电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » QCN9024QCN9074MU-MIMO4X46GHzwifi6M.2/Wal
共9条 1/1 1 跳转至页
QCN9024QCN9074MU-MIMO4X46GHzwifi6M.2/Wallys802.11axcardDR9074-5G(PN02.1)
2022-12-20 11:23:08     打赏
QCN9024 QCN9074 MU-MIMO 4X4 6GHz wifi6 M.2/Wallys 802.11ax card DR9074-5G(PN02.1)
802.11ac and 802.11ax are different wireless (WiFi) technology standards that are present in WiFi routers or gateways.WiFi and Internet capabilities are constantly evolving. Up until 2019, the most common wireless standard called for 802.11ac, also referred to as WiFi 5. However, in late 2019, 802.11ax (also known as WiFi 6) was launched, providing enhanced capabilities over its predecessor. These two WiFi standards are important to understand because they determine what devices you will need for your home network, which features they support, and the overall performance of your WiFi.
Here are wallys 802.11ax boards and cards.
DR6018 V4
DR6018C V01
DR6018-S V02
DR8072 V01
DR5018
DR9074-6E(PN02.7)
DR9074-5G(PN02.1)
DR9074-2.4G(PN01.1)
We have introduced DR6018V4,DR6018C V01,DR6018-S V02,DR8072 V01,DR5018 in previous articles and today let’s talk about wallys card the DR9074-5G(PN02.1).
DR9074-5G(PN02.1)
QCN9074,802.11AX,WIFI6,4X4,MU-MIMO,5GHz,M.2
This is a card integrated with Qualcomm Atheros QCN9074 CPU, 5GHz, max 23dBm per chain, up to 4949Mbps,Single Band 5GHz 4x4 WiFi 6 (802.11ax),4 spatial streams (4SS),M.2 E Key Interface,PCI Express 3.0 Interface,Supports Dynamic Frequency Selection (DFS)
Regard to the Absolute Maximum Rating,we’ll introduce from 4 perspectives parameters:Operating Temperature Range,Storage Temperature Range,Operating Humidity Range and Storage Humidity Range.
For the Operating Temperature Range,it is -20 to +70ºC.
For the Storage Temperature Range,it is -40 to +90ºC.
For the Operating Humidity Range,it is 5 to +95 (non-condensing)%.
For the Storage Humidity Range,It is 0 to +90 (non-condensing)%.
Regard to the Hardware Specifications,we’ll introduce from 16 perspectives:
For the CPU,it is Qualcomm Atheros QCN9074.
For the WLAN Host Interface,it is PCI Express 3.0 Interface.
For the System Memory,it is 2Mbit serial I²C bus EEPROM.
For the Standard Operating Voltage,it is 5V
For the Operating Systems,it is QSDK
For the Host Interface,it is M.2 E Key
For the Antenna Cable / Port,it is 4 x MMCX Connectors,4T4R
For the Frequency Range,it is 5.15GHz-5.95GHz
For the Data Rates for WALN,it is 5GHz, max 23dBm per chain, up to 4949Mbps
For the Channel Spectrum Widths for WLAN,It support 20/40/80/160MHz at 5GHz.
For the Modulation Techniques,It is OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
For the Certification,TBD
For the Power Consumption,TBD
For the Reference Design,It is PN02.1
For the Dimensions (WxHxD),It is 57mm x 63mm x 6mm.
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
Email us by https://www.wallystech.com/
关键词: QCN9024     QCN9074     MU-MIMO     w
2022-12-20 22:06:03     打赏
2022-12-20 22:59:23     打赏
感谢楼主分享
2022-12-23 09:27:51     打赏
2022-12-24 16:10:12     打赏
2022-12-25 12:13:29     打赏
2022-12-25 12:18:56     打赏
这是什么啊,全英文?看不懂
2022-12-26 16:24:52     打赏
2022-12-28 22:32:27     打赏
共9条 1/1 1 跳转至页
