请问,我更新了IAR 8.4后,
在Make 时,出现
Error[Pe235]: variable "__stdout" was declared with a never-completed type
共3条
更新了IAR8.4后,在Make时报错的原因?怎么解决?
直接把 struct struct __FILE { int handle; /* Add whatever you need here */ };拉出来编译即可
共3条
