电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 51单片机读写24C64及TM1638显示按键模块
共14条 1/2 1 2 跳转至
2022-01-13 10:24:39   被打赏 200 分(兑奖)     打赏
一个测试读写24C64以及TM1638数码管显示、矩阵按键模块的工程,有源码。经过测试,没问题。
bit I2C_Start(void) {
    delay_us(10);
    I2C_SDA =1;
    delay_us(10);
    I2C_SCK =1;
    delay_us(10);
    if ( I2C_SDA == 0) return 0;
    if ( I2C_SCK == 0) return 0;
    I2C_SDA = 0;
    delay_us(10);
    I2C_SCK = 0;
    delay_us(10);
    return 1;
void  I2C_Stop(void) {
    delay_us(10);
    I2C_SDA = 0;
    delay_us(10);
    I2C_SCK = 1;
    delay_us(10);
    I2C_SDA = 1;
    delay_us(10);
void I2C_Ack(void)  {
    delay_us(10);
    I2C_SDA=0;
    delay_us(10);
    I2C_SCK=1;
    delay_us(10);
    I2C_SCK=0;
    delay_us(10);
void I2C_Nack(void) {
    delay_us(10);
    I2C_SDA=1;
    delay_us(10);
    I2C_SCK=1;
    delay_us(10);
    I2C_SCK=0;
    delay_us(10);
bit I2C_Send_Byte( uchar d) {
    uchar i = 8;
    bit bit_ack;
    while( i-- )  {
        delay_us(10);
        if (d & 0x80 )   I2C_SDA =1;
        else             I2C_SDA =0;
        delay_us(10);
        I2C_SCK = 1;
        delay_us(10);
        I2C_SCK = 0;
        d = d << 1;
    delay_us(10);
    I2C_SDA = 1;
    delay_us(10);
    I2C_SCK = 1;
    delay_us(10);
    bit_ack = I2C_SDA;
    I2C_SCK =0;
    delay_us(10);
    return bit_ack;
uchar I2C_Receive_Byte(void) {
    uchar i = 8, d;
    delay_us(10);
    I2C_SDA = 1;
    while ( i--)     {
        d = d << 1;
        delay_us(10);
        I2C_SCK =1;
        if ( I2C_SDA ) d++;
        delay_us(10);
        I2C_SCK =0;
    return d;
void AT24C64_W(void *mcu_address,uint AT24C64_address,uint count)  {
    I2C_WP=0;
    while(count--)      {
        I2C_Start();
        /*I2C_Send_Byte( 0xa0 + AT24C64_address /256 *2);*/  /* 24C16  USE */
        I2C_Send_Byte( 0xa0 );
        I2C_Send_Byte(  AT24C64_address/256 );
        I2C_Send_Byte( AT24C64_address %256 );
        I2C_Send_Byte( *(uchar*)mcu_address );
        I2C_Stop();
        delay_ms(10);       /* waiTIng for write cycle to be completed */
        ((uchar*)mcu_address)++;
        AT24C64_address++;
    I2C_WP=1;
void AT24C64_R(void *mcu_address,uint AT24C64_address,uint count) {
    while(count--) {
        I2C_Start();
        /*I2C_Send_Byte( 0xa0 + AT24C64_address / 256 *2 );*/   /* 24C16 USE */
        I2C_Send_Byte( AT24C64_address % 256 );
        I2C_Start();
        /*I2C_Send_Byte( 0xa1 + AT24C64_address /256 *2 );*/
        I2C_Send_Byte( 0xa1 );
        *(uchar*)mcu_address = I2C_Receive_Byte();
        I2C_Nack();
        I2C_Stop();
        AT24C64_address++;
void TM1638_Write(unsigned char DATA) //写数据函数
unsigned char i;
for(i=0;i<8;i++)
CLK=0;
if(DATA&0X01)
DIO=1;
else
DIO=0;
DATA>>=1;
CLK=1;
unsigned char TM1638_Read(void) //读数据函数
unsigned char i;
unsigned char temp=0;
DIO=1; //设置为输入
for(i=0;i<8;i++)
temp>>=1;
CLK=0;
if(DIO)
temp|=0x80;
CLK=1;
return temp;
void Write_COM(unsigned char cmd) //发送命令字
STB=0;
TM1638_Write(cmd);
STB=1;
unsigned char Read_key(void)
unsigned char c[4],i,key_value=0;
STB=0;
TM1638_Write(0x42);
delay_ms(100);
for(i=0;i<4;i++)
c[i]=TM1638_Read();
STB=1; //4个字节数据合成一个字节
if(c[0]==0x04) key_value=1;
if(c[0]==0x40) key_value=2;
if(c[1]==0x04) key_value=3;
if(c[1]==0x40) key_value=4;
if(c[2]==0x04) key_value=5;
if(c[2]==0x40) key_value=6;
if(c[3]==0x04) key_value=7;
if(c[3]==0x40) key_value=8;
if(c[0]==0x02) key_value=9;
if(c[0]==0x20) key_value=10;
if(c[1]==0x02) key_value=11;
if(c[1]==0x20) key_value=12;
if(c[2]==0x02) key_value=13;
if(c[2]==0x20) key_value=14;
if(c[3]==0x02) key_value=15;
if(c[3]==0x20) key_value=16;
    delay_ms(100);
return (key_value);
TM1638_24C64.zip
关键词: 单片机     24C64     TM1638显示按键模块
2022-01-18 19:38:36     打赏
干货
2022-01-18 19:47:21     打赏
很实用 谢谢分享
2022-01-18 19:50:59     打赏
很实用的文章
2022-01-18 19:55:14     打赏
感谢楼主分享
2022-01-18 20:04:03     打赏
感谢楼主分享
2022-01-18 20:18:13     打赏
干货
2022-01-18 23:46:58     打赏
2022-01-19 23:37:44     打赏
模块总结的挺好的
2022-01-20 11:08:33     打赏
好家伙!纯干货!
共14条 1/2 1 2 跳转至
