电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 基于STM32C0的手表设计
基于STM32C0的手表设计
2023-03-10 16:01:25     打赏
      STM32C0单片机的主频为48Mhz,内核为cortexM0+,与架构与G0一样。ROM/RAM根据型号不同从16k-32k/6k-12k不等,不同封装的芯片引脚数量从8个到48个。非常适合低功耗小巧的设计。用起来感觉和G0 L0系列差不多。
    驱动手表1.28寸屏,原理图:
驱动PIN
//              VCC  3.3V
//              SCL   PA0
//              SDA   PA1
//              RES   PA2
//              DC    PA3
//              CS    PA4
//              BLK   PA5
GPIO初始化:
void LCD_GPIO_Init(void)
GPIO_InitTypeDef GPIO_InitStruct;
  __HAL_RCC_GPIOA_CLK_ENABLE();
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5,GPIO_PIN_SET);
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
    Error_Handler();
配置代码:
#include "lcd_init.h"
#include "delay.h"
void LCD_Writ_Bus(u8 dat)
	u8 i;
	LCD_CS_Clr();
	for(i=0;i<8;i++)
		LCD_SCLK_Clr();
		if(dat&0x80)
		   LCD_MOSI_Set();
		else
		   LCD_MOSI_Clr();
		LCD_SCLK_Set();
		dat<<=1;
  LCD_CS_Set();
void LCD_WR_DATA8(u8 dat)
	LCD_Writ_Bus(dat);
void LCD_WR_DATA(u16 dat)
	LCD_Writ_Bus(dat>>8);
	LCD_Writ_Bus(dat);
void LCD_WR_REG(u8 dat)
	LCD_DC_Clr();//дÃüÁî
	LCD_Writ_Bus(dat);
	LCD_DC_Set();//дÊý¾Ý
void LCD_Address_Set(u16 x1,u16 y1,u16 x2,u16 y2)
		LCD_WR_REG(0x2a);//ÁеØÖ·ÉèÖÃ
		LCD_WR_DATA(x1);
		LCD_WR_DATA(x2);
		LCD_WR_REG(0x2b);//ÐеØÖ·ÉèÖÃ
		LCD_WR_DATA(y1);
		LCD_WR_DATA(y2);
		LCD_WR_REG(0x2c);//´¢´æÆ÷д
void LCD_Init(void)
	LCD_GPIO_Init();//³õʼ»¯GPIO
	LCD_RES_Clr();//¸´Î»
	delay_ms(100);
	LCD_RES_Set();
	delay_ms(100);
	LCD_BLK_Set();//´ò¿ª±³¹â
  delay_ms(100);
	LCD_WR_REG(0xEF);
	LCD_WR_REG(0xEB);
	LCD_WR_DATA8(0x14);
  LCD_WR_REG(0xFE);
	LCD_WR_REG(0xEF);
	LCD_WR_REG(0xEB);
	LCD_WR_DATA8(0x14);
	LCD_WR_REG(0x84);
	LCD_WR_DATA8(0x40);
	LCD_WR_REG(0x85);
	LCD_WR_DATA8(0xFF);
	LCD_WR_REG(0x86);
	LCD_WR_DATA8(0xFF);
	LCD_WR_REG(0x87);
	LCD_WR_DATA8(0xFF);
	LCD_WR_REG(0x88);
	LCD_WR_DATA8(0x0A);
	LCD_WR_REG(0x89);
	LCD_WR_DATA8(0x21);
	LCD_WR_REG(0x8A);
	LCD_WR_DATA8(0x00);
	LCD_WR_REG(0x8B);
	LCD_WR_DATA8(0x80);
	LCD_WR_REG(0x8C);
	LCD_WR_DATA8(0x01);
	LCD_WR_REG(0x8D);
	LCD_WR_DATA8(0x01);
	LCD_WR_REG(0x8E);
	LCD_WR_DATA8(0xFF);
	LCD_WR_REG(0x8F);
	LCD_WR_DATA8(0xFF);
	LCD_WR_REG(0xB6);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x20);
	LCD_WR_REG(0x36);
	if(USE_HORIZONTAL==0)LCD_WR_DATA8(0x08);
	else if(USE_HORIZONTAL==1)LCD_WR_DATA8(0xC8);
	else if(USE_HORIZONTAL==2)LCD_WR_DATA8(0x68);
	else LCD_WR_DATA8(0xA8);
	LCD_WR_REG(0x3A);
	LCD_WR_DATA8(0x05);
	LCD_WR_REG(0x90);
	LCD_WR_DATA8(0x08);
	LCD_WR_DATA8(0x08);
	LCD_WR_DATA8(0x08);
	LCD_WR_DATA8(0x08);
	LCD_WR_REG(0xBD);
	LCD_WR_DATA8(0x06);
	LCD_WR_REG(0xBC);
	LCD_WR_DATA8(0x00);
	LCD_WR_REG(0xFF);
	LCD_WR_DATA8(0x60);
	LCD_WR_DATA8(0x01);
	LCD_WR_DATA8(0x04);
	LCD_WR_REG(0xC3);
	LCD_WR_DATA8(0x13);
	LCD_WR_REG(0xC4);
	LCD_WR_DATA8(0x13);
	LCD_WR_REG(0xC9);
	LCD_WR_DATA8(0x22);
	LCD_WR_REG(0xBE);
	LCD_WR_DATA8(0x11);
	LCD_WR_REG(0xE1);
	LCD_WR_DATA8(0x10);
	LCD_WR_DATA8(0x0E);
	LCD_WR_REG(0xDF);
	LCD_WR_DATA8(0x21);
	LCD_WR_DATA8(0x0c);
	LCD_WR_DATA8(0x02);
	LCD_WR_REG(0xF0);
	LCD_WR_DATA8(0x45);
	LCD_WR_DATA8(0x09);
	LCD_WR_DATA8(0x08);
	LCD_WR_DATA8(0x08);
	LCD_WR_DATA8(0x26);
 	LCD_WR_DATA8(0x2A);
 	LCD_WR_REG(0xF1);
 	LCD_WR_DATA8(0x43);
 	LCD_WR_DATA8(0x70);
 	LCD_WR_DATA8(0x72);
 	LCD_WR_DATA8(0x36);
 	LCD_WR_DATA8(0x37);
 	LCD_WR_DATA8(0x6F);
 	LCD_WR_REG(0xF2);
 	LCD_WR_DATA8(0x45);
 	LCD_WR_DATA8(0x09);
 	LCD_WR_DATA8(0x08);
 	LCD_WR_DATA8(0x08);
 	LCD_WR_DATA8(0x26);
 	LCD_WR_DATA8(0x2A);
 	LCD_WR_REG(0xF3);
 	LCD_WR_DATA8(0x43);
 	LCD_WR_DATA8(0x70);
 	LCD_WR_DATA8(0x72);
 	LCD_WR_DATA8(0x36);
 	LCD_WR_DATA8(0x37);
 	LCD_WR_DATA8(0x6F);
	LCD_WR_REG(0xED);
	LCD_WR_DATA8(0x1B);
	LCD_WR_DATA8(0x0B);
	LCD_WR_REG(0xAE);
	LCD_WR_DATA8(0x77);
	LCD_WR_REG(0xCD);
	LCD_WR_DATA8(0x63);
	LCD_WR_REG(0x70);
	LCD_WR_DATA8(0x07);
	LCD_WR_DATA8(0x07);
	LCD_WR_DATA8(0x04);
	LCD_WR_DATA8(0x0E);
	LCD_WR_DATA8(0x0F);
	LCD_WR_DATA8(0x09);
	LCD_WR_DATA8(0x07);
	LCD_WR_DATA8(0x08);
	LCD_WR_DATA8(0x03);
	LCD_WR_REG(0xE8);
	LCD_WR_DATA8(0x34);
	LCD_WR_REG(0x62);
	LCD_WR_DATA8(0x18);
	LCD_WR_DATA8(0x0D);
	LCD_WR_DATA8(0x71);
	LCD_WR_DATA8(0xED);
	LCD_WR_DATA8(0x70);
	LCD_WR_DATA8(0x70);
	LCD_WR_DATA8(0x18);
	LCD_WR_DATA8(0x0F);
	LCD_WR_DATA8(0x71);
	LCD_WR_DATA8(0xEF);
	LCD_WR_DATA8(0x70);
	LCD_WR_DATA8(0x70);
	LCD_WR_REG(0x63);
	LCD_WR_DATA8(0x18);
	LCD_WR_DATA8(0x11);
	LCD_WR_DATA8(0x71);
	LCD_WR_DATA8(0xF1);
	LCD_WR_DATA8(0x70);
	LCD_WR_DATA8(0x70);
	LCD_WR_DATA8(0x18);
	LCD_WR_DATA8(0x13);
	LCD_WR_DATA8(0x71);
	LCD_WR_DATA8(0xF3);
	LCD_WR_DATA8(0x70);
	LCD_WR_DATA8(0x70);
	LCD_WR_REG(0x64);
	LCD_WR_DATA8(0x28);
	LCD_WR_DATA8(0x29);
	LCD_WR_DATA8(0xF1);
	LCD_WR_DATA8(0x01);
	LCD_WR_DATA8(0xF1);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x07);
	LCD_WR_REG(0x66);
	LCD_WR_DATA8(0x3C);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0xCD);
	LCD_WR_DATA8(0x67);
	LCD_WR_DATA8(0x45);
	LCD_WR_DATA8(0x45);
	LCD_WR_DATA8(0x10);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x00);
	LCD_WR_REG(0x67);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x3C);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x01);
	LCD_WR_DATA8(0x54);
	LCD_WR_DATA8(0x10);
	LCD_WR_DATA8(0x32);
	LCD_WR_DATA8(0x98);
	LCD_WR_REG(0x74);
	LCD_WR_DATA8(0x10);
	LCD_WR_DATA8(0x85);
	LCD_WR_DATA8(0x80);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x00);
	LCD_WR_DATA8(0x4E);
	LCD_WR_DATA8(0x00);
  LCD_WR_REG(0x98);
	LCD_WR_DATA8(0x3e);
	LCD_WR_DATA8(0x07);
	LCD_WR_REG(0x35);
	LCD_WR_REG(0x21);
	LCD_WR_REG(0x11);
	delay_ms(120);
	LCD_WR_REG(0x29);
	delay_ms(20);
功能代码
#include "lcd.h"
#include "lcdfont.h"
#include "delay.h"
void LCD_Fill(u16 xsta,u16 ysta,u16 xend,u16 yend,u16 color)
	u16 i,j;
	LCD_Address_Set(xsta,ysta,xend-1,yend-1);//ÉèÖÃÏÔʾ·¶Î§
	for(i=ysta;i<yend;i++)
		for(j=xsta;j<xend;j++)
			LCD_WR_DATA(color);
void LCD_DrawPoint(u16 x,u16 y,u16 color)
	LCD_Address_Set(x,y,x,y);//ÉèÖùâ±êλÖà
	LCD_WR_DATA(color);
      º¯Êý˵Ã÷£º»­Ïß
      Èë¿ÚÊý¾Ý£ºx1,y1   ÆðÊ¼×ø±ê
                x2,y2   ÖÕÖ¹×ø±ê
                color   ÏßµÄÑÕÉ«
      ·µ»ØÖµ£º  ÎÞ
void LCD_DrawLine(u16 x1,u16 y1,u16 x2,u16 y2,u16 color)
	u16 t;
	int xerr=0,yerr=0,delta_x,delta_y,distance;
	int incx,incy,uRow,uCol;
	delta_x=x2-x1; //¼ÆËã×ø±êÔöÁ¿
	delta_y=y2-y1;
	uRow=x1;//»­Ï߯ðµã×ø±ê
	uCol=y1;
	if(delta_x>0)incx=1; //ÉèÖõ¥²½·½Ïò
	else if (delta_x==0)incx=0;//´¹Ö±Ïß
	else {incx=-1;delta_x=-delta_x;}
	if(delta_y>0)incy=1;
	else if (delta_y==0)incy=0;//ˮƽÏß
	else {incy=-1;delta_y=-delta_y;}
	if(delta_x>delta_y)distance=delta_x; //ѡȡ»ù±¾ÔöÁ¿×ø±êÖá
	else distance=delta_y;
	for(t=0;t<distance+1;t++)
		LCD_DrawPoint(uRow,uCol,color);//»­µã
		xerr+=delta_x;
		yerr+=delta_y;
		if(xerr>distance)
			xerr-=distance;
			uRow+=incx;
		if(yerr>distance)
			yerr-=distance;
			uCol+=incy;
      º¯Êý˵Ã÷£º»­¾ØÐÎ
                x2,y2   ÖÕÖ¹×ø±ê
                color   ¾ØÐεÄÑÕÉ«
      ·µ»ØÖµ£º  ÎÞ
void LCD_DrawRectangle(u16 x1, u16 y1, u16 x2, u16 y2,u16 color)
	LCD_DrawLine(x1,y1,x2,y1,color);
	LCD_DrawLine(x1,y1,x1,y2,color);
	LCD_DrawLine(x1,y2,x2,y2,color);
	LCD_DrawLine(x2,y1,x2,y2,color);
      º¯Êý˵Ã÷£º»­Ô²
      Èë¿ÚÊý¾Ý£ºx0,y0   Ô²ÐÄ×ø±ê
                r       °ë¾¶
                color   Ô²µÄÑÕÉ«
      ·µ»ØÖµ£º  ÎÞ
void Draw_Circle(u16 x0,u16 y0,u8 r,u16 color)
	int a,b;
	a=0;b=r;
	while(a<=b)
		LCD_DrawPoint(x0-b,y0-a,color);             //3
		LCD_DrawPoint(x0+b,y0-a,color);             //0
		LCD_DrawPoint(x0-a,y0+b,color);             //1
		LCD_DrawPoint(x0-a,y0-b,color);             //2
		LCD_DrawPoint(x0+b,y0+a,color);             //4
		LCD_DrawPoint(x0+a,y0-b,color);             //5
		LCD_DrawPoint(x0+a,y0+b,color);             //6
		LCD_DrawPoint(x0-b,y0+a,color);             //7
		a++;
		if((a*a+b*b)>(r*r))//ÅжÏÒª»­µÄµãÊÇ·ñ¹ýÔ¶
			b--;
      º¯Êý˵Ã÷£ºÏÔʾºº×Ö´®
      Èë¿ÚÊý¾Ý£ºx,yÏÔÊ¾×ø±ê
                *s ÒªÏÔʾµÄºº×Ö´®
                fc ×ÖµÄÑÕÉ«
                bc ×ֵı³¾°É«
                sizey ×ֺŠ¿ÉÑ¡ 16 24 32
                mode:  0·Çµþ¼Óģʽ  1µþ¼Óģʽ
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowChinese(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	while(*s!=0)
		if(sizey==12) LCD_ShowChinese12x12(x,y,s,fc,bc,sizey,mode);
		else if(sizey==16) LCD_ShowChinese16x16(x,y,s,fc,bc,sizey,mode);
		else if(sizey==24) LCD_ShowChinese24x24(x,y,s,fc,bc,sizey,mode);
		else if(sizey==32) LCD_ShowChinese32x32(x,y,s,fc,bc,sizey,mode);
		else return;
		s+=2;
		x+=sizey;
      º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö12x12ºº×Ö
                *s ÒªÏÔʾµÄºº×Ö
                fc ×ÖµÄÑÕÉ«
                bc ×ֵı³¾°É«
                sizey ×ÖºÅ
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowChinese12x12(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 i,j,m=0;
	u16 k;
	u16 HZnum;//ºº×ÖÊýÄ¿
	u16 TypefaceNum;//Ò»¸ö×Ö·ûËùÕ¼×Ö½Ú´óС
	u16 x0=x;
	TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
	HZnum=sizeof(tfont12)/sizeof(typFNT_GB12);	//ͳ¼Æºº×ÖÊýÄ¿
	for(k=0;k<HZnum;k++)
		if((tfont12[k].Index[0]==*(s))&&(tfont12[k].Index[1]==*(s+1)))
			LCD_Address_Set(x,y,x+sizey-1,y+sizey-1);
			for(i=0;i<TypefaceNum;i++)
				for(j=0;j<8;j++)
					if(!mode)//·Çµþ¼Ó·½Ê½
						if(tfont12[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
						else LCD_WR_DATA(bc);
						m++;
						if(m%sizey==0)
							m=0;
							break;
					else//µþ¼Ó·½Ê½
						if(tfont12[k].Msk[i]&(0x01<<j))	LCD_DrawPoint(x,y,fc);//»­Ò»¸öµã
						x++;
						if((x-x0)==sizey)
							x=x0;
							y++;
							break;
		continue;  //²éÕÒµ½¶ÔÓ¦µãÕó×Ö¿âÁ¢¼´Í˳ö£¬·ÀÖ¹¶à¸öºº×ÖÖØ¸´È¡Ä£´øÀ´Ó°Ïì
      º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö16x16ºº×Ö
                *s ÒªÏÔʾµÄºº×Ö
                fc ×ÖµÄÑÕÉ«
                bc ×ֵı³¾°É«
                sizey ×ÖºÅ
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowChinese16x16(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 i,j,m=0;
	u16 k;
	u16 x0=x;
	HZnum=sizeof(tfont16)/sizeof(typFNT_GB16);	//ͳ¼Æºº×ÖÊýÄ¿
		if ((tfont16[k].Index[0]==*(s))&&(tfont16[k].Index[1]==*(s+1)))
				for(j=0;j<8;j++)
						if(tfont16[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
						m++;
						if(m%sizey==0)
							m=0;
							break;
					else//µþ¼Ó·½Ê½
						if(tfont16[k].Msk[i]&(0x01<<j))	LCD_DrawPoint(x,y,fc);//»­Ò»¸öµã
						x++;
						if((x-x0)==sizey)
							x=x0;
							y++;
							break;
      º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö24x24ºº×Ö
                *s ÒªÏÔʾµÄºº×Ö
                fc ×ÖµÄÑÕÉ«
                bc ×ֵı³¾°É«
                sizey ×ÖºÅ
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowChinese24x24(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 i,j,m=0;
	u16 k;
	u16 x0=x;
	HZnum=sizeof(tfont24)/sizeof(typFNT_GB24);	//ͳ¼Æºº×ÖÊýÄ¿
		if ((tfont24[k].Index[0]==*(s))&&(tfont24[k].Index[1]==*(s+1)))
				for(j=0;j<8;j++)
						if(tfont24[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
						m++;
						if(m%sizey==0)
							m=0;
							break;
					else//µþ¼Ó·½Ê½
						if(tfont24[k].Msk[i]&(0x01<<j))	LCD_DrawPoint(x,y,fc);//»­Ò»¸öµã
						x++;
						if((x-x0)==sizey)
							x=x0;
							y++;
							break;
      º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö32x32ºº×Ö
                *s ÒªÏÔʾµÄºº×Ö
                fc ×ÖµÄÑÕÉ«
                bc ×ֵı³¾°É«
                sizey ×ÖºÅ
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowChinese32x32(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 i,j,m=0;
	u16 k;
	u16 x0=x;
	HZnum=sizeof(tfont32)/sizeof(typFNT_GB32);	//ͳ¼Æºº×ÖÊýÄ¿
		if ((tfont32[k].Index[0]==*(s))&&(tfont32[k].Index[1]==*(s+1)))
				for(j=0;j<8;j++)
						if(tfont32[k].Msk[i]&(0x01<<j))LCD_WR_DATA(fc);
						m++;
						if(m%sizey==0)
							m=0;
							break;
					else//µþ¼Ó·½Ê½
						if(tfont32[k].Msk[i]&(0x01<<j))	LCD_DrawPoint(x,y,fc);//»­Ò»¸öµã
						x++;
						if((x-x0)==sizey)
							x=x0;
							y++;
							break;
      º¯Êý˵Ã÷£ºÏÔʾµ¥¸ö×Ö·û
                num ÒªÏÔʾµÄ×Ö·û
                fc ×ÖµÄÑÕÉ«
                bc ×ֵı³¾°É«
                sizey ×ÖºÅ
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowChar(u16 x,u16 y,u8 num,u16 fc,u16 bc,u8 sizey,u8 mode)
	u8 temp,sizex,t,m=0;
	u16 i,TypefaceNum;//Ò»¸ö×Ö·ûËùÕ¼×Ö½Ú´óС
	u16 x0=x;
	sizex=sizey/2;
	TypefaceNum=(sizex/8+((sizex%8)?1:0))*sizey;
	num=num-' ';    //µÃµ½Æ«ÒƺóµÄÖµ
	LCD_Address_Set(x,y,x+sizex-1,y+sizey-1);  //ÉèÖùâ±êλÖà
		if(sizey==12)temp=ascii_1206[num][i];		       //µ÷ÓÃ6x12×ÖÌå
		else if(sizey==16)temp=ascii_1608[num][i];		 //µ÷ÓÃ8x16×ÖÌå
		else if(sizey==24)temp=ascii_2412[num][i];		 //µ÷ÓÃ12x24×ÖÌå
		else if(sizey==32)temp=ascii_3216[num][i];		 //µ÷ÓÃ16x32×ÖÌå
		else return;
		for(t=0;t<8;t++)
			if(!mode)//·Çµþ¼Óģʽ
				if(temp&(0x01<<t))LCD_WR_DATA(fc);
				m++;
				if(m%sizex==0)
					m=0;
					break;
			else//µþ¼Óģʽ
				if(temp&(0x01<<t))LCD_DrawPoint(x,y,fc);//»­Ò»¸öµã
				x++;
				if((x-x0)==sizex)
					x=x0;
					y++;
					break;
      º¯Êý˵Ã÷£ºÏÔʾ×Ö·û´®
                *p ÒªÏÔʾµÄ×Ö·û´®
                fc ×ÖµÄÑÕÉ«
                bc ×ֵı³¾°É«
                sizey ×ÖºÅ
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowString(u16 x,u16 y,const u8 *p,u16 fc,u16 bc,u8 sizey,u8 mode)
	while(*p!='\0')
		LCD_ShowChar(x,y,*p,fc,bc,sizey,mode);
		x+=sizey/2;
		p++;
      º¯Êý˵Ã÷£ºÏÔʾÊý×Ö
      Èë¿ÚÊý¾Ý£ºmµ×Êý£¬nÖ¸Êý
      ·µ»ØÖµ£º  ÎÞ
u32 mypow(u8 m,u8 n)
	u32 result=1;
	while(n--)result*=m;
	return result;
      º¯Êý˵Ã÷£ºÏÔʾÕûÊý±äÁ¿
                num ÒªÏÔʾÕûÊý±äÁ¿
                len ÒªÏÔʾµÄλÊý
                fc ×ÖµÄÑÕÉ«
                bc ×ֵı³¾°É«
                sizey ×ÖºÅ
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowIntNum(u16 x,u16 y,u16 num,u8 len,u16 fc,u16 bc,u8 sizey)
	u8 t,temp;
	u8 enshow=0;
	u8 sizex=sizey/2;
	for(t=0;t<len;t++)
		temp=(num/mypow(10,len-t-1))%10;
		if(enshow==0&&t<(len-1))
			if(temp==0)
				LCD_ShowChar(x+t*sizex,y,' ',fc,bc,sizey,0);
				continue;
			}else enshow=1;
	 	LCD_ShowChar(x+t*sizex,y,temp+48,fc,bc,sizey,0);
      º¯Êý˵Ã÷£ºÏÔʾÁ½Î»Ð¡Êý±äÁ¿
                num ÒªÏÔʾСÊý±äÁ¿
                len ÒªÏÔʾµÄλÊý
                fc ×ÖµÄÑÕÉ«
                bc ×ֵı³¾°É«
                sizey ×ÖºÅ
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowFloatNum1(u16 x,u16 y,float num,u8 len,u16 fc,u16 bc,u8 sizey)
	u8 t,temp,sizex;
	u16 num1;
	sizex=sizey/2;
	num1=num*100;
	for(t=0;t<len;t++)
		temp=(num1/mypow(10,len-t-1))%10;
		if(t==(len-2))
			LCD_ShowChar(x+(len-2)*sizex,y,'.',fc,bc,sizey,0);
			t++;
			len+=1;
      º¯Êý˵Ã÷£ºÏÔʾͼƬ
      Èë¿ÚÊý¾Ý£ºx,yÆðµã×ø±ê
                length Í¼Æ¬³¤¶È
                width  Í¼Æ¬¿í¶È
                pic[]  Í¼Æ¬Êý×é
      ·µ»ØÖµ£º  ÎÞ
void LCD_ShowPicture(u16 x,u16 y,u16 length,u16 width,const u8 pic[])
	u16 i,j;
	u32 k=0;
	LCD_Address_Set(x,y,x+length-1,y+width-1);
	for(i=0;i<length;i++)
		for(j=0;j<width;j++)
			LCD_WR_DATA8(pic[k*2]);
			LCD_WR_DATA8(pic[k*2+1]);
			k++;
