[推荐]vision工具BIN文件格式
Introduction
The Flat Binary File Format (BIN) is a simple binary file used to program target FLASH
devices via the visionICE and visionPROBE emulator products. Bin Files are derived from
the native object module format via Wind River’s Convert Utility.
File Format
BIN files are partitioned into two areas: HEADER and DATA.
HEADER:
The Header consists of 32 bytes:
bytes #0-7: 8-bytes, fixed ASCII coded character string “ESTFBINR”
bytes #8-11: 4-bytes, Starting Address. These four bytes contain the 32-bit target address
where the data will be deposited. Byte #8 contains the most significant byte of the intended
address. The left-most bit is read first and is the most significant address bit of the intended
address. Byte #11 is the least significant byte. The last bit read is in byte #11 and is the least
significant bit of the intended address. All addresses should be on even address boundaries.
bytes #12-15: 4-bytes, Last Address (upper). Data received beyond the Last Address is
discarded.
byte #16: 1-byte fill character. All unused data values will be programmed to the fill
character.
bytes #17-23: 7-bytes, Reserved. Reserved areas are used for internal operations and should
be set to 0.
bytes #24-27: Actual Start Address
bytes #28-31: Actual End Address
DATA (#0— #n):
The data field consists of 8-bit quantities -- byte #0 is the most significant data value, byte #n
is the least significant data value. The total number of bytes corresponds to the range
specified by the Staring Address and Last Address in the HEADER.
There is no added trailer pattern or checksum.
[align=right][color=#000066][此贴子已经被作者于2002-12-7 15:02:18编辑过][/color][/align]
关键词: 推荐 vision 工具 文件 格式
有奖活动 | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 | |
汽车电子中巡航控制系统的使用被打赏10分 | |
【我踩过的那些坑】工作那些年踩过的记忆深刻的坑被打赏100分 | |
分享汽车电子中巡航控制系统知识被打赏10分 | |
分享安全气囊系统的检修注意事项被打赏10分 | |
分享电子控制安全气囊计算机知识点被打赏10分 | |
【分享开发笔记,赚取电动螺丝刀】【OZONE】使用方法总结被打赏20分 |
