共3条
帮忙下载windriver的patch,谢谢先!
Patch Wind Web 2.0 Cumulative Patch: Wind Web Server 2.0 Cumulative Patch #1
Save to Folder
NAME: Wind Web Server 2.0 Cumulative Patch #1
IDENTIFIER: Wind Web 2.0 Cumulative Patch
HEADLINE: Wind Web Server 2.0 Cumulative Patch #1
PRODUCT VERSION: Wind Web Server 2.0
DOWNLOADS: wws_2.0_cp1.zip
wws_cp1_release_notes.pdf
DESCRIPTION: WIND WEB Server 2.0 Cumulative Patch #1, provides solutions for a significant number of recognized problem reports.
For more information, read the WIND WEB Server
Cumulative Patch #1 Release Notes document (wws_cp1_release_notes.pdf)
INSTALLATION: The contents of the patch (wws_2.0_cp1.zip) must be extracted over the Wind Web Server 2.0 installation.
CAVEATS: None
AFFECTED PRODUCTS: Wind Web Server 2.0
AFFECTED DOCUMENTATION: N/A
REQUIRED: Mandatory
SPR (PRIMARY): 30786: WWS2.0: Excessive overhead in re-connection with server when LiveControl is used
SPRS: 29204
29996: for URIs that are too long, the server should not send 413 error
30121: demo's and tutorials using floating point examples should conditionally wrap them with ifdef's
30317
30788: WWS2.0: Memory leak exists under a host client browser when LiveControl is used.
64079: Wind Web Server 2 should spawn the server task with floating point support.
70654
71109: Potential floating point register corruption in WWS
71353
72155
75816
77044
78128
80391
80695
81300
82432
CLEARCASE LABEL/BRANCH: TBD
共3条
