电子产品世界 » 论坛首页 » 嵌入式开发 » 国产MCU » 如何去解决RK3568Android系统二次编译失败的问题
2024-01-31 11:46:57     打赏
之前成功编译过几次Android,近期只修改了kernel和uboot,然后回头编译Android时,发现有如下错误。
  尝试过 BoardConfig.mk 加BUILD_BROKEN_DUP_RULES := true,但又会出其他问题。
  [ 46% 128/277] including hardware/rockchip/libhwjpeg/Android.mk 。..
  [ 48% 133/277] including hardware/rockchip/omx_il/Android.mk 。..
  date: Unknown option ‘R’ (see “date --help”)
  cp: .git/hooks/pre-commit: No such file or directory
  tools/hooks .git/hooks
  [ 99% 276/277] finishing build rules 。..
  packages/apps/Camera2/Android.mk: warning: “Camera2 (app:platform) should
not link against libjni_jpegutil (native:ndk:libc++:static)”
  [100% 277/277] writing build rules 。..
  FAILED:
  build/make/core/Makefile:900: error: overriding commands for
target`out/target/product/rk3568_firefly_aioj/obj/PACKAGING/depmod_vendor_stripped_intermediates/bcmdhd.ko‘,
previously defined at build/make/core/Makefile:900
  15:45:50 ckati failed with: exit status 1
关键词: RK3568
2024-01-31 11:47:57     打赏
具体修改了什么,回退修改后是否可以编译成功
我之前也遇到过类似的问题,make clean完,git reset过,然后重新编译了几个小时,就解决了,但是不知道之前为什么出现问题。
