010032.768KHZ±20PPM7.0x1.5mm
MC-146Q13MC146200020032.768KHZ±20PPM7.0x1.5mm
FC-135Q13FC135000030032.768KHZ±20PPM3.2x1.5mm
FC-135Q13FC135000020032.768KHZ±20PPM3.2x1.5mm
FC-135Q13FC135000040032.768KHZ±20PPM3.2x1.5mm
FA2016AAFA2016AA16MHz ~ 54MHz±10ppm2.0X1.6
XG5032HANXG5032HAN100MHz ~200MHz±50ppm,±100ppm5.0X3.2
XG-1000CAXG-1000CA50MHz~170MHz±50ppm,±100ppm7.0X5.0
VG7050EANVG7050EAN50MHz~800MHz±50ppm7.5X5.0
VG-4513CBVG-4513CB100MHz~500MHz-40℃~+85℃5.0X3.2
VG-4512CAVG-4512CA80MHz~200MHz±50ppm7.5X5.0
VG-4231CEVG-4231CE3MHz~60MHz±30ppm,±37ppm3.2X2.5
VG-4231CBVG-4231CB1MHz~81MHz±50ppm5.0X3.2
VG-4231CAVG-4231CA1MHz~80MHz±35ppm,±50ppm7.5X5.0
SG-8003JFSG-8003JF1MHz~166MHz±50ppm7.1X4.6
SG3225EANSG3225EAN73.5MHz~700MHz±20ppm, ±30ppm,±50ppm3.2X2.5
SG-3030CMSG-3030CM32.768kHz±5±23ppm3.2X1.5
MC-30AMC-30A32.768kHz±20ppm, ±50ppm,±100ppm8.0X3.8
MA-406MA-4064MHz~64MHz±50ppm11.7X4.8
MA-306MA-30614.31818MHz~41MHz±50ppm8.0X3.8
FC-13A32.768kHz32.768KHz±20ppm, ±30ppm,±50ppm3.2X1.5
FA2016ASFA2016AS16MHz~54MHz±10ppm2.0X1.6
FA2016AAFA2016AA16MHz~54MHz±10ppm,2.0X1.6
FA-118TFA-118T24MHz~54MHz±10ppm, ±30ppm1.6X1.2
EV-9100JGEV-9100JG800MHz~2500MHz±100ppm13.9X9.8
EV1409SANEV1409SAN1000MHz~2500MHz±50ppm14.0X9.0
EG-4121EG-4121100MHz~700MHz±50ppm,±100ppm7.0X5.0
EG-2121EG-2121100MHz~700MHz±50ppm,±100ppm5.0X3.2
EG-2101CAEG-2101CA62.5MHz~99.999 MHz±50ppm,±100ppm7.5X5.0
EG-2021EG-202162.5MHz~250MHz±50ppm,±100ppm7.5X5.0
EG-2002CAEG-2002CA62.5MHz~170MHz±50ppm,±100ppm7.5X5.0
EA-2102CBEA-2102CB100MHz±300ppm5.0X3.2
C-002RXC-002RX32.768kHz±20ppm2.0X6.0
SG-8101CGSG-8101CG0.67MHz~170MHz±25ppm, ±50ppm,±100ppm2.5X2.0
SG7050CANSG7050CAN1MHz~75MHz±50ppm7.5X5.0
SG5032CANSG5032CAN1MHz~75MHz±50ppm5.0X3.2
SG-211S*ESG-211S*E2.375MHz~60MHz±15ppm, ±20ppm2.5X2.0
SG-210S*HSG-210S*H80MHz~170MHz±50ppm, ±100ppm2.5X2.0
SG-210S*DSG-210S*D50MHz~80MHz±50ppm, ±100ppm2.5X2.0
SG-210S*BASG-210S*BA2MHz~60MHz±50ppm, ±100ppm2.5X2.0
SG-210STFSG-210STF1MHz~75MHz±25ppm, ± 50ppm2.5X2.0
HG-2150CAHG-2150CA1MHz~60MHz±15ppm, ± 20ppm7.5X5.0
HTS-206HTS-20632.4 kHz±20ppm2.0X6.0
XG5032HANXG5032HAN100MHz~200MHz±50ppm, ±100ppm5.0X3.2
SG7050EENSG7050EEN25MHz~200MHz±25ppm, ±50ppm,±100ppm7.5X5.0
SG7050EBNSG7050EBN100MHz~175MHz±50ppm7.5X5.0
SG5032EAN/VANSG5032EAN/VAN73.5MHz~700MHz±20ppm, ±30ppm,±50ppm5.0X3.2
SG7050EAN/VANSG7050EAN/VAN73.5MHz~700MHz±20ppm, ±30ppm,±50ppm7.5X5.0
EG-4121CAEG-4121CA100MHz~700MHz±50ppm7.5X5.0
EG-2123EG-2123100MHz~700MHz±100ppm5.0X3.2
EA-2102CBEA-2102CB100MHz± 300ppm5.0X3.2
关键词: 爱普生晶振     晶振
2021-01-13 21:30:13     打赏
±2PPM,不错哦!
2021-01-13 21:38:43     打赏
32.768K 这个频点, 不知道现在哪家做得最好?
2021-01-13 21:44:01     打赏
0.5ppm , 带温补才牛~
2021-01-13 23:33:33     打赏
总结的非常全面
2021-01-13 23:45:49     打赏
这些器件应该都挺不错的吧
共6条 1/1 1 跳转至页
