电子产品世界 » 论坛首页 » 企业专区 » TI » 【MSP焕新大作战】课程2+任务2
共3条 1/1 1 跳转至页
【MSP焕新大作战】课程2+任务2
2024-07-03 15:47:29     打赏
实现数码管数字递减
要注意
DAT
CLK
RCK
与硬件的接线
代码如下
#include "ti_msp_dl_config.h"
/* This results in approximately 0.5s of delay assuming 32MHz CPU_CLK */
#define DELAY (16000000)
uint8_t Disp_Dx[16]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x8c,0xbf,0xc6,0xa1,0x86,0xff};
uint8_t Disp_Px[8]={1,2,3,4,5,6,7,8};
uint16_t tempval =456;
uint8_t TimerCnt = 0 ;
#define HC595_DAT(x)   ((x)?(DL_GPIO_setPins(GPIO_LEDS_PORT,GPIO_LEDS_DAT_PIN)):(DL_GPIO_clearPins(GPIO_LEDS_PORT,GPIO_LEDS_DAT_PIN)))
#define HC595_CLK(x)   ((x)?(DL_GPIO_setPins(GPIO_LEDS_PORT,GPIO_LEDS_CLK_PIN)):(DL_GPIO_clearPins(GPIO_LEDS_PORT,GPIO_LEDS_CLK_PIN)))
#define HC595_RCK(x)   ((x)?(DL_GPIO_setPins(GPIO_LEDS_PORT,GPIO_LEDS_RCK_PIN)):(DL_GPIO_clearPins(GPIO_LEDS_PORT,GPIO_LEDS_RCK_PIN)))
void display_out()
    HC595_RCK(0);
    delay_cycles(32);
    HC595_RCK(1);
    delay_cycles(32);
void hc595_writedata(uint8_t data)
    uint8_t i;
    for(i =0 ;i < 8; i++)
        if(data&0x80)
            HC595_DAT(1);
        else
            HC595_DAT(0);
        data <<=1;
        HC595_CLK(0);
        delay_cycles(32);
        HC595_CLK(1);
        delay_cycles(32);
void hc_send_data(uint8_t dis_num,uint8_t dis_bit)
    hc595_writedata(dis_num);
    hc595_writedata(1<<dis_bit);
    display_out();
void disp_data(uint16_t datal)
    uint16_t templ;
    uint8_t num_q,num_b,num_s,num_g;
    templ = datal;
    num_q = templ/1000;
    num_b = templ/100%10;
    num_s = templ/10%10;
    num_g = templ%10;
    hc_send_data(Disp_Dx[num_q],3);
    hc_send_data(Disp_Dx[num_b],2);
    hc_send_data(Disp_Dx[num_s],1);
    hc_send_data(Disp_Dx[num_g],0);
int main(void)
    /* Power on GPIO, initialize pins as digital outputs */
    SYSCFG_DL_init();
    NVIC_EnableIRQ(TIMER_0_INST_INT_IRQN);
    while (1) {
        disp_data(tempval);
void TIMER_0_INST_IRQHandler(void)
    switch(DL_TimerG_getPendingInterrupt(TIMER_0_INST))
    case DL_TIMER_IIDX_ZERO:
        TimerCnt++;
        if(TimerCnt >=100)
            TimerCnt=0;
            tempval--;
            if(tempval>500)tempval=0;
        break;
    default:
        break;
演示视频
https://www.bilibili.com/video/BV1PwhkehEeG/?vd_source=4f8f0092a0967d5a44cc4790809b35be
2024-07-03 15:57:17     打赏
2024-07-12 07:33:29     打赏
共3条 1/1 1 跳转至页
