MCU为stm32l0系列,时钟配置如下:
//时钟系统配置函数
//SYSCLK=Fs*PLLMUL/PLLDIV;
//Fusb=Fvco/pllq=Fs*(plln/(pllm*pllq));
//SYSCLK =
//Fs 8M
//Fvco: 8M
//SYSCLK: 系统时钟频率 8*8/2=32
//PLLMUL:倍频 8
//PLLDIV:分频系数 2
void SystemClockConfig( void )
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_PWR_CLK_ENABLE( );
__HAL_PWR_VOLTAGESCALING_CONFIG( PWR_REGULATOR_VOLTAGE_SCALE1 );
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; //高速外部时钟 8M
RCC_OscInitStruct.HSEState = RCC_HSE_ON; //打开HSE
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; //打开PLL
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; //设置PLL时钟源
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL8; //8倍频
RCC_OscInitStruct.PLL.PLLDIV = RCC_PLL_DIV2; //PLL VCO输入时钟的分频系数
if( HAL_RCC_OscConfig( &RCC_OscInitStruct ) != HAL_OK )
assert_param( FAIL );
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK |
RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; //设置系统时钟源
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; //AHB分频系数为1 32
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV8; //APB1分频系数为8 4
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; //APB2分频系数为1 32
if( HAL_RCC_ClockConfig( &RCC_ClkInitStruct, FLASH_LATENCY_1 ) != HAL_OK )
HAL_SYSTICK_Config( HAL_RCC_GetHCLKFreq( ) / 1000 );
HAL_SYSTICK_CLKSourceConfig( SYSTICK_CLKSOURCE_HCLK );
HAL_NVIC_SetPriority( SysTick_IRQn, 1, 0 );
HAL_NVIC_EnableIRQ(SysTick_IRQn);
