电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » PIC32单片机harmony开发环境-uart例程和代码分析
共4条 1/1 1 跳转至页
2021-08-12 23:57:00     打赏
开发环境:mplab 3.45 harmony 1.09 xc32 1.42
源代码下载:http://download.csdn.net/detail/zn2857/9712707
源代码分析:
void APP_Tasks ( void )
    /* Check the application's current state. */
    switch ( appData.state )
        /* Application's initial state. */
        case APP_STATE_INIT:
            bool appInitialized = true;
            if (appInitialized)
                /* Open the USART Driver for USART1 Client  */
                appData.drvUartHandle = DRV_USART_Open( DRV_USART_INDEX_0,DRV_IO_INTENT_READWRITE );
                appData.state = APP_STATE_CHECK_DRVR_STATE;
            break;
        case APP_STATE_CHECK_DRVR_STATE:
            /* Check the USART1 driver handler */
            if (appData.drvUartHandle == DRV_HANDLE_INVALID )
                /* Set the uart state to Ready */
                appData.state = APP_STATE_INIT;
                return;
            DRV_USART_ByteReceiveCallbackSet(DRV_USART_INDEX_0, (DRV_USART_BYTE_EVENT_HANDLER)Uart_LoopBack);
            appData.state = APP_STATE_IDLE;
            break;
        case APP_STATE_SERVICE_TASKS:
            uint8_t numBytes = 0;
            while( numBytes < 1 )
                numBytes++;
                if( !(DRV_USART_TRANSFER_STATUS_TRANSMIT_FULL & DRV_USART_TransferStatus(appData.drvUartHandle)) )
                    DRV_USART_WriteByte(appData.drvUartHandle, temp);
            break;
        case APP_STATE_IDLE:
            break;
        /* TODO: implement your application state machine.*/
        /* The default state should never be executed. */
        default:
            /* TODO: Handle error in application's state machine. */
            break;
2021-08-13 11:36:03     打赏
学习学习
2021-08-13 23:47:07     打赏
分析的挺好的
2021-08-15 23:58:17     打赏
分析的还是比较到位的
共4条 1/1 1 跳转至页
