电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 51单片机的测温+按键+LCD显示的一个软硬件范例
共12条 1/2 1 2 › 跳转至页
2021-06-15 21:57:25     打赏
51单片机的测温+按键+LCD显示的一个软硬件范例, 电路图和源码可参考如下:
//包含的头文件
#include<REG51.H>
#include<math.h>
#include<INTRINS.H>
#include<string.h>
//定义宏定义
#define CIRCLE 100
#define uchar unsigned char
#define uint   unsigned int;
struct PID {
unsigned int SetPoint; // 设定目标 Desired Value
unsigned int Proportion; // 比例常数 Proportional Const
unsigned int Integral; // 积分常数 Integral Const
unsigned int Derivative; // 微分常数 Derivative Const
unsigned int LastError; // Error[-1]
unsigned int PrevError; // Error[-2]
unsigned int SumError; // Sums of Errors
struct PID spid; // PID Control Structure
unsigned int rout; // PID Response (Output)
unsigned int rin; // PID Feedback (Input)
typedef unsigned char BYTE;
typedef unsigned int WORD;
typedef bit BOOL ;
sbit key1=P3^2;   //定义按键位置
sbit key2=P3^3;
sbit key3=P3^4;
sbit rs = P1^0;
sbit rw = P1^1;
sbit ep = P1^2;
sbit pwm=P1^5; //PWM输出端设置为P1.5输出
sbit DQ=P1^3;//ds18b20 信号引脚即DQ
sfr dataled=0x80;//显示数据端口 即P2口为段选码输入口
uchar temp;//温度变量
unsigned char set_temper=30;
unsigned char high_time;
unsigned int s;
uchar flag_get,count,num,counter; //温度读取标志位、中断次数变量t0中断次数以读取温度值, t1中断次数以控制周期和PWM的占空比
char const table[]={100,80,70,60,50,40,30,20,0};//高电平时间查表
uchar
code
tab[]={0x28,0xEB,0x32,0xA2,0xE1,0xA4,0x24,0xEA,0x20,0xA0,0x60,0x25,0x3C,0x23,0x34,
0x74,0xF7,0xFF};//,0x88,0x83,0xC6,0xA1,0x86,0x8E};//共阳led显示段码115段码表
uchar  shi,ge,danwei,dang,dang_dis;  // 定义温度十位、个位、摄氏度单位、及档位变量名称,及显示档位的查表变量
void delay1(uchar MS);// 延时函数
unsigned char ReadTemperature(void);//读温度子函数
void Init_DS18B20(void);// DS18B20初始化
unsigned char ReadOneChar(void);//读字节子函数
void WriteOneChar(unsigned char dat);//写字节子函数
void delay(unsigned int i);//延时
//void del(unsigned int);
void drive_moto();//由P1低四位输出控制信号
void initial();
unsigned int TempBuffer[5];
BYTE code dis1[] = {"Temperature:"};
BYTE code dis2[] = {"Set_Temper:"};
BYTE code dis3[] = {"0123456789"};
BYTE code dis4[] = 0xdf;
BYTE code dis5[] = {"C"};
//定义函数
void delay2(BYTE ms)
 BYTE i;
 while(ms--)
  for(i = 0; i< 250; i++)
   _nop_();
   _nop_();
   _nop_();
   _nop_();
// 测试LCD忙碌状态
BOOL lcd_bz()
 BOOL result;
 rs = 0;
 rw = 1;
 ep = 1;
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 result = (BOOL)(P0 & 0x80);
ep = 0;
 return result;
// 写入指令数据到LCD
void lcd_wcmd(BYTE cmd)
 while(lcd_bz());
 rs = 0;
 rw = 0;
 ep = 0;
 _nop_();
 _nop_();
 P0 = cmd;
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 ep = 1;
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 ep = 0;
//设定显示位置
void lcd_pos(BYTE pos)
 lcd_wcmd(pos | 0x80);
 //写入字符显示数据到LCD
void lcd_wdat(BYTE dat)
 while(lcd_bz());
rs = 1;
 rw = 0;
 ep = 0;
 P0 = dat;
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 ep = 1;
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 ep = 0;
//LCD初始化设定
void lcd_init()
 lcd_wcmd(0x38);   //
 delay2(1);
 lcd_wcmd(0x0c);   //
 delay2(1);
 lcd_wcmd(0x06);   //
 delay2(1);
 lcd_wcmd(0x01);   //清除LCD的显示内容
 delay2(1);
//初始化相应的寄存器
void initial()
EA=1;
TMOD=0x11;//定时器设置皆工作在16定时计数器模式
TH0=0xef;//T0赋初值
TL0=0xf0;
TH1=(65536-1000)/256;//T1赋初值
TL1=(65536-1000)%256;
ET1=1;
ET0=1;
TR0=1;
TR1=1;
P2=0xff;
count=0;
counter=0;//pwm占空比控制变量
//IP=0x08; //T1优先级高于T0 ,后来证明此语句是多余的因为当加入此句后反/////而PWM调速和温度检测都变得有点不稳定
//延时函数
 while(i--);
//18b20初始化函数检测总线上是否有从属器件DS的存在若存在则通讯成功
 unsigned char x=0;
 DQ = 1;    //DQ复位
 delay(8);  //稍做延时
 DQ = 0;    //单片机将DQ拉低
 delay(80); //延时 大于 480us
 DQ = 1;    //拉高总线
 delay(10);
 x=DQ;      //稍做延时后 如果x=0则初始化成功 x=1则初始化失败因为DQ复位成功的回答信号即存在信号是低电平
 delay(5);
//读一个字节ROM
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
  DQ = 0; // 给脉冲信号
  dat>>=1;
  DQ = 1; // 给脉冲信号
  if(DQ)
   dat|=0x80;//
  delay(5);
 return(dat);
//写一个字节
 unsigned char i=0;
 for (i=8; i>0; i--)
  DQ = 0;
  DQ = dat&0x01;
  delay(5);
  DQ = 1;
  dat>>=1;
delay(5);
//读取温度
unsigned char a=0;
unsigned char b=0;
unsigned char t=0;
Init_DS18B20();// 复位
WriteOneChar(0xCC); // 跳过读序号列号的操作
WriteOneChar(0x44); // 启动温度转换
delay(100);
Init_DS18B20();  //每次操作前都要进行复位
WriteOneChar(0xCC); //跳过读序号列号的操作
WriteOneChar(0xBE); //读取温度寄存器等共可读9个寄存器 前两个就是温度
a=ReadOneChar();
b=ReadOneChar();
s=(unsigned int)(a&0x0f);
b<<=4;//取高字节的第四位因为高四位为符号位1111为负0000为正
b+=(a&0xf0)>>4;//忽略小数位取a的高四位与b的相加就是此时所测得到整数温度值
t=b;
return(t);//返回温度值给这个函数
//显示函数
void printf()
 BYTE i;
 delay2(10);
 lcd_pos(0x00);    // 设置显示位置为第一行的第5个字符
 i = 0;
 while(dis1[i] != '\0')
  lcd_wdat(dis1[i]);
  i++;
 lcd_pos(0x40);   // 设置显示位置为第二行第二个字符
 i = 0;
 while(dis2[i] != '\0')
  lcd_wdat(dis2[i]); // 显示字符
  i++;
 TempBuffer[0]=temp/10;  //十位
 TempBuffer[1]=temp%10;  //个位
 lcd_pos(0x0c);
 lcd_wdat(dis3[TempBuffer[0]]); //测试温度十位
 lcd_pos(0x0d);
 lcd_wdat(dis3[TempBuffer[1]]); //测试温度个位
 lcd_pos(0x0e);
 lcd_wdat(dis4[0]);
 lcd_pos(0x0f);
 lcd_wdat(dis5[0]);
 TempBuffer[2]=set_temper/10;  //十位
 TempBuffer[3]=set_temper%10;  //个位
 lcd_pos(0x4c);
 lcd_wdat(dis3[TempBuffer[2]]); //设置温度十位
 lcd_pos(0x4d);
 lcd_wdat(dis3[TempBuffer[3]]); //设置温度个位
 lcd_pos(0x4e);
 lcd_wdat(dis4[0]);
 lcd_pos(0x4f);
lcd_wdat(dis5[0]);
//键盘输入函数
void keyscan()
         if(key1==0)
          delay(200);
          if(key1==0)
           set_temper++;
         if(key2==0)
          delay(200);
          if(key2==0)
           set_temper--;
//         //开始按键
// if(key3==0)
//          delay(300);
//         if(key3==0)
//                        TR1=1;
//T1定时中断服务程序
void into(void) interrupt 3
    TH1=(65536-1000)/256;//初值重装
 counter++;
  if(counter>CIRCLE)
  counter=0;////限定周期为T=100X0.01ms=10ms
 if(counter<=high_time)//取得查表参数以调节pwm的占空比
 pwm=1;//PWM高电平
 else
 pwm=0;
//设定占空比函数
void compare_temper()
char shi=0,ge=0;
 if(set_temper>temp)
//当设置温度与实际温度大于10度时
          if(set_temper-temp>=10)
          //进入死循环
                          while(1)
                           TR1=0;      //关闭定时器   从而关闭PWM波
                           pwm=0;           //输出低电平
                           temp=ReadTemperature();        //读取温度传感器的值
                           shi=temp/10;                 //分离出十位
                           ge=temp%10;                 //分离出个位
                           lcd_pos(0x0c);         //设置显示位置
                           lcd_wdat(0x30+shi);          //在指定位置显示十位
                           lcd_pos(0x0d);                 //设置显示位置
                           lcd_wdat(0x30+ge);            //在指定位置显示各位
                           if(set_temper-temp<10)         //如果温度差值低于10度
                                        TR1=1; //打开定时器  开pwm波
                                           break;         //跳出循环
                  else
                  //打开定时器
                  TR1=1;
                  //根据差值调整PWM波
                   if (set_temper-temp==9)
                    high_time=10;
                   if (set_temper-temp==8)
                    high_time=20;
                   if (set_temper-temp==7)
                    high_time=30;
                   if (set_temper-temp==6)
                    high_time=40;
                   if (set_temper-temp==5)
                    high_time=50;
                   if (set_temper-temp==4)
                    high_time=60;
                   if (set_temper-temp==3)
                    high_time=70;
                   if (set_temper-temp==2)
                    high_time=80;
                   if (set_temper-temp==1)
                    high_time=90;
 else if(set_temper<temp)
 //关闭定时器
   pwm=1;
   TR1=0;
main()
 initial();// 初始化个变量及定时器的初值开中断等
 lcd_init();    // 初始化LCD
 while(1)
 //比较函数
  compare_temper();
 //输出函数
  printf();
  //读取温度函数
  //键盘扫描函数
  keyscan();
关键词: 测温     显示     LCD     DS18B20
2021-06-16 21:25:52     打赏
谢谢分享,收藏了。
2021-06-16 22:27:18     打赏
项目挺完整的嘛!用来学习不错!
2021-06-16 22:34:04     打赏
原理图画得挺beatiful的,楼主啥软件画的啊?
2021-06-17 23:48:45     打赏
代码写的非常好
2021-06-18 17:39:41     打赏
2021-06-19 13:46:16     打赏
代码写的非常不错
2021-06-19 16:16:41     打赏
学习到了
2021-06-19 16:20:23     打赏
学习一下
2021-06-19 19:20:26     打赏
学习到了
共12条 1/2 1 2 › 跳转至页
