请问ADSP-21489怎么实现DMA功能?
看了一下例程和手册,还是不太明白怎么操作DMA,请问在C语言下,以UART为例,怎么实现DMA接收串口数据到指定的数组里或者单个变量上?能贴个代码不?
ADSP-21489是ADI公司生产的一款数字信号处理器(DSP)产品。实现DMA功能时,可以通过配置DMA的控制寄存器和源/目的地址来实现数据的传输。
以下是一个使用DMA接收UART数据的示例代码:
```c
#include
#include
#include
#include
#include "adi_initialize.h"
#include "adi_uart.h"
#include "adi_dma.h"
// UART相关配置
#define UART_DEVICE_NUM 0
#define UART_FLOW_CONTROL false
#define UART_BITRATE 115200
#define UART_WORD_LENGTH ADI_UART_WORDLEN_8BITS
#define UART_PARITY ADI_UART_PARITY_NONE
#define UART_STOP_BITS ADI_UART_ONE_STOPBIT
// DMA相关配置
#define DMA_CHANNEL_NUM 0
#define DMA_NUM_TRANSFERS 1
#define DMA_DATA_WIDTH 2 // 数据宽度:2字节(16位)
#define DMA_DATA_TRANSFER_SIZE sizeof(uint16_t) // 数据传输单位大小
// 数据接收缓冲区
#define BUFFER_SIZE 100
uint16_t buffer[BUFFER_SIZE];
// DMA完成中断标志
volatile bool dmaTransferCompleteFlag = false;
// DMA回调函数
static void dmaCallback(void *pCBParam, uint32_t Event, void *pArg)
if (Event == ADI_DMA_EVENT_TRANSFER_COMPLETE)
dmaTransferCompleteFlag = true;
int main(void)
// 系统初始化
adi_initComponents();
// 初始化UART
if (adi_uart_Open(UART_DEVICE_NUM, ADI_UART_DIR_RX, NULL, NULL, &uartDevice) != ADI_UART_SUCCESS)
printf("UART open failedn");
return -1;
if (adi_uart_ConfigData(UART_DEVICE_NUM, UART_WORD_LENGTH, UART_PARITY, UART_STOP_BITS) != ADI_UART_SUCCESS)
printf("UART configuration failedn");
return -1;
if (adi_uart_SetBitrate(UART_DEVICE_NUM, UART_BITRATE) != ADI_UART_SUCCESS)
printf("UART bitrate configuration failedn");
return -1;
// 初始化DMA
if (adi_dma_Init(NULL) != ADI_DMA_SUCCESS)
printf("DMA initialization failedn");
return -1;
// 配置DMA传输
ADI_DMA_TRANSFER dmaTransfer = {
.DestAddr = (void *)buffer,
.DestAddrMode = ADI_DMA_ADDR_MODE_LINEAR,
.SrcAddr = ADI_UART_IRQ_RXDATA_UART0,
.SrcAddrMode = ADI_DMA_ADDR_MODE_PERIPHERAL,
.DataWidth = DMA_DATA_WIDTH,
.BytesPerElement = DMA_DATA_TRANSFER_SIZE,
.ElementCount = BUFFER_SIZE,
.IncrementDestAddr = true,
.InterruptOnCompletion = true,
.UseBurstMode = true,
.EnableCircularMode = false,
.CallbackFcn = dmaCallback,
.CallbackRefCon = NULL
// 配置DMA传输通道
if (adi_dma_ChannelAllocate(DMA_CHANNEL_NUM, dmaTransfer.DestAddrMode, NULL) != ADI_DMA_SUCCESS)
printf("DMA channel allocation failedn");
return -1;
if (adi_dma_SetChannelConfig(DMA_CHANNEL_NUM, ADI_DMA_MODE_BASIC, true) != ADI_DMA_SUCCESS)
printf("DMA channel configuration failedn");
return -1;
// 开始DMA传输
if (adi_dma_SubmitTransfer(DMA_CHANNEL_NUM, &dmaTransfer) != ADI_DMA_SUCCESS)
printf("DMA transfer submission failedn");
return -1;
// 等待DMA传输完成
while (!dmaTransferCompleteFlag)
// 可以添加其他处理逻辑
// 关闭UART和DMA
adi_uart_Close(UART_DEVICE_NUM);
adi_dma_Close(DMA_CHANNEL_NUM);
return 0;
以上代码实现了使用DMA接收UART数据,并将数据存储在指定的数组中。在代码中,首先通过`adi_uart_Open`打开UART设备,然后配置UART的通信参数。接下来,初始化DMA并配置DMA传输通道和传输参数。最后,通过`adi_dma_SubmitTransfer`提交传输,等待传输完成后,关闭UART和DMA。
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
