电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » IPQ4019IPQ6010QCN9074highpowerwifirouter
IPQ4019IPQ6010QCN9074highpowerwifiroutersupportopenWRT/Wallys
2022-12-08 09:49:53     打赏
IPQ4019 IPQ6010 QCN9074 high power wifi router support openWRT/Wallys
In this article,we’ll discuss about the openWRT and 2 of wallys routerboards which support openWRT,DR6018 and DR4019S.
OpenWRT can be described as an embedded Linux distribution. (mainstream router firmware dd-wrt, tomato, openwrt, padavan four class) compared to a single, static system, openwrt package management provides a completely writable file system, from the application suppliers selection and configuration, and allows you to customize the device, so as to adapt to any application.
The function of the openwrt are as below
1. Openwrt can be used as a client to connect to other wifi as a WAN, and then create its own wifi as a LAN, which is equivalent to the wired WAN port to realize wifi Internet access without inserting a network cable. Other firmware seems to have no such setting mode, I don't know if I didn't find it. Usually, other firmware can only relay other wifi. The client is actually connected to the wifi of this relay, and the IP address is also assigned by the superior relay wifi, so it is not possible to create a sub-network through this router. The advantage of OpenwrT is that it connects to the Internet through wifi, creates a subnet by itself, and allows port mapping and rate limiting.
2. SSH tunnel
OpenWrt includes an SSH server so you can access its terminals. After exposing its SSH service to the network (don't forget to encrypt it with key authentication rather than a weak password), you can connect remotely and access it using SSH tunnel encryption. This allows you to use public Wi-Fi to access sites that are only accessible at home.
3. Set up VPN
SSH tunnels and VPNS are similar in many ways, but you can still build your own VPN on OpenWrt routes.
4. Install the BitTorrent client
If you have a specific network attached memory (NAS), or a router that comes with a USB port and a USB device, you can use the router as a BitTorrent client.
5. Run the server software
OpenWrt's software source includes packages that allow it to function as a Web server, such as IRCserver, BitTorrenttracker, and more. You're probably using a router, so why not just use that router as a server? A router uses much less power than a computer, so it's smart to use it as a lightweight server.
6. Traffic shaping service
OpenWrt lets you perform packet shaping on routed packets and check their quality of service (qos), assigning appropriate packets first. You can even assign a given packet to a given computer first and defer processing of packets assigned to other computers.
7. Create a VIP network
The OpenWrt wiki has instructions on how to set up a special wireless network for guests, which is separate from your main network for security purposes. You can even limit the speed of the VIP network.
8. Capture and analyze network traffic
You can use tcpdump to record all packets that pass through your router. You can then share it online or use tools like Wireshark to open it and analyze your network traffic and behavior.
DR6018
QCN9074,WIFI 6E,IPQ6010,802.11AX
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
DR4019S
IPQ4019,802.11AC,2.4G/5G DUAL BANDS
Featuring withindustrial-grade IPQ4019 chipset
Integrated with 2x 2 5G high power
Radio module and 2x2 2.4G high power Radio module
Support 5.180GHz to5.825GHz Frequency Range;
Support 2.412GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/802.11AC
RoHS compliance ensure a high level
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Email us by sales1@wallystech.com
For more information,visit our website:https://www.wallystech.com/
关键词: IPQ4019     IPQ6010     QCN9074     p
