电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » [推荐]vision工具BIN文件格式
[推荐]vision工具BIN文件格式
2002-12-07 23:01:32     打赏
Introduction The Flat Binary File Format (BIN) is a simple binary file used to program target FLASH devices via the visionICE and visionPROBE emulator products. Bin Files are derived from the native object module format via Wind River’s Convert Utility. File Format BIN files are partitioned into two areas: HEADER and DATA. HEADER: The Header consists of 32 bytes: bytes #0-7: 8-bytes, fixed ASCII coded character string “ESTFBINR” bytes #8-11: 4-bytes, Starting Address. These four bytes contain the 32-bit target address where the data will be deposited. Byte #8 contains the most significant byte of the intended address. The left-most bit is read first and is the most significant address bit of the intended address. Byte #11 is the least significant byte. The last bit read is in byte #11 and is the least significant bit of the intended address. All addresses should be on even address boundaries. bytes #12-15: 4-bytes, Last Address (upper). Data received beyond the Last Address is discarded. byte #16: 1-byte fill character. All unused data values will be programmed to the fill character. bytes #17-23: 7-bytes, Reserved. Reserved areas are used for internal operations and should be set to 0. bytes #24-27: Actual Start Address bytes #28-31: Actual End Address DATA (#0— #n): The data field consists of 8-bit quantities -- byte #0 is the most significant data value, byte #n is the least significant data value. The total number of bytes corresponds to the range specified by the Staring Address and Last Address in the HEADER. There is no added trailer pattern or checksum. [align=right][color=#000066][此贴子已经被作者于2002-12-7 15:02:18编辑过][/color][/align]
关键词: 推荐     vision     工具     文件     格式
2002-12-09 17:11:00     打赏
shy:) 只是wind river的app note!
