电子产品世界 » 论坛首页 » 企业专区 » TI » 【MSP焕新大作战】课程二+任务二
【MSP焕新大作战】课程二+任务二
2024-07-13 13:01:59     打赏
通过数码管显示数字变化,首先需要将跳线帽拔掉
进入syscfg进行初始化GPIO管脚和定时器,分别配置
PA27==>HC595_DAT,
PA26==>HC595_SLK,
PA13==>HC595_RLK,
在代码中编写HC595驱动函数:
uint16_t tempval =456;
uint8_t TimerCnt = 0 ;
unsigned char Disp_DX[16] ={ 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x8C, 0xBF, 0xC6, 0xA1, 0x86, 0xFF };
unsigned char Disp_PX[8] = {1,2,3,4,5,6,7,8};
#define HC595_DAT(x)				((x)?(DL_GPIO_setPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_DAT_PIN)) : (DL_GPIO_clearPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_DAT_PIN)))
#define HC595_CLK(x)				((x)?(DL_GPIO_setPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_SLK_PIN)) : (DL_GPIO_clearPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_SLK_PIN)))
#define HC595_RCK(x)				((x)?(DL_GPIO_setPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_RLK_PIN)) : (DL_GPIO_clearPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_RLK_PIN)))
void Display_0ut()
	HC595_RCK(0);
	delay_cycles(32);
	HC595_RCK(1);
	delay_cycles(32);
void HC595_WriteData(unsigned char data)
	unsigned char i;
	for(i=0;i<8;i++)
		if(data & 0x80)
			HC595_DAT(1);
		else
			HC595_DAT(0);
		data <<= 1;
		HC595_CLK(0);
		delay_cycles(32);
		HC595_CLK(1);
		delay_cycles(32);
void HC595_Send_Data(uint8_t dis_num,uint8_t dis_bit)
	HC595_WriteData(dis_num);
	HC595_WriteData(1<<dis_bit);
	Display_0ut();
void Disp_Data(uint16_t u16DataH)
    uint16_t templ,tempH;
    uint8_t num_q,num_b,num_s,num_g;
    tempH = u16DataH;
    num_q = tempH/1000;
    num_b = tempH/100%10;
    num_s = tempH/10%10;
    num_g = tempH%10;
    HC595_Send_Data(Disp_DX[num_q],7);
    HC595_Send_Data(Disp_DX[num_b],6);
    HC595_Send_Data(Disp_DX[num_s],5);
    HC595_Send_Data(Disp_DX[num_g],4);
void TIMER_0_INST_IRQHandler(void)
	 switch(DL_TimerG_getPendingInterrupt(TIMER_0_INST))
	    case DL_TIMER_IIDX_ZERO:
	        TimerCnt++;
	        if(TimerCnt >=100)
	            TimerCnt=0;
	            tempval--;
	            if(tempval>500)tempval=0;
	        break;
	    default:
	        break;
在主函数中调用:
关键词: 任务     课程
