STM32C0单片机的主频为48Mhz,内核为cortexM0+,与架构与G0一样。ROM/RAM根据型号不同从16k-32k/6k-12k不等,不同封装的芯片引脚数量从8个到48个。非常适合低功耗小巧的设计。用起来感觉和G0 L0系列差不多。
驱动手表1.28寸屏,原理图:
驱动PIN
// VCC 3.3V
// SCL PA0
// SDA PA1
// RES PA2
// DC PA3
// CS PA4
// BLK PA5
GPIO初始化:
void LCD_GPIO_Init(void)
GPIO_InitTypeDef GPIO_InitStruct;
__HAL_RCC_GPIOA_CLK_ENABLE();
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5,GPIO_PIN_SET);
}void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
Error_Handler();
}配置代码:
#include "lcd_init.h"
#include "delay.h"
void LCD_Writ_Bus(u8 dat)
u8 i;
LCD_CS_Clr();
for(i=0;i<8;i++)
LCD_SCLK_Clr();
if(dat&0x80)
LCD_MOSI_Set();
else
LCD_MOSI_Clr();
LCD_SCLK_Set();
dat<<=1;
LCD_CS_Set();
void LCD_WR_DATA8(u8 dat)
LCD_Writ_Bus(dat);
void LCD_WR_DATA(u16 dat)
LCD_Writ_Bus(dat>>8);
LCD_Writ_Bus(dat);
void LCD_WR_REG(u8 dat)
LCD_DC_Clr();//дÃüÁî
LCD_Writ_Bus(dat);
LCD_DC_Set();//дÊý¾Ý
void LCD_Address_Set(u16 x1,u16 y1,u16 x2,u16 y2)
LCD_WR_REG(0x2a);//ÁеØÖ·ÉèÖÃ
LCD_WR_DATA(x1);
LCD_WR_DATA(x2);
LCD_WR_REG(0x2b);//ÐеØÖ·ÉèÖÃ
LCD_WR_DATA(y1);
LCD_WR_DATA(y2);
LCD_WR_REG(0x2c);//´¢´æÆ÷д
void LCD_Init(void)
LCD_GPIO_Init();//³õʼ»¯GPIO
LCD_RES_Clr();//¸´Î»
delay_ms(100);
LCD_RES_Set();
delay_ms(100);
LCD_BLK_Set();//´ò¿ª±³¹â
delay_ms(100);
LCD_WR_REG(0xEF);
LCD_WR_REG(0xEB);
LCD_WR_DATA8(0x14);
LCD_WR_REG(0xFE);
LCD_WR_REG(0xEF);
LCD_WR_REG(0xEB);
LCD_WR_DATA8(0x14);
LCD_WR_REG(0x84);
LCD_WR_DATA8(0x40);
LCD_WR_REG(0x85);
LCD_WR_DATA8(0xFF);
LCD_WR_REG(0x86);
LCD_WR_DATA8(0xFF);
LCD_WR_REG(0x87);
LCD_WR_DATA8(0xFF);
LCD_WR_REG(0x88);
LCD_WR_DATA8(0x0A);
LCD_WR_REG(0x89);
LCD_WR_DATA8(0x21);
LCD_WR_REG(0x8A);
LCD_WR_DATA8(0x00);
LCD_WR_REG(0x8B);
LCD_WR_DATA8(0x80);
LCD_WR_REG(0x8C);
LCD_WR_DATA8(0x01);
LCD_WR_REG(0x8D);
LCD_WR_DATA8(0x01);
LCD_WR_REG(0x8E);
LCD_WR_DATA8(0xFF);
LCD_WR_REG(0x8F);
LCD_WR_DATA8(0xFF);
LCD_WR_REG(0xB6);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x20);
LCD_WR_REG(0x36);
if(USE_HORIZONTAL==0)LCD_WR_DATA8(0x08);
else if(USE_HORIZONTAL==1)LCD_WR_DATA8(0xC8);
else if(USE_HORIZONTAL==2)LCD_WR_DATA8(0x68);
else LCD_WR_DATA8(0xA8);
LCD_WR_REG(0x3A);
LCD_WR_DATA8(0x05);
LCD_WR_REG(0x90);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x08);
LCD_WR_REG(0xBD);
LCD_WR_DATA8(0x06);
LCD_WR_REG(0xBC);
LCD_WR_DATA8(0x00);
LCD_WR_REG(0xFF);
LCD_WR_DATA8(0x60);
LCD_WR_DATA8(0x01);
LCD_WR_DATA8(0x04);
LCD_WR_REG(0xC3);
LCD_WR_DATA8(0x13);
LCD_WR_REG(0xC4);
LCD_WR_DATA8(0x13);
LCD_WR_REG(0xC9);
LCD_WR_DATA8(0x22);
LCD_WR_REG(0xBE);
LCD_WR_DATA8(0x11);
LCD_WR_REG(0xE1);
LCD_WR_DATA8(0x10);
LCD_WR_DATA8(0x0E);
LCD_WR_REG(0xDF);
LCD_WR_DATA8(0x21);
LCD_WR_DATA8(0x0c);
LCD_WR_DATA8(0x02);
LCD_WR_REG(0xF0);
LCD_WR_DATA8(0x45);
LCD_WR_DATA8(0x09);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x26);
LCD_WR_DATA8(0x2A);
LCD_WR_REG(0xF1);
LCD_WR_DATA8(0x43);
LCD_WR_DATA8(0x70);
LCD_WR_DATA8(0x72);
LCD_WR_DATA8(0x36);
LCD_WR_DATA8(0x37);
LCD_WR_DATA8(0x6F);
LCD_WR_REG(0xF2);
LCD_WR_DATA8(0x45);
LCD_WR_DATA8(0x09);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x26);
LCD_WR_DATA8(0x2A);
LCD_WR_REG(0xF3);
LCD_WR_DATA8(0x43);
LCD_WR_DATA8(0x70);
LCD_WR_DATA8(0x72);
LCD_WR_DATA8(0x36);
LCD_WR_DATA8(0x37);
LCD_WR_DATA8(0x6F);
LCD_WR_REG(0xED);
LCD_WR_DATA8(0x1B);
LCD_WR_DATA8(0x0B);
LCD_WR_REG(0xAE);
LCD_WR_DATA8(0x77);
LCD_WR_REG(0xCD);
LCD_WR_DATA8(0x63);
LCD_WR_REG(0x70);
LCD_WR_DATA8(0x07);
LCD_WR_DATA8(0x07);
LCD_WR_DATA8(0x04);
LCD_WR_DATA8(0x0E);
LCD_WR_DATA8(0x0F);
LCD_WR_DATA8(0x09);
LCD_WR_DATA8(0x07);
LCD_WR_DATA8(0x08);
LCD_WR_DATA8(0x03);
LCD_WR_REG(0xE8);
LCD_WR_DATA8(0x34);
LCD_WR_REG(0x62);
LCD_WR_DATA8(0x18);
LCD_WR_DATA8(0x0D);
LCD_WR_DATA8(0x71);
LCD_WR_DATA8(0xED);
LCD_WR_DATA8(0x70);
LCD_WR_DATA8(0x70);
LCD_WR_DATA8(0x18);
LCD_WR_DATA8(0x0F);
LCD_WR_DATA8(0x71);
LCD_WR_DATA8(0xEF);
LCD_WR_DATA8(0x70);
LCD_WR_DATA8(0x70);
LCD_WR_REG(0x63);
LCD_WR_DATA8(0x18);
LCD_WR_DATA8(0x11);
LCD_WR_DATA8(0x71);
LCD_WR_DATA8(0xF1);
LCD_WR_DATA8(0x70);
LCD_WR_DATA8(0x70);
LCD_WR_DATA8(0x18);
LCD_WR_DATA8(0x13);
LCD_WR_DATA8(0x71);
LCD_WR_DATA8(0xF3);
LCD_WR_DATA8(0x70);
LCD_WR_DATA8(0x70);
LCD_WR_REG(0x64);
LCD_WR_DATA8(0x28);
LCD_WR_DATA8(0x29);
LCD_WR_DATA8(0xF1);
LCD_WR_DATA8(0x01);
LCD_WR_DATA8(0xF1);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x07);
LCD_WR_REG(0x66);
LCD_WR_DATA8(0x3C);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0xCD);
LCD_WR_DATA8(0x67);
LCD_WR_DATA8(0x45);
LCD_WR_DATA8(0x45);
LCD_WR_DATA8(0x10);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x00);
LCD_WR_REG(0x67);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x3C);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x01);
LCD_WR_DATA8(0x54);
LCD_WR_DATA8(0x10);
LCD_WR_DATA8(0x32);
LCD_WR_DATA8(0x98);
LCD_WR_REG(0x74);
LCD_WR_DATA8(0x10);
LCD_WR_DATA8(0x85);
LCD_WR_DATA8(0x80);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x4E);
LCD_WR_DATA8(0x00);
LCD_WR_REG(0x98);
LCD_WR_DATA8(0x3e);
LCD_WR_DATA8(0x07);
LCD_WR_REG(0x35);
LCD_WR_REG(0x21);
LCD_WR_REG(0x11);
delay_ms(120);
LCD_WR_REG(0x29);
delay_ms(20);
}功能代码
#include "lcd.h"
#include "lcdfont.h"
#include "delay.h"
void LCD_Fill(u16 xsta,u16 ysta,u16 xend,u16 yend,u16 color)
u16 i,j;
LCD_Address_Set(xsta,ysta,xend-1,yend-1);//ÉèÖÃÏÔʾ·¶Î§
for(i=ysta;i<yend;i++)
for(j=xsta;j<xend;j++)
LCD_WR_DATA(color);
void LCD_DrawPoint(u16 x,u16 y,u16 color)
LCD_Address_Set(x,y,x,y);//ÉèÖùâ±êλÖÃ
LCD_WR_DATA(color);
º¯Êý˵Ã÷£º»Ïß
Èë¿ÚÊý¾Ý£ºx1,y1 ÆðÊ¼×ø±ê
x2,y2 ÖÕÖ¹×ø±ê
color ÏßµÄÑÕÉ«
·µ»ØÖµ£º ÎÞ
void LCD_DrawLine(u16 x1,u16 y1,u16 x2,u16 y2,u16 color)
u16 t;
int xerr=0,yerr=0,delta_x,delta_y,distance;
int incx,incy,uRow,uCol;
delta_x=x2-x1; //¼ÆËã×ø±êÔöÁ¿
delta_y=y2-y1;
uRow=x1;//»Ï߯ðµã×ø±ê
uCol=y1;
if(delta_x>0)incx=1; //ÉèÖõ¥²½·½Ïò
else if (delta_x==0)incx=0;//´¹Ö±Ïß
else {incx=-1;delta_x=-delta_x;}
if(delta_y>0)incy=1;
else if (delta_y==0)incy=0;//ˮƽÏß
else {incy=-1;delta_y=-delta_y;}
if(delta_x>delta_y)distance=delta_x; //ѡȡ»ù±¾ÔöÁ¿×ø±êÖá
else distance=delta_y;
for(t=0;t<distance+1;t++)
LCD_DrawPoint(uRow,uCol,color);//»µã
xerr+=delta_x;
yerr+=delta_y;
if(xerr>distance)
xerr-=distance;
uRow+=incx;
if(yerr>distance)
yerr-=distance;
uCol+=incy;
º¯Êý˵Ã÷£º»¾ØÐÎ
x2,y2 ÖÕÖ¹×ø±ê
color ¾ØÐεÄÑÕÉ«
·µ»ØÖµ£º ÎÞ
void LCD_DrawRectangle(u16 x1, u16 y1, u16 x2, u16 y2,u16 color)
LCD_DrawLine(x1,y1,x2,y1,color);
LCD_DrawLine(x1,y1,x1,y2,color);
LCD_DrawLine(x1,y2,x2,y2,color);
LCD_DrawLine(x2,y1,x2,y2,color);
º¯Êý˵Ã÷£º»Ô²
Èë¿ÚÊý¾Ý£ºx0,y0 Ô²ÐÄ×ø±ê
r °ë¾¶
color Ô²µÄÑÕÉ«
·µ»ØÖµ£º ÎÞ
void Draw_Circle(u16 x0,u16 y0,u8 r,u16 color)
int a,b;
a=0;b=r;
while(a<=b)
LCD_DrawPoint(x0-b,y0-a,color); //3
LCD_DrawPoint(x0+b,y0-a,color); //0
LCD_DrawPoint(x0-a,y0+b,color); //1
LCD_DrawPoint(x0-a,y0-b,color); //2
LCD_DrawPoint(x0+b,y0+a,color); //4
LCD_DrawPoint(x0+a,y0-b,color); //5
LCD_DrawPoint(x0+a,y0+b,color); //6
LCD_DrawPoint(x0-b,y0+a,color); //7
a++;
if((a*a+b*b)>(r*r))//ÅжÏÒª»µÄµãÊÇ·ñ¹ýÔ¶
b--;
º¯Êý˵Ã÷£ºÏÔʾºº×Ö´®
Èë¿ÚÊý¾Ý£ºx,yÏÔÊ¾×ø±ê
*s ÒªÏÔʾµÄºº×Ö´®
fc ×ÖµÄÑÕÉ«
bc ×ֵı³¾°É«
sizey ×ֺŠ¿ÉÑ¡ 16 24 32
mode: 0·Çµþ¼Óģʽ 1µþ¼Óģʽ
·µ»ØÖµ£º ÎÞ
void LCD_ShowChinese(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
while(*s!=0)
if(sizey==12) LCD_ShowChinese12x12(x,y,s,fc,bc,sizey,mode);
else if(sizey==16) LCD_ShowChinese16x16(x,y,s,fc,bc,sizey,mode);
else if(sizey==24) LCD_ShowChinese24x24(x,y,s,fc,bc,sizey,mode);
else if(sizey==32) LCD_ShowChinese32x32(x,y,s,fc,bc,sizey,mode);
else return;
s+=2;
x+=sizey;
º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö12x12ºº×Ö
*s ÒªÏÔʾµÄºº×Ö
fc ×ÖµÄÑÕÉ«
bc ×ֵı³¾°É«
sizey ×ÖºÅ
·µ»ØÖµ£º ÎÞ
void LCD_ShowChinese12x12(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
u8 i,j,m=0;
u16 k;
u16 HZnum;//ºº×ÖÊýÄ¿
u16 TypefaceNum;//Ò»¸ö×Ö·ûËùÕ¼×Ö½Ú´óС
u16 x0=x;
TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
HZnum=sizeof(tfont12)/sizeof(typFNT_GB12); //ͳ¼Æºº×ÖÊýÄ¿
for(k=0;k<HZnum;k++)
if((tfont12[k].Index[0]==*(s))&&(tfont12[k].Index[1]==*(s+1)))
LCD_Address_Set(x,y,x+sizey-1,y+sizey-1);
for(i=0;i<TypefaceNum;i++)
for(j=0;j<8;j++)
if(!mode)//·Çµþ¼Ó·½Ê½
if(tfont12[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
else LCD_WR_DATA(bc);
m++;
if(m%sizey==0)
m=0;
break;
else//µþ¼Ó·½Ê½
if(tfont12[k].Msk[i]&(0x01<<j)) LCD_DrawPoint(x,y,fc);//»Ò»¸öµã
x++;
if((x-x0)==sizey)
x=x0;
y++;
break;
continue; //²éÕÒµ½¶ÔÓ¦µãÕó×Ö¿âÁ¢¼´Í˳ö£¬·ÀÖ¹¶à¸öºº×ÖÖØ¸´È¡Ä£´øÀ´Ó°Ïì
º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö16x16ºº×Ö
*s ÒªÏÔʾµÄºº×Ö
fc ×ÖµÄÑÕÉ«
bc ×ֵı³¾°É«
sizey ×ÖºÅ
·µ»ØÖµ£º ÎÞ
void LCD_ShowChinese16x16(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
u8 i,j,m=0;
u16 k;
u16 x0=x;
HZnum=sizeof(tfont16)/sizeof(typFNT_GB16); //ͳ¼Æºº×ÖÊýÄ¿
if ((tfont16[k].Index[0]==*(s))&&(tfont16[k].Index[1]==*(s+1)))
for(j=0;j<8;j++)
if(tfont16[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
m++;
if(m%sizey==0)
m=0;
break;
else//µþ¼Ó·½Ê½
if(tfont16[k].Msk[i]&(0x01<<j)) LCD_DrawPoint(x,y,fc);//»Ò»¸öµã
x++;
if((x-x0)==sizey)
x=x0;
y++;
break;
º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö24x24ºº×Ö
*s ÒªÏÔʾµÄºº×Ö
fc ×ÖµÄÑÕÉ«
bc ×ֵı³¾°É«
sizey ×ÖºÅ
·µ»ØÖµ£º ÎÞ
void LCD_ShowChinese24x24(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
u8 i,j,m=0;
u16 k;
u16 x0=x;
HZnum=sizeof(tfont24)/sizeof(typFNT_GB24); //ͳ¼Æºº×ÖÊýÄ¿
if ((tfont24[k].Index[0]==*(s))&&(tfont24[k].Index[1]==*(s+1)))
for(j=0;j<8;j++)
if(tfont24[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
m++;
if(m%sizey==0)
m=0;
break;
else//µþ¼Ó·½Ê½
if(tfont24[k].Msk[i]&(0x01<<j)) LCD_DrawPoint(x,y,fc);//»Ò»¸öµã
x++;
if((x-x0)==sizey)
x=x0;
y++;
break;
º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö32x32ºº×Ö
*s ÒªÏÔʾµÄºº×Ö
fc ×ÖµÄÑÕÉ«
bc ×ֵı³¾°É«
sizey ×ÖºÅ
·µ»ØÖµ£º ÎÞ
void LCD_ShowChinese32x32(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
u8 i,j,m=0;
u16 k;
u16 x0=x;
HZnum=sizeof(tfont32)/sizeof(typFNT_GB32); //ͳ¼Æºº×ÖÊýÄ¿
if ((tfont32[k].Index[0]==*(s))&&(tfont32[k].Index[1]==*(s+1)))
for(j=0;j<8;j++)
if(tfont32[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
m++;
if(m%sizey==0)
m=0;
break;
else//µþ¼Ó·½Ê½
if(tfont32[k].Msk[i]&(0x01<<j)) LCD_DrawPoint(x,y,fc);//»Ò»¸öµã
x++;
if((x-x0)==sizey)
x=x0;
y++;
break;
º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö×Ö·û
num ÒªÏÔʾµÄ×Ö·û
fc ×ÖµÄÑÕÉ«
bc ×ֵı³¾°É«
sizey ×ÖºÅ
·µ»ØÖµ£º ÎÞ
void LCD_ShowChar(u16 x,u16 y,u8 num,u16 fc,u16 bc,u8 sizey,u8 mode)
u8 temp,sizex,t,m=0;
u16 i,TypefaceNum;//Ò»¸ö×Ö·ûËùÕ¼×Ö½Ú´óС
u16 x0=x;
sizex=sizey/2;
TypefaceNum=(sizex/8+((sizex%8)?1:0))*sizey;
num=num-' '; //µÃµ½Æ«ÒƺóµÄÖµ
LCD_Address_Set(x,y,x+sizex-1,y+sizey-1); //ÉèÖùâ±êλÖÃ
if(sizey==12)temp=ascii_1206[num][i]; //µ÷ÓÃ6x12×ÖÌå
else if(sizey==16)temp=ascii_1608[num][i]; //µ÷ÓÃ8x16×ÖÌå
else if(sizey==24)temp=ascii_2412[num][i]; //µ÷ÓÃ12x24×ÖÌå
else if(sizey==32)temp=ascii_3216[num][i]; //µ÷ÓÃ16x32×ÖÌå
else return;
for(t=0;t<8;t++)
if(!mode)//·Çµþ¼Óģʽ
if(temp&(0x01<<t))LCD_WR_DATA(fc);
m++;
if(m%sizex==0)
m=0;
break;
else//µþ¼Óģʽ
if(temp&(0x01<<t))LCD_DrawPoint(x,y,fc);//»Ò»¸öµã
x++;
if((x-x0)==sizex)
x=x0;
y++;
break;
º¯Êý˵Ã÷£ºÏÔʾ×Ö·û´®
*p ÒªÏÔʾµÄ×Ö·û´®
fc ×ÖµÄÑÕÉ«
bc ×ֵı³¾°É«
sizey ×ÖºÅ
·µ»ØÖµ£º ÎÞ
void LCD_ShowString(u16 x,u16 y,const u8 *p,u16 fc,u16 bc,u8 sizey,u8 mode)
while(*p!='\0')
LCD_ShowChar(x,y,*p,fc,bc,sizey,mode);
x+=sizey/2;
p++;
º¯Êý˵Ã÷£ºÏÔʾÊý×Ö
Èë¿ÚÊý¾Ý£ºmµ×Êý£¬nÖ¸Êý
·µ»ØÖµ£º ÎÞ
u32 mypow(u8 m,u8 n)
u32 result=1;
while(n--)result*=m;
return result;
º¯Êý˵Ã÷£ºÏÔʾÕûÊý±äÁ¿
num ÒªÏÔʾÕûÊý±äÁ¿
len ÒªÏÔʾµÄλÊý
fc ×ÖµÄÑÕÉ«
bc ×ֵı³¾°É«
sizey ×ÖºÅ
·µ»ØÖµ£º ÎÞ
void LCD_ShowIntNum(u16 x,u16 y,u16 num,u8 len,u16 fc,u16 bc,u8 sizey)
u8 t,temp;
u8 enshow=0;
u8 sizex=sizey/2;
for(t=0;t<len;t++)
temp=(num/mypow(10,len-t-1))%10;
if(enshow==0&&t<(len-1))
if(temp==0)
LCD_ShowChar(x+t*sizex,y,' ',fc,bc,sizey,0);
continue;
}else enshow=1;
LCD_ShowChar(x+t*sizex,y,temp+48,fc,bc,sizey,0);
º¯Êý˵Ã÷£ºÏÔʾÁ½Î»Ð¡Êý±äÁ¿
num ÒªÏÔʾСÊý±äÁ¿
len ÒªÏÔʾµÄλÊý
fc ×ÖµÄÑÕÉ«
bc ×ֵı³¾°É«
sizey ×ÖºÅ
·µ»ØÖµ£º ÎÞ
void LCD_ShowFloatNum1(u16 x,u16 y,float num,u8 len,u16 fc,u16 bc,u8 sizey)
u8 t,temp,sizex;
u16 num1;
sizex=sizey/2;
num1=num*100;
for(t=0;t<len;t++)
temp=(num1/mypow(10,len-t-1))%10;
if(t==(len-2))
LCD_ShowChar(x+(len-2)*sizex,y,'.',fc,bc,sizey,0);
t++;
len+=1;
º¯Êý˵Ã÷£ºÏÔʾͼƬ
Èë¿ÚÊý¾Ý£ºx,yÆðµã×ø±ê
length ͼƬ³¤¶È
width ͼƬ¿í¶È
pic[] ͼƬÊý×é
·µ»ØÖµ£º ÎÞ
void LCD_ShowPicture(u16 x,u16 y,u16 length,u16 width,const u8 pic[])
u16 i,j;
u32 k=0;
LCD_Address_Set(x,y,x+length-1,y+width-1);
for(i=0;i<length;i++)
for(j=0;j<width;j++)
LCD_WR_DATA8(pic[k*2]);
LCD_WR_DATA8(pic[k*2+1]);
k++;
