Questions:如何将以下默认非GPIO的Pin设置为GPIO
OSC_IN PD0
OSC_OUT PD1
JTMS-SWDIO PA13
JTCK-SWCLK PA14
JTDI PA15
JTDO PB3
NJTRST PB4
TAMPER-RTC PC13
OSC32_IN PC14
OSC32_OUT PC15
Answer:将以上IO设置为GPIO,需要开启对应GPIO时钟、开启复用时钟、将IO配置为输入/输出/复用功能、设置重映射、关闭入侵检测、关闭外部时钟等相应的操作。
1. 将OSC_IN、OSC_OUT设置为GPIO输出,需要设置如下:
//开启GPIOD时钟、开启复用时钟
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOD | RCC_APB2PERIPH_AFIO, ENABLE);
//关闭外部高速时钟
RCC_HSEConfig(RCC_HSE_DISABLE);
//设置PD0、PD1为推挽输出
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_0 | GPIO_Pins_1;
GPIO_InitStructure.GPIO_MaxSpeed = GPIO_MaxSpeed_2MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
//设置重映射 JTAG-DP Disabled and SW-DP Enabled
GPIO_PinsRemapConfig(GPIO_Remap_PTD01, ENABLE);
注:如果要使用PD0、PD1,则时钟初始化时不用使能HSE、PLL时钟源不能选择为HSE。
2. 将SWJ设置为GPIO,例如将JTDI、JTDO、NJTRST设置为GPIO输出,需要设置如下:
//开启GPIOA、GPIOB时钟、开启复用时钟
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOA | RCC_APB2PERIPH_GPIOB | RCC_APB2PERIPH_AFIO, ENABLE);
//设置PA15、PB3、PB4为推挽输出
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_15;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_3 | GPIO_Pins_4;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinsRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
关于SWJ重映射说明:
/*!< Full SWJ Enabled (JTAG-DP + SW-DP) but without JTRST */
#define GPIO_Remap_SWJ_NoJNTRST ((uint32_t)0x01000000)
/*!< JTAG-DP Disabled and SW-DP Enabled */
#define GPIO_Remap_SWJ_JTAGDisable ((uint32_t)0x02000000)
/*!< Full SWJ Disabled (JTAG-DP + SW-DP) */
#define GPIO_Remap_SWJ_AllDisable ((uint32_t)0x04000000)
3. 将TAMPER-RTC、OSC32_IN、OSC32_OUT设置为GPIO输出,需要设置如下:
//开启GPIOC时钟、开启备份接口时钟、开启电源接口时钟
RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_GPIOC, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_BKP, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_PWR, ENABLE);
//关闭入侵检测和外部低速时钟
PWR_BackupAccessCtrl(ENABLE);
BKP_TamperPinCmd(DISABLE); //关闭入侵检测
RCC_LSEConfig(RCC_LSE_DISABLE); //关闭外部低速时钟
PWR_BackupAccessCtrl(DISABLE);
//设置PC13、PC14、PC15为推挽输出
GPIO_InitStructure.GPIO_Pins = GPIO_Pins_13 | GPIO_Pins_14 | GPIO_Pins_15;
GPIO_Init(GPIOC, &GPIO_InitStructure);
注:如果要使用PC14、PC15,则时钟初始化时不用使能LSE。
类型:MCU 应用
适用型号:全系列(AT32F403, AT32F403A, AT32F413,AT32F415, AT32F407)
主功能:GPIO
