求助大佬解决
谢谢~
参照说明,能编译生成 resource.img 和 kernel.img。
看到官方的烧录说明,是用内置eMMC存储才能烧录这两个分区?
有办法编译成.deb文件么? 试过执行 `./build.sh kerneldeb` ,但输出如下:
```bash
firefly@firefly:~/proj$ ./build.sh kerneldeb
processing option: kerneldeb
============Start building kernel deb============
TARGET_ARCH =arm64
TARGET_KERNEL_CONFIG =firefly_roc-rk3399-pc_defconfig
TARGET_KERNEL_DTS =rk3399-roc-pc
TARGET_KERNEL_CONFIG_FRAGMENT =
/home/firefly/proj
# configuration written to .config
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config/kernel.release
make KBUILD_SRC=
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
CHK scripts/mod/devicetable-offsets.h
CHK include/generated/timeconst.h
CHK include/generated/bounds.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
make[3]: 'include/generated/vdso-offsets.h' is up to date.
CHK include/generated/compile.h
DTC arch/arm64/boot/dts/rockchip/rk3399-roc-pc-exp.dtb
Error: arch/arm64/boot/dts/rockchip/rk3399-roc-pc-exp.dts:53.1-12 Label or path usb_charge not found
FATAL ERROR: Syntax error parsing input tree
scripts/Makefile.lib:320: recipe for target 'arch/arm64/boot/dts/rockchip/rk3399-roc-pc-exp.dtb' failed
make[4]: *** [arch/arm64/boot/dts/rockchip/rk3399-roc-pc-exp.dtb] Error 1
scripts/Makefile.build:484: recipe for target 'arch/arm64/boot/dts/rockchip' failed
make[3]: *** [arch/arm64/boot/dts/rockchip] Error 2
arch/arm64/Makefile:127: recipe for target 'dtbs' failed
make[2]: *** [dtbs] Error 2
make[2]: *** Waiting for unfinished jobs....
scripts/package/Makefile:96: recipe for target 'bindeb-pkg' failed
make[1]: *** [bindeb-pkg] Error 2
Makefile:1324: recipe for target 'bindeb-pkg' failed
make: *** [bindeb-pkg] Error 2
ERROR: Running build_kerneldeb failed!
ERROR: exit code 2 from line 758:
make ARCH=$RK_ARCH bindeb-pkg RK_KERNEL_DTS=$RK_KERNEL_DTS -j$RK_JOBS
这边用的SD卡启动方式,没用到eMMC存储。
| PCF8574功能模块及其使用被打赏¥20元 | |
