MOTOROLA上海汽车电子研发中心招聘模拟电路设计工程师,要求如下:
Job Description:
Highly skilled technologist whose focus is the design of analog circuits, architecture, system simulation, verification, layout supervision, debug, characterization, and transfer to production. Typically has a Bachelor or Master's of Science degree in Electrical Engineering. Experience level depends on the job requirements.
Experiences and ability: Have designed basic analog and digital signal processing circuit Be able to check and analysis signal by Oscilloscope Have known anti- electromagnetism interfering general method Have designed power supply transform circuit and DC to AC or AC to DC Familiar automobile electronic technique and application environment
有意者请将个人中英文简历发送至如下邮箱:richy.sun@motorola.com。
[align=right][color=#000066][此贴子已经被作者于2004-11-23 17:30:47编辑过][/color][/align]
