电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » Wallystech|MT7915MT7975MediaTekchipsetwi
共4条 1/1 1 跳转至
Wallystech|MT7915MT7975MediaTekchipsetwifi6dualbandcard
2023-02-21 15:51:46     打赏
The MT7915 chipset is a Wi-Fi 6 (802.11ax) chip that offers 2x2 MIMO technology and can deliver up to 1.2Gbps of wireless data throughput on the 5GHz band. It supports 1024-QAM modulation and MU-MIMO, which allows multiple devices to connect to a single access point and stream data simultaneously. The MT7915 chipset also supports OFDMA, which improves wireless efficiency and reduces latency, making it ideal for real-time applications such as gaming and video streaming.
The MT7975 chipset, on the other hand, is designed for high-end routers and access points. It offers 4x4 MIMO technology and can deliver up to 3.5Gbps of wireless data throughput on the 5GHz band. The chipset also supports MU-MIMO and OFDMA, allowing it to handle multiple devices simultaneously and improve wireless efficiency. The MT7975 chipset is compatible with Wi-Fi 6E (802.11ax) and can operate on the newly available 6GHz band, providing additional spectrum for high-bandwidth applications.
Both chipsets support the 2.4GHz and 5GHz frequency bands and are backward compatible with earlier Wi-Fi standards such as 802.11ac/a/b/g/n. They also support a range of technologies, including Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio Combining (MRC), and Space Time Block Code (STBC), which enhance wireless performance and reliability.
The Media Tek MT7915 and MT7975 chipsets are designed to meet the high demands of modern wireless connectivity. They offer advanced features such as beamforming, which focuses wireless signals on specific devices, and Target Wake Time (TWT), which reduces power consumption by allowing devices to schedule their wireless transmissions.
These chipsets are also designed with security in mind, supporting WPA3, the latest wireless security protocol, which offers improved encryption and authentication.
Wallys Communications(Suzhou) Co.,Ltd is a specialized company that offers a range of wireless communication products, including Routerboard, Network Card, Industrial Wireless AP, Antenna, and more. One of their top-of-the-line products is the DR7915, which is a Mini PCI Express edge connector card that offers fast and reliable wireless connectivity.
The DR7915 is powered by the MT7915+MT7975 chipset and supports IEEE 802.11ac/ax standards while being backward compatible with 802.11ax/ac/a/b/g/n, making it ideal for a wide range of applications. It offers a 2×2 2.4G & 2×2 5G MIMO technology and can deliver up to 1.8Gbps of wireless data throughput. The device also supports a maximum output power of 23dBm on 2.4GHz and 20dBm on 5GHz, ensuring a strong and stable wireless connection.
The DR7915 supports the frequency range of 2412MHz to 2482MHz and 5180MHz to 5825MHz, providing flexibility in wireless network deployment. It also supports a range of technologies, including Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio Combining (MRC), and Space Time Block Code (STBC), which enhance wireless performance and reliability.
The DR7915 also supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards, as well as Dynamic Frequency Selection (DFS), ensuring compatibility and compliance with different wireless networking standards. The card is individually calibrated for quality assurance, ensuring high performance and reliability.
In addition, the DR7915 is RoHS compliant, ensuring a high level of protection of human health and the environment from risks that can be posed by chemicals.
Wallys Communications offers a range of services, including OEM/ODM/JDM services for wifi modules and customization services from idea design to manufacturing to product launch. Their professional R&D team has over 15 years of experience in the industry, and they take pride in providing high-quality products and services to their clients.
If you're interested in learning more about the DR7915 or any other products or services from Wallys Communications, you can contact them at sales1@wallystech.com, or visit their website at https://www.wallystech.com/
关键词: MT7915     MT7975     wifi6     wirel
2023-02-21 21:54:18     打赏
2023-02-21 21:58:51     打赏
2023-02-21 22:31:41     打赏
共4条 1/1 1 跳转至
站长统计
有奖问卷
英飞凌400V CoolSiC™重新定义高性能电源设计的功率密度和效率,含有奖小问卷,限前200名工程师!
