1、复制一个示例i2c的示例工程,并重命名为LP_MSPM0G3507_oled
2、开启i2c1,并设置速率为400K
3、保存到工程,然后添加oled的驱动库
4、在驱动库中,主要需要修改的为write_byte函数,内容如下:
int I2C_WriteByte(uint8_t addr, uint8_t data) {
uint8_t buff[2] = {0};
buff[0] = addr;
buff[1] = data;
/* Wait for I2C to be Idle */
while (!(DL_I2C_getControllerStatus(I2C_OLED_INST) &
DL_I2C_CONTROLLER_STATUS_IDLE))
/* Send the packet to the controller.
* This function will send Start + Stop automatically.
DL_I2C_startControllerTransfer(I2C_OLED_INST, OLED_ADDR,
DL_I2C_CONTROLLER_DIRECTION_TX, 2);
DL_I2C_fillControllerTXFIFO(I2C_OLED_INST, &buff[0], 2);
/* Poll until the Controller writes all bytes */
while (DL_I2C_getControllerStatus(I2C_OLED_INST) &
DL_I2C_CONTROLLER_STATUS_BUSY_BUS)
/* Trap if there was an error */
if (DL_I2C_getControllerStatus(I2C_OLED_INST) &
DL_I2C_CONTROLLER_STATUS_ERROR) {
/* LED will remain high if there is an error */
__BKPT(0);
return 0;
}这样我们的代码就移植完毕。
4、添加测试代码:
#include "ti_msp_dl_config.h"
#include "\oled\oled.h"
int main(void)
SYSCFG_DL_init();
/* Set LED to indicate start of transfer */
OLED_Init();
OLED_CLS();
OLED_ShowString(3, 1,"LP-MSPM0G3507", 2);
OLED_ShowString(5, 1,"eepw Ti", 2);
/* If write and read were successful, toggle LED */
while (1) {
}5、测试结果:
到此移植OLED就完毕。
【移植要点】
1、要准备已经做好的OLED的驱动。
2、配置好I2C。
3、改写i2cwritbyte函数。
