电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【换取手持数字示波器】STM32U083实现手势识别功能
共3条 1/1 1 跳转至页
2024-04-04 13:57:14   被打赏 40 分(兑奖)     打赏
【目的】
驱动PAJ7620U2,实现对手势的识别
【手势传感器介绍】
PAJ7620U2将手势识别功能与通用识别9个手势,包括向上移动,向~下移动,向左移动,向右移动,向前移动,向后移动,顺时针旋转,逆时针旋转和波动。可以通过12C总线简单地访问这些手势信息。PAJ7620U2还提供内置接近检测功能
用于检测接近或离开的物体。PAJ76202在节电机制方面具有极大的灵活性。
【实现步骤】
1、使用stm32cubeMAX新建工程,开启i2c1与串口2
2、生成mdk工程,并打开工程。
3、移植PAJ7620U2驱动,编写驱动如下:
PAJ7620U2.h
  * @file 			( фаил ):   PAJ7620U2.h
  * @brief 		( описание ):
  * @attention 	( внимание ):	author: Golinskiy Konstantin	e-mail: golinskiy.konstantin@gmail.com
#ifndef _PAJ7620U2_H
#define _PAJ7620U2_H
#ifdef __cplusplus
extern "C" {
#endif
/* Includes ----------------------------------------------------------*/
#include "main.h"
// num i2c ---------------------------------------------
#define PAJ7620U2_I2C										hi2c1
extern I2C_HandleTypeDef PAJ7620U2_I2C;
#define DEV_Delay_ms(__xms)							HAL_Delay(__xms)
//i2c address
#define PAJ7620U2_I2C_ADDRESS				(0x73<<1)
//Register Bank select
#define PAJ_BANK_SELECT							0xEF		//Bank0=0x00,Bank1=0x01
//Register ID ( read only )
#define PAJ_PART_ID_L								0x00		// result 0x20
#define PAJ_PART_ID_H								0x01		// result 0x76
#define PAJ_VERSION_ID							0x02		// result 0x01
//Register Bank 0
#define PAJ_SUSPEND			 						0x03		//I2C suspend command (Write 0x01 to enter suspend state). I2C wake-up command is slave ID wake-up. Refer to topic I2C Bus Timing Characteristics and Protocol
#define PAJ_INT_FLAG1_MASK					0x41		//Gesture detection interrupt flag mask
#define PAJ_INT_FLAG2_MASK					0x42		//Gesture/PS detection interrupt flag mask
#define PAJ_INT_FLAG1		    				0x43		//Gesture detection interrupt flag
#define PAJ_INT_FLAG2								0x44		//Gesture/PS detection interrupt flag
#define PAJ_STATE										0x45		//State indicator for gesture detection (Only functional at gesture detection mode)
#define PAJ_PS_HIGH_THRESHOLD				0x69		//PS hysteresis high threshold (Only functional at proximity detection mode)
#define PAJ_PS_LOW_THRESHOLD				0x6A		//PS hysteresis low threshold (Only functional at proximity detection mode)
#define PAJ_PS_APPROACH_STATE				0x6B		//PS approach state,  Approach = 1 , (8 bits PS data >= PS high threshold),  Not Approach = 0 , (8 bits PS data <= PS low threshold)(Only functional at proximity detection mode)
#define PAJ_PS_DATA									0x6C		//PS 8 bit data(Only functional at gesture detection mode)
#define PAJ_OBJ_BRIGHTNESS					0xB0		//Object Brightness (Max. 255)
#define PAJ_OBJ_SIZE_L							0xB1		//Object Size(Low 8 bit)
#define PAJ_OBJ_SIZE_H							0xB2		//Object Size(High 8 bit)
//Register Bank 1
#define PAJ_PS_GAIN									0x44		//PS gain setting (Only functional at proximity detection mode)
#define PAJ_IDLE_S1_STEP_L					0x67		//IDLE S1 Step, for setting the S1, Response Factor(Low 8 bit)
#define PAJ_IDLE_S1_STEP_H					0x68		//IDLE S1 Step, for setting the S1, Response Factor(High 8 bit)
#define PAJ_IDLE_S2_STEP_L					0x69		//IDLE S2 Step, for setting the S2, Response Factor(Low 8 bit)
#define PAJ_IDLE_S2_STEP_H					0x6A		//IDLE S2 Step, for setting the S2, Response Factor(High 8 bit)
#define PAJ_OPTOS1_TIME_L						0x6B		//OPtoS1 Step, for setting the OPtoS1 time of operation state to standby 1 state(Low 8 bit)
#define PAJ_OPTOS2_TIME_H						0x6C		//OPtoS1 Step, for setting the OPtoS1 time of operation state to standby 1 stateHigh 8 bit)
#define PAJ_S1TOS2_TIME_L						0x6D		//S1toS2 Step, for setting the S1toS2 time of standby 1 state to standby 2 state(Low 8 bit)
#define PAJ_S1TOS2_TIME_H						0x6E		//S1toS2 Step, for setting the S1toS2 time of standby 1 state to standby 2 stateHigh 8 bit)
#define PAJ_EN											0x72		//Enable/Disable PAJ7620U2
#define PAJ_NONE										0x0000	// отсутствует
#define PAJ_UP				    					0x0001 	// вверх
#define PAJ_DOWN			    					0x0002	// вниз
#define PAJ_LEFT			    					0x0004 	// влево
#define PAJ_RIGHT			    					0x0008	// вправо
#define PAJ_FORWARD			    				0x0010 	// вперед
#define PAJ_BACKWARD		    				0x0020	// назад
#define PAJ_CLOCKWISE								0x0040	// по часовой стрелке
#define PAJ_ANTI_CLOCKWISE					0x0080	// против часовой стрелки
#define PAJ_WAVE										0x0100	// волна
#define PAJ_PARTID  								0x7620
//Power up initialize array
extern const uint8_t Init_Register_Array[][2];
//Initialize array size
#define Init_Array 									sizeof(Init_Register_Array)/2
//Bank 0 or 1
typedef enum:uint8_t{
	PAJ_BANK_0,			//Bank0 = 0x00
	PAJ_BANK_1			//Bank1 = 0x01
}Paj_Bank_Num;
/* Functions prototypes ----------------------------------------------*/
uint16_t PAJ7620U2_init(void);
uint16_t PAJ7620U2_Gesture_ReadData(void);
uint8_t PAJ7620U2_PS_ReadObjBrightness(void);
uint16_t PAJ7620U2_PS_ReadObjSize(void);
#ifdef __cplusplus
#endif
#endif	/*	_PAJ7620U2_H */
/************************ (C) COPYRIGHT GKP *****END OF FILE****/
PAJ7620U2.c代码如下:
  * @file 			( фаил ):   PAJ7620U2.c
#include "PAJ7620U2.h"
const uint8_t Init_Register_Array[][2] = {
		{0xEF,0x00},
    {0x32,0x29},
    {0x33,0x01},
    {0x34,0x00},
    {0x35,0x01},
    {0x36,0x00},
    {0x37,0x07},
    {0x38,0x17},
    {0x39,0x06},
    {0x3A,0x12},
    {0x3F,0x00},
    {0x40,0x02},
    {0x41,0xFF},
    {0x42,0x01},
    {0x46,0x2D},
    {0x47,0x0F},
    {0x48,0x3C},
    {0x49,0x00},
    {0x4A,0x1E},
    {0x4B,0x00},
    {0x4C,0x20},
    {0x4D,0x00},
    {0x4E,0x1A},
    {0x4F,0x14},
    {0x50,0x00},
    {0x51,0x10},
    {0x52,0x00},
    {0x5C,0x02},
    {0x5D,0x00},
    {0x5E,0x10},
    {0x5F,0x3F},
    {0x60,0x27},
    {0x61,0x28},
    {0x62,0x00},
    {0x63,0x03},
    {0x64,0xF7},
    {0x65,0x03},
    {0x66,0xD9},
    {0x67,0x03},
    {0x68,0x01},
    {0x69,0xC8},
    {0x6A,0x40},
    {0x6D,0x04},
    {0x6E,0x00},
    {0x6F,0x00},
    {0x70,0x80},
    {0x71,0x00},
    {0x72,0x00},
    {0x73,0x00},
    {0x74,0xF0},
    {0x75,0x00},
    {0x80,0x42},
    {0x81,0x44},
    {0x82,0x04},
    {0x83,0x20},
    {0x84,0x20},
    {0x85,0x00},
    {0x86,0x10},
    {0x87,0x00},
    {0x88,0x05},
    {0x89,0x18},
    {0x8A,0x10},
    {0x8B,0x01},
    {0x8C,0x37},
    {0x8D,0x00},
    {0x8E,0xF0},
    {0x8F,0x81},
    {0x90,0x06},
    {0x91,0x06},
    {0x92,0x1E},
    {0x93,0x0D},
    {0x94,0x0A},
    {0x95,0x0A},
    {0x96,0x0C},
    {0x97,0x05},
    {0x98,0x0A},
    {0x99,0x41},
    {0x9A,0x14},
    {0x9B,0x0A},
    {0x9C,0x3F},
    {0x9D,0x33},
    {0x9E,0xAE},
    {0x9F,0xF9},
    {0xA0,0x48},
    {0xA1,0x13},
    {0xA2,0x10},
    {0xA3,0x08},
    {0xA4,0x30},
    {0xA5,0x19},
    {0xA6,0x10},
    {0xA7,0x08},
    {0xA8,0x24},
    {0xA9,0x04},
    {0xAA,0x1E},
    {0xAB,0x1E},
    {0xCC,0x19},
    {0xCD,0x0B},
    {0xCE,0x13},
    {0xCF,0x64},
    {0xD0,0x21},
    {0xD1,0x0F},
    {0xD2,0x88},
    {0xE0,0x01},
    {0xE1,0x04},
    {0xE2,0x41},
    {0xE3,0xD6},
    {0xE4,0x00},
    {0xE5,0x0C},
    {0xE6,0x0A},
    {0xE7,0x00},
    {0xE8,0x00},
    {0xE9,0x00},
    {0xEE,0x07},
    {0xEF,0x01},
    {0x00,0x1E},
    {0x01,0x1E},
    {0x02,0x0F},
    {0x03,0x10},
    {0x04,0x02},
    {0x05,0x00},
    {0x06,0xB0},
    {0x07,0x04},
    {0x08,0x0D},
    {0x09,0x0E},
    {0x0A,0x9C},
    {0x0B,0x04},
    {0x0C,0x05},
    {0x0D,0x0F},
    {0x0E,0x02},
    {0x0F,0x12},
    {0x10,0x02},
    {0x11,0x02},
    {0x12,0x00},
    {0x13,0x01},
    {0x14,0x05},
    {0x15,0x07},
    {0x16,0x05},
    {0x17,0x07},
    {0x18,0x01},
    {0x19,0x04},
    {0x1A,0x05},
    {0x1B,0x0C},
    {0x1C,0x2A},
    {0x1D,0x01},
    {0x1E,0x00},
    {0x21,0x00},
    {0x22,0x00},
    {0x23,0x00},
    {0x25,0x01},
    {0x26,0x00},
    {0x27,0x39},
    {0x28,0x7F},
    {0x29,0x08},
    {0x30,0x03},
    {0x31,0x00},
    {0x32,0x1A},
    {0x33,0x1A},
    {0x34,0x07},
    {0x35,0x07},
    {0x36,0x01},
    {0x37,0xFF},
    {0x38,0x36},
    {0x39,0x07},
    {0x3A,0x00},
    {0x3E,0xFF},
    {0x3F,0x00},
    {0x40,0x77},
    {0x41,0x40},
    {0x42,0x00},
    {0x43,0x30},
    {0x44,0xA0},
    {0x45,0x5C},
    {0x46,0x00},
    {0x47,0x00},
    {0x48,0x58},
    {0x4A,0x1E},
    {0x4B,0x1E},
    {0x4C,0x00},
    {0x4D,0x00},
    {0x4E,0xA0},
    {0x4F,0x80},
    {0x50,0x00},
    {0x51,0x00},
    {0x52,0x00},
    {0x53,0x00},
    {0x54,0x00},
    {0x57,0x80},
    {0x59,0x10},
    {0x5A,0x08},
    {0x5B,0x94},
    {0x5C,0xE8},
    {0x5D,0x08},
    {0x5E,0x3D},
    {0x5F,0x99},
    {0x60,0x45},
    {0x61,0x40},
    {0x63,0x2D},
    {0x64,0x02},
    {0x65,0x96},
    {0x66,0x00},
    {0x67,0x97},
    {0x68,0x01},
    {0x69,0xCD},
    {0x6A,0x01},
    {0x6B,0xB0},
    {0x6C,0x04},
    {0x6D,0x2C},
    {0x6E,0x01},
    {0x6F,0x32},
    {0x71,0x00},
    {0x72,0x01},
    {0x73,0x35},
    {0x74,0x00},
    {0x75,0x33},
    {0x76,0x31},
    {0x77,0x01},
    {0x7C,0x84},
    {0x7D,0x03},
    {0x7E,0x01}
function:
	I2C Write and Read
static void DEV_I2C_WriteByte(uint8_t add_, uint8_t data_)
	uint8_t Buf[1] = {0};
	Buf[0] = data_;
	HAL_I2C_Mem_Write(&PAJ7620U2_I2C, PAJ7620U2_I2C_ADDRESS, add_, I2C_MEMADD_SIZE_8BIT, Buf, 1, 500);
static void DEV_I2C_WriteWord(uint8_t add_, uint16_t data_)
	uint8_t Buf[2] = {0};
	Buf[0] = data_ >> 8;
	Buf[1] = data_;
	HAL_I2C_Mem_Write(&PAJ7620U2_I2C, PAJ7620U2_I2C_ADDRESS, add_, I2C_MEMADD_SIZE_8BIT, Buf, 2, 500);
static uint8_t DEV_I2C_ReadByte(uint8_t add_)
	uint8_t Buf[1]={add_};
	HAL_I2C_Mem_Read(&PAJ7620U2_I2C, PAJ7620U2_I2C_ADDRESS, add_, I2C_MEMADD_SIZE_8BIT, Buf, 1, 500);
	return Buf[0];
static uint16_t DEV_I2C_ReadWord(uint8_t add_)
    uint8_t Buf[2]={0, 0};
		HAL_I2C_Mem_Read(&PAJ7620U2_I2C, PAJ7620U2_I2C_ADDRESS, add_, I2C_MEMADD_SIZE_8BIT, Buf, 2, 500);
    return ((Buf[1] << 8) | (Buf[0] & 0xff));
static uint16_t PAJ7620U2_GetPartID(void)
	uint8_t data[2] = {0, };
	data[0] = DEV_I2C_ReadByte(PAJ_PART_ID_L);
	data[1] = DEV_I2C_ReadByte(PAJ_PART_ID_H);
	return ((uint16_t)data[1]<<8) | data[0];
// при инициализации возвращает ( если соединение с датчиком удачное ) значение 0x7620 либо 0 если датчик не увидел
	uint16_t ID = PAJ7620U2_GetPartID();
	if( ID == PAJ_PARTID ){
		DEV_I2C_WriteByte(PAJ_BANK_SELECT, PAJ_BANK_0);
		for (uint8_t i = 0; i < Init_Array; i++ )
			 DEV_I2C_WriteByte(Init_Register_Array[i][0], Init_Register_Array[i][1]);//Power up initialize
		return ID;
	return 0;
// запрашиваем номер движения ( если движения небыло вернет 0 ) если было то его номер
	return DEV_I2C_ReadWord(PAJ_INT_FLAG1);
// Object Brightness (Max. 255)
	return DEV_I2C_ReadByte(PAJ_OBJ_BRIGHTNESS);
// Object Size (Max. 900)
	return DEV_I2C_ReadWord(PAJ_OBJ_SIZE_L);
3、在main.c中先定义初始化变量:
/* USER CODE BEGIN PTD */
int Gesture_Data = 0;
uint8_t OBJ_BRIGHTNESS = 0;		// Object Brightness (Max. 255)
uint16_t OBJ_SIZE = 0;				// Object Size (Max. 900)
/* USER CODE END PTD */
4、添加PAJ7620U2的init函数。并在while循环中检测是否有手势,如果有,通过case分别给予打印到串口中。
uint16_t ID = PAJ7620U2_init();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
				Gesture_Data = PAJ7620U2_Gesture_ReadData();
		// если движение было то
		if( Gesture_Data != PAJ_NONE )
			switch (Gesture_Data)
				case PAJ_UP:
					HAL_UART_Transmit(&huart2,"Up -> Data\n",sizeof("Up -> Data\n"),100);
					break;
				case PAJ_DOWN:
					HAL_UART_Transmit(&huart2,"Down -> Data\n",sizeof("Down -> Data\n"),100);
				break;	// вниз
				case PAJ_LEFT:
					HAL_UART_Transmit(&huart2,"Left -> Data\n",sizeof("Left -> Data\n"),100);
				break;	// влево
				case PAJ_RIGHT:
					HAL_UART_Transmit(&huart2,"Right -> Data\n",sizeof("Right -> Data\n"),100);
				break;	// вправо
				case PAJ_FORWARD:
					HAL_UART_Transmit(&huart2,"Forward -> Data\n",sizeof("Forward -> Data\n"),100);
				break;	// вперед
				case PAJ_BACKWARD:
					HAL_UART_Transmit(&huart2,"Backward -> Data\n",sizeof("Backward -> Data\n"),100);
				break;	// назад
				case PAJ_CLOCKWISE:
					HAL_UART_Transmit(&huart2,"Clockwise -> Data\n",sizeof("Clockwise -> Data\n"),100);
				break;	// по часовой стрелке
				case PAJ_ANTI_CLOCKWISE:
					HAL_UART_Transmit(&huart2,"AntiClockwise -> Data\n",sizeof("AntiClockwise -> Data\n"),100);
				break;	// против часовой стрелки
				case PAJ_WAVE:
					HAL_UART_Transmit(&huart2,"Wave -> Data\n",sizeof("Wave -> Data\n"),100);
				break;	// волна
				default: break;
		Gesture_Data = 0;
		// запрашиваем размер и освященность обьекта перед датчиком
		OBJ_BRIGHTNESS = PAJ7620U2_PS_ReadObjBrightness();	// Object Brightness (Max. 255)
		OBJ_SIZE = PAJ7620U2_PS_ReadObjSize();							// Object Size (Max. 900)
		HAL_Delay(50);
    /* USER CODE END WHILE */
【实验效果】
上传代码到开发板后,打开串口助手,可以看到可以正确的识别了手势,并打印出来。
关键词: STM32U0     PAJ7620U2
2024-04-04 14:12:41     打赏
不错啊
2024-04-19 08:36:32     打赏
不错不错
共3条 1/1 1 跳转至页
