电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » Uboot命令应用
共12条 1/2 1 2 跳转至
Uboot命令应用
2022-09-20 23:42:27     打赏
U-Boot 是一个主要用于嵌入式系统的引导加载程序,可以支持多种不同的计算机系统结构,包括PPC、ARM、AVR32、MIPS、x86、68k、Nios与MicroBlaze。这也是一套在GNU通用公共许可证之下发布的自由软件。
U-Boot本质是一个裸机程序,是一种普遍用于嵌入式系统中的开源的Bootloader,作用是用来引导操作系统,以及给开发人员提供测试调试工具。主要负责基本硬件初始化,导启动内核启动。
U-Boot命令众多,通过uboot命令可完成系统环境变量设置。U-Boot本质就是一份裸机程序,这样可以在U-Boot命令下调试一些硬件设备问题。U-Boot命令行也是可以实现自动补全功能。
1.查看当前U-Boot支持命令:?或者help
TINY4412 # ?
?       - alias for 'help'
base    - print or set address offset
bdinfo  - print Board Info structure
boot    - boot default, i.e., run 'bootcmd'
bootd   - boot default, i.e., run 'bootcmd'
bootelf - Boot from an ELF image in memory
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
bootvx  - Boot vxWorks from an ELF image
chpart  - change active partition
cmp     - memory compare
coninfo - print console devices and information
cp      - memory copy
crc32   - checksum calculationdcache  - enable or disable data cache
dnw     - dnw     - initialize USB device and ready to receive for Windows server (specific)
echo    - echo args to console
editenv - edit environment variable
emmc    - Open/Close eMMC boot Partition
env     - environment handling commands
exit    - exit script
ext2format- ext2format - disk format by ext2
ext2load- load binary file from a Ext2 filesystem
ext2ls  - list files in a directory (default /)
ext3format- ext3format - disk format by ext3
false   - do nothing, unsuccessfully
fastboot- fastboot- use USB Fastboot protocol
fatformat- fatformat - disk format by FAT32
fatinfo - fatinfo - print information about filesystem
fatload - fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
fdisk   - fdisk for sd/mmc.
go      - start application at address 'addr'
help    - print command description/usage
icache  - enable or disable instruction cache
iminfo  - print header information for application image
imxtract- extract a part of a multi-image
itest   - return true/false on integer compare
loadb   - load binary file over serial line (kermit mode)
2.打印系统环境变量:print
TINY4412 # pr
baudrate=115200
bootargs=noinitrd root=/dev/nfs nfsroot=192.168.10.106:/root/work/root_nfs ip=192.168.10.123:192.168.10.106:192.168.10.1:255.255.255.0::eth0:off init=/linuxrc console=ttySAC0 lcd=S702
bootcmd=movi read kernel 0 40008000;movi read rootfs 0 41000000 400000;bootm 40008000 41000000
bootdelay=3
ethaddr=00:40:5c:26:0a:5b
gatewayip=192.168.0.1
ipaddr=192.168.0.20
netmask=255.255.255.0
serverip=192.168.0.10
Environment size: 438/16380 bytes
3.设置保存环境变量
TINY4412 # set wbyq "uboot test" #设置环境变量
TINY4412 # save #保存环境变量
Saving Environment to SMDK bootable device...
done
4.串口传输二进制文件到DDR:laody
  用法:loady [内存地址] [波特率]
TINY4412 # ? loady
loady - load binary file over serial line (ymodem mode)
Usage:
loady [ off ] [ baud ]
   - load binary file over serial line with offset 'off' and baudrate 'baud'
  [ off ] [ baud ]为选填参数。不填则有由系统选择。
  • 示例:
pYYBAGMiq16ALsWFAAEnj-8P_7I875.png#pic_center
TINY4412 # loady 40008000  #启动接收
## Ready for binary (ymodem) download to 0x40008000 at 0 bps...
CCCCCC
 ymodem  trl+C ȡ
正在传输 main.bin...
 100%     656   164 /0:00:04       1
## Total Size      = 0x00000290 = 656 Bytes
TINY4412 # go 40008000 #调到指定地址执行
## Starting application at 0x40008000 ...
poYBAGMiq16AAoU3AAJf-dx6UV4938.png#pic_center
5.磁盘分区命令:fdisk
  • 用法:
      fdisk -p <设备号>
      fdisk -c <设备号> [<系统分区大小(MB)> <用户数据分区大小> <缓存分区大小>]
      fdisk命令一次实现4个分区
TINY4412 # ? fdisk
Usage:
fdisk -p    - print partition information
fdisk -c  []
       - create partition
  • 示例:
TINY4412 # fdisk -p 0 #查看设备0分区信息
partion #    size(MB)     block start #    block count    partition_Id
  1         14764           309248        30236672          0x0C
TINY4412 # fdisk -c 0 1024 1024 1024 #设置分区
fdisk is completed
  1         11715          6422528        23993344          0x0C
  2          1024           131072         2097152          0x83
  3          1024          2228224         2097152          0x83
  4          1024          4325376         2097152          0x83
6.安装文件系统
  当前uboot命令中支持文件系统格式有ext2、ext3、fat32。
pYYBAGMiq16AUBH_AACybA0ds3A363.png#pic_center
  • 安装文件示例
      下面以fat32为例安装文件系统。
       用法:fatformat mmc <设备号:分区号>
TINY4412 # ? fatformat
fatformat - fatformat - disk format by FAT32
Usage:
fatformat
       - format by FAT32 on 'interface'
TINY4412 # fatformat mmc 0:1
Start format MMC&d partition&d ...
Partition1: Start Address(0x620000), Size(0x16e1c00)
size checking ...
Under 16G
write FAT info: 32
Fat size : 0x2dc3
Erase FAT region...................................................................................................................................................
(only>
poYBAGMiq1-AYAW5AAEEcWVlOZ8691.png#pic_centerpYYBAGMiq1-APad5AAJ6K51BLh0452.png#pic_center
7.查看设备指定目录下文件:fatls
  • 用法:
      fatls  <设备号:分区号> [目录路径]
TINY4412 # ? fatls
Usage:
fatls  [directory]
   - list files from 'dev' on 'interface' in a 'directory'
//查看设备0的根目录下的文件
TINY4412 # fatls mmc 0 /
Partition1: Start Address(0x4b800), Size(0x1cd6000)
           system volume information/
           images/
0 file(s), 2 dir(s)
[:part]>
7.加载设备中二进制文件到内存:fatload
  • 用法:
      fatls  <设备号:分区号> <内存地址> <文件名> [加载字节数]
TINY4412 # ? fatload
Usage:
fatload  [bytes]
   - load binary file 'filename' from 'dev' on 'interface'
     to address 'addr' from dos filesystem
//从设备0中读取mian.bin文件到40008000
TINY4412 # fatload  mmc 0 40008000 /main.bin
reading /main.bin
656 bytes read
//跳转到40008000中执行main.bin文件
[:part]>
9.mmc子系统
  • mmc命令功能
  1. mmc read 从指定设备中读数据到内存
  2. mmc write 将指定内存中的数据写到设备中
  3. mmc rescan 扫描检测硬件改动
  4. mmc erase 擦除
  5. mmc list列举可用设备
TINY4412 # ? mmc
mmc - MMC sub system
Usage:
mmc read  addr blk# cnt   #从设备中读取数据到内存中
mmc write  addr blk# cnt  #将地址中的数据写入到设备中
mmc rescan
mmc erase
mmc list - lists available devices
//从设备0中第1057个扇区连续读12288个扇区到40009000地址中
TINY4412 # mmc read 0 40009000 421 3000
MMC read: dev # 0, block # 1057, count 12288 ... 12288 blocks read: OK
//跳转到40009000中执行
TINY4412 # bootm 40009000
10.movi子系统
  • movi命令功能
movi init 初始化和显示设备信息。
movi read 从sd或mmc中读bl1.bin、bl2.bin、uboot、kernel、tzsw.bin文件到指定内存地址中。
movi write 将指定内存地址中bl1.bin、bl2.bin、uboot、kernel、tzsw.bin写入到sd或mmc中。
movi read rootfs读根文件系统到指定内存地址中。
movi write rootfs将指定内存地址中根文件系统写入到sd或mmc中。
TINY4412 # ? movi
movi - movi     - sd/mmc r/w sub system for SMDK board
Usage:
movi init - Initialize moviNAND and show card info
movi read zero {fwbl1 | u-boot} {device_number} {addr} - Read data from sd/mmc
movi write zero {fwbl1 | u-boot} {device_number} {addr} - Read data from sd/mmc
movi read {u-boot | kernel} {device_number} {addr} - Read data from sd/mmc
movi write {fwbl1 | u-boot | kernel} {device_number} {addr} - Write data to sd/mmc
movi read rootfs {device_number} {addr} [bytes(hex)] - Read rootfs data from sd/mmc by size
movi write rootfs {device_number} {addr} [bytes(hex)] - Write rootfs data to sd/mmc by size
movi read {sector#} {device_number} {bytes(hex)} {addr} - instead of this, you can use "mmc read"
movi write {sector#} {device_number} {bytes(hex)} {addr} - instead of this, you can use "mmc write"
  tiny4412开发板bl1、bl2、uboot、kernel、tzsw、rootfs在SD卡和EMMC中存储格式:
poYBAGMiq1-AbisLAACRnNui4z4039.png#pic_center
  将bl1、bl2、uboot、kernel从SD卡拷贝到EMMC中示例:
//从设备0读取bl1.bin到内存,再写入到设备1中
movi r f 0 40008000;emmc open 1;movi w z f 1 40008000;emmc close 1;
//从设备0读取bl2.bin到内存,再写入到设备1中
movi r b 0 40008000;emmc open 1;movi w z b 1 40008000;emmc close 1;
//从设备0读取完整uboot到内存,再写入到设备1中
movi r u 0 40008000;emmc open 1;movi w z u 1 40008000;emmc close 1;
//从设备0读取kernel到内存,再写入到设备1中
movi r k 0 40008000;movi w k 1 40008000;
 注意:由于SD卡存储和EMMC存储bl1、bl2、uboot、tzsw这几个文件时总是相册一个扇区,所以从EMMC中读取bl1、bl2、uboot、tzsw这几个文件时要使用movi read zero命令来完成。写入bl1、bl2、uboot、tzsw这几个文件到EMMC时要使用movi write zero命令来完成 。
2022-09-21 00:05:55     打赏
谢谢分享  看看
2022-09-21 03:17:30     打赏
感谢楼主的分享,很实用了。
2022-09-21 06:26:31     打赏
感谢楼主的分享
2022-09-21 06:39:20     打赏
感谢分享!
2022-09-21 06:42:26     打赏
学习
2022-09-21 06:43:32     打赏
2022-09-21 07:03:57     打赏
2022-09-21 07:05:07     打赏
2022-09-21 07:12:38     打赏
共12条 1/2 1 2 跳转至
